Old 02-12-2005, 08:53 PM   #1 (permalink)
Member Number: 23982
Exclamation I Need Alot Of Help Here.new Srt4 Owner
i am buying an srt-4 in lat ematch a 2005. I am wandering what performance parts can i get to give me more HP'S. what kind of cat-back system?? what kind of cool air inake? I am getting it lowered, getting a turbo timer, and i was wondering if i can replace the hoses that go to the intercooler to the motor, from rubber to intake like pipeing, and will any of this void my warranyt?? please i need help and thank you very much!!!!
soon to be a proud owner!!!!
Downtone61 is offline   Reply With Quote
Old 02-12-2005, 08:54 PM   #2 (permalink)
Default bof
and should i look at getting a new blow off Val and what kind should i get??
Old 02-13-2005, 03:17 PM   #3 (permalink)
Technical Tuning & EFI/EMS Electronics moderator
sour kraut's Avatar
Member Number: 19796
Before everyone rips you a new one, I'd say try using the search function.
sour kraut is offline   Reply With Quote
Old 02-13-2005, 07:16 PM   #4 (permalink)
Member Number: 14465
There are tons of mods. Search for performance guide and it gives you kind of a direction to go in.
ohiosrt4 is offline   Reply With Quote
Old 02-14-2005, 12:59 AM   #5 (permalink)
Member Number: 20423
almost all aftermarket parts are going to void the warr but that's only if they find out.
ByByGT is offline   Reply With Quote
Old 02-14-2005, 01:59 AM   #6 (permalink)
Member Number: 20381
Post
You should mod your way up intake, exhaust, pipes,etc. etc. whatever, but if i were you i would not put any blow off valve on, or shit thats not needed at least before you get a higher boost...talk to these guys about your car they have been there and for the most part done that..use the search, Dont just help looks or hp/tq numbers, Do the little things they add up to be big and worthy Example: CATCH CAN, stuff that should be there if you had a say in the car when built (small stuff). Things that you want right away arent always going to be needed or even wanted in the long run...bass?? MOPAR BLOWOFFVALVE??-
cLined is offline   Reply With Quote
Old 02-14-2005, 03:33 AM   #7 (permalink)
skipdogg's Avatar
Member Number: 18045
Alright, I had a hard time deciphering your post, but I'll attempt to answer your questions.
Performance parts that will give you more HP'S (assuming you mean horsepower?)
- I would stick with the Mopar stage upgrades. Stage 1 is a great building block for alot of future modifications.
As for your cat-back
- The Mopar/Borla is relatively inexpensive, and sounds great. It was designed for the car. I highly recommend it.
Cold Air Intake
- A CAI is pointless on a relatively stock car. Save your money, buy a K&N drop in filter for the car. A CAI will not get you more power on our car. (if someone can dyno prove that it makes a signifigant, repeatable gain I'll stand corrected)
Lowering
- If you have the money get the Mopar stage 3 coilovers. If not I really like the Hotchkis springs.
Turbo Timer
- If you want one, go for it. I personally don't use one, I always let my car cool down for a bit when I run it really hard. Most of the time, I don't worry about it.
Hard pipes or what you called
- You can replace them if you want. I wouldn't worry about it if you plan on keeping stock boost levels.
Nothing I've suggested should void your warranty, but that is ultimately up to the dealer and DCX.
skipdogg is offline   Reply With Quote
Page generated in 0.21119 seconds with 13 queries
