Old 11-16-2008, 12:37 PM   #16 (permalink)
Slow_spool's Avatar
Member Number: 50382
Trader Rating: (33)
Quote: Originally Posted by mightyxwhitey53 View Post
^^yup...about the only advantage i can see is quicker throttle response of the 4 itb's...
i would see it being a huge restriction like turbomopargod said.
for a normal srt street setup a 55-62mm throttlebody is just fine for all 4 cylinders.
now think about how small a throttle body is going to be for each cylinder (as long as its a 37r or smaller turbo imo, more of a street practical setup)
now with a smaller TB, the throttle plate and shaft will be in the way of airflow for each TB
Slow_spool is offline   Reply With Quote
Old 11-16-2008, 12:39 PM   #17 (permalink)
mightyxwhitey53's Avatar
Member Number: 30679
Quote: Originally Posted by TurboMoparGod View Post
I almost think 4 TB's on a turbo car would be a restriction due to 4 tb plates and 4 tb shafts in front of each runner vs. 1 tb plate and 1 tb shaft at the end of an intake manifold. Think about it.
true...but i think if you had a good enough fabricator and design...it could be done...i just done see it being worth the cost
Texas' first DCR SRT TT 11.30@126.02
Forever Tuned by Mark Riley
531hp 450tq 5 spd
420hp 400tq 3 spd auto
Quote: Originally Posted by stowaway
Dear mightyxwhitey53,
You have received an infraction at SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum.
Reason: Bashing a 'tard
mightyxwhitey53 is offline   Reply With Quote
Old 11-16-2008, 12:45 PM   #18 (permalink)
TurboMoparGod's Avatar
Member Number: 33697
Trader Rating: (58)
Exactly.
Forward Motion 302-658-2829
http://www.forwardmotioninc.com/html...og/page18.html
Sales@ForwardMotioninc.com
Stock turbo 12.82@107mph DR's
E1 Turbo 12.48@115mph DR's slipping stock clutch
E3 47lb Turbo 1/8 7.923@93.67 1.95 60' 235/60/15 DR's
TurboMoparGod is offline   Reply With Quote
Old 11-16-2008, 12:51 PM   #19 (permalink)
Member Number: 27506
Quote: Originally Posted by Slow_spool View Post
actually they are really complicated to tune correctly.. a friend of mine Dennis from hybrid dynamics did several articles about it in modified mag.
none of the RB series motors come with individual throttle bodies.
especially a forced induction motor, like said before it just complicates things.
i dont see a benefit to running a single intercooler pipe to each cylinder.
if there was a benefit to it everbody would be doing it, and it would have been done on the pro forced induction nhra 4 cylinder style cars several years ago
Please don't spread mis-information if you don't know or never seen a stock GTR r32-r34 then don't tell him he's wrong, they do come with ITB's.
ITB's are a thing of the N/A world it's just not worth the hassle in a F/I car when you can just up the boost and get the same benefit, it's not that it won't work.
Why re-invent the wheel?
DGR8srt is offline   Reply With Quote
Old 11-16-2008, 12:55 PM   #20 (permalink)
^^some people just like trying new things..if youve got the time and money cool.
Old 11-16-2008, 01:18 PM   #21 (permalink)
aww sheet's Avatar
Member Number: 20431
Trader Rating: (31)
yes rb26 motors have itb's, alot people convert to a single q45 t/b
get it right
View Modifications
Old 11-16-2008, 01:32 PM   #22 (permalink)
Slow_spool's Avatar
Trader Rating: (33)
get it right
no they dont dip shit..
ive worked on a skyline before...R32 with a rb26 swap
here is a rb26:
rb25:
rb20:
Old 11-16-2008, 01:43 PM   #23 (permalink)
Slow_spool's Avatar
Trader Rating: (33)
only 2 pics of my friends swap i could find of the motor, this is when it was stock:
Old 11-16-2008, 07:07 PM   #24 (permalink)
aww sheet's Avatar
Trader Rating: (31)
ok 1st off i didn't say anything about rb20 motors.
2nd the pics of the rb25/rb26 motors have aftermarket intake manifolds which goes back to my previous statement about alot them being converted to a single t/b
3rd look and this pic that you posted, you see that little bracket on top of the intake? thats what opens all the butterflies in what?.........the individual throttlebodies.
worked on a rb26 huh? what did you do change the air filter?
and you watch who you call a dipshit just because you came on here acting like you knew what you were talking about, and got called out on it.
Old 11-16-2008, 07:14 PM   #25 (permalink)
aww sheet's Avatar
Trader Rating: (31)
oh and here reading is fundamental.
nissan rb26
Old 11-16-2008, 07:36 PM   #26 (permalink)
Member Number: 42667
Here.....a quick 2 second search shows all kinds of pics of the ITB's on the RB26 engine.
http://www.buwaldahybrids.com/speed.htm
05plsrt4 is offline   Reply With Quote
Old 11-16-2008, 07:45 PM   #27 (permalink)
Slow_spool's Avatar
Trader Rating: (33)
all along i thought you were talking about individual runners and TB's...i thought you ment they dont use a intake plenum and would run a intercooler pipe to each TB.
sorry for the misconfusion.
they still use a conventional intake plenum which is what i was getting at...
nissan rb26
i didnt see anything about the individual tb's in here though?
more info here manifold design
Old 11-16-2008, 07:51 PM   #28 (permalink)
aww sheet's Avatar
Trader Rating: (31)
^^^^its in the 1st paragraph but, ok
Old 11-16-2008, 09:53 PM   #29 (permalink)
duster360's Avatar
Member Number: 45182
Individiual runners "show" more benefit to NA engines where tuning specific pressure resonances is key to top performance, but they would also benefit a turbo car similiarly. A turbo will more easily mask a poor design.
There would be no "restriction"
On a 2.4L the tb diameter should be around 36mm-42mm. Thats obviuosly a considerable increase in tb area over a single 60mm tb, since each port has its own.
Tuning NA is a little bit of a chore because the lack of a plenum volume allows the MAP signal to pulse with each cylinder stroke, mostly just at sub-baro pressures. A plenum acts to dampen expansion waves which keeps the fuel map steady . I've tuned a GSXR(600cc, N/A, itb 34mm tb) with an aftermarket EFI and it wasn't that big of a deal.
duster360 is online now   Reply With Quote
Old 11-16-2008, 10:35 PM   #30 (permalink)
Member Number: 36823
not realy in puerto rico thats what most people use in there old school cars....and this guys run 8 secs all day.............but they run webers not itb....
Mopar4chic is offline   Reply With Quote
Page generated in 0.22886 seconds with 13 queries
