Old 07-03-2008, 08:35 AM   #241 (permalink)
Spoolin2.4's Avatar
Member Number: 33480
Trader Rating: (17)
Quote: Originally Posted by neonporter19018 View Post
Im Running A Turboneti Gt-k 1000 .96 A/r With A Derrel Cox Option B Motor And Pro Head With His Manifold And Throttle Body Aem Programmable Ecu Hanh Craft High Boost Injecters(2 Injector Per Cylinder) Bcstage 3 And A Bunch Of Other Stuff And Im Making 1200hp@6551rpm And 891trq@5697rpm I Spool Around 4000rpm And Have No Problem Smokin Anyone In Philly My Personal Best Time In He 1/4mile Is 8.023 @ 195mph
What was the point of this post???
I'll be heading out in acouple of weeks. I'm waiting untill i get a wot box. Like you said srt4me i'm falling out of boost everytime I shift. I'm gonna compare my logs with, and without the box and see the difference. I can't wait I was pretty good at no lift shifts so with the box I can only get better right?
Spoolin2.4 is offline   Reply With Quote
Old 07-03-2008, 09:59 AM   #242 (permalink)
srt4me18's Avatar
Member Number: 50825
Quote: Originally Posted by uncommonŠ View Post
I'm picking up an hp61 .63 a/r tonight ... if all goes as planned, I'll probably hit up the track next Wednesday & see how pointless this turbo is on a stock block/rev car
Your only gonna have like ~2000rpms or so of full boost and even with WOT shifting at 6100rpms you will fall back out of boost at the very, very least you need the ability to shift AT 6500rpms Either way tear it up crank it up to 30psi
On a .63 ar it might not be that bad, but on a .82 it would be pointless
hp61
AEM Ems, STock Head, Stock Cams, STock block
Aaronneon Tune=badass
60' 1.75
1/8 7.52@101.55
1/4 11.45@125mph
1.66 60' wasted on a 13.2@64mph
srt4me18 is offline   Reply With Quote
Old 07-03-2008, 10:03 AM   #243 (permalink)
srt4me18's Avatar
good luck, I got in some new sensors, new plugs, and gonna try to figure out what is making my car run like poop... its got to be wiring or that damn fuel pump, or something.. I dunno its really starting to piss me off
Old 07-03-2008, 02:51 PM   #244 (permalink)
ReDsRtKiD's Avatar
Member Number: 46248
Trader Rating: (10)
I have a GT35R with a .63 A/R on bone stock motor. The lag isn't THAT bad but I hit full spool at 4200RPM. The only thing is I have AEM and my redline at 6500. Even if I shift around 6100ish it doesn't fall outta boost at all. So IMO it's not pointless it's just a lil laggy.
(Old Set-up) BB .50 Trim
12.8 @ 118 Traction>Me
(New Set-up) HTA35R+EMS
11.8@114 Breaking up through 4th
60' 1.70 1/8 7.6@95
ReDsRtKiD is offline   Reply With Quote
Old 07-03-2008, 03:04 PM   #245 (permalink)
srt4me18's Avatar
1-2 shift at the track it wil fall out cause its a 2300rpm fall off on the 1-2 shift unless you have a higher rev. limit like i said
Old 07-03-2008, 03:08 PM   #246 (permalink)
Buy/Sell Section Moderator
uncommonŠ's Avatar
Member Number: 39843
Trader Rating: (131)
sounds promising ... I wouldn't mind the lag at all
I posted in AGP's section just to see, but I wanted to swap over my t04s compressor housing off my 60 trim onto the hp61 & they said I'd need a new housing (LOL, obviously) and a backplate ... which would involve complete disassembly and reassembly (pretty much a rebuild) ... now I don't understand why I couldn't just throw the t04s housing on there, unless the t04e housing is machined to fit the hp61 wheel, then it makes no sense ... the backplates for the t04e & t04s aren't compatible?
12.1 @ 125.8 mph on street tires & pump gas
uncommonŠ is offline   Reply With Quote
Old 07-03-2008, 03:13 PM   #247 (permalink)
srt4me18's Avatar
machined
Old 07-03-2008, 03:13 PM   #248 (permalink)
ReDsRtKiD's Avatar
Trader Rating: (10)
I orginally ordered a 35r t04e just to be different and see what it was like. I never put it on but sent it back to Garrett. They said all they did was swap the compressor housing from t04e to the t04s. So I'm pretty sure you can just swap housings.
EDIT: I just re-read the post and what I said has pretty much no bearing on this topic.
Old 07-03-2008, 03:20 PM   #249 (permalink)
uncommonŠ's Avatar
jesus, if it's machined then my car might be down for a couple weeks while I wait for my 60 trim to get rebuilt ... the hp61 has a 3" inlet & 2" outlet (t04e) ... my t04s has a 4" inlet for my 4" intake & a 2.5" outlet for my 2.5" coupler on my discharge pipe
I don't feel like getting a 3" intake or putting a screen on the turbo & I don't feel like getting a 2.5" to 2" coupler for the discharge pipe ... sigh
Old 07-03-2008, 04:55 PM   #250 (permalink)
2004NeonSRT4's Avatar
Member Number: 4577
Trader Rating: (31)
my built 2.4 8.5 compression with crane 14s doesnt full spool till 4k, 4100 in a .63. but revs to 7500 so its worth it. a stock rev limit or even 6500 is still pretty useless. you'll go faster on a 50trim.
400X100 for a sig pic is useless.
2004NeonSRT4 is offline   Reply With Quote
» Search Used Cars
ť Wheel & Tire Center
Page generated in 0.29140 seconds with 11 queries
