Nice!!! Congrats. Finally someone ordered the 40lb wheel. You should be able to turn some good numbers at the track with that setup. F all that dyno queen shit! Im gonna follow your results with that kit. Are you just basically install the kit and retune with the SAFC? That looks like all you should need to do.
thats the plan so far till i can get some cash for a returnline and a fuel pump with the bottleneck fix 1600+ in the hole drains a banking account the SST combo's best was a 12.7 at 110 with a 2.05 60ft so im sure ill get more outta the delta/40lb!!
amusement will be high at first, but youll be bored shortly after and want more
well thats said for about anything once you get used to it you want more right!! Anyways the 40lb is more than enough for me my sst was ALMOST enough but it kept the egt's to high!
Yes and being that they all use the same log style manifold you can easily get the 44/48lb and slap it on and re-tune. I think starting with the 40lb wheel is a great way to approach it.
