Old 10-27-2009, 08:27 PM   #1 (permalink)
Member Number: 39822
Default How much different????
I was wondering how much of a difference there is between the standard bearing 50tirm with the 48 a/r exhaust and the one with the 63 a/r exhaust?
What would be the difference in spool time's and what would be the difference in hp around let's say 20/21psi pump gas?
What kind of numbers would they put down at 20/21psi with a stock engine with just all the normal bolt-on's on pump gas?
2004 SRT-4 Precision 60-1 @ 22psi
Diablosport Predator Tuned by TDSAaron
1/4th Mile Best On Street Tires
12.4 @ 121mph 2.2 60ft
oleBLUE is offline   Reply With Quote
Old 10-27-2009, 08:35 PM   #2 (permalink)
Member Number: 33203
Trader Rating: (25)
You'll see probably 300-400 rpms of difference in full boost from the .48ar hotside to the .63ar hotside. .48ar 50 trims are badass turbo's for people content with 450ish whp or less. You'll have a great powerband, even with a stock limiter. The power isn't gonna be a huge difference between the two hotsides at that boost level either. The couple of hp lost from the smaller hotside will definitely be made up for in powerband! I'm certain you'd like it better than a 60-1
Precision 6057@30psi on pump
8.50@87 on 10psi w/2.0 60 ft (wg pressure on 30 psi tune, no 2 step)
Contact Turbo666/TDSaaron for your tuning needs.
turbojonsrt4 is offline   Reply With Quote
Old 10-27-2009, 08:37 PM   #3 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (92)
for the street id go 50t .48 ar.
AGP S256 FS
lyncoo is online now   Reply With Quote
Old 10-27-2009, 09:26 PM   #4 (permalink)
Yea i'm really thinking about the 48 a/r 50 trim. I want a faster spooling turbo than this 60-1. I have the ball bearing one and still don't hit full boost till like 4,000rpm's on the street and like 3,800rpm's on a load dyno. This 60-1 would be better for someone wanting to rev there car out but I just want to stay around 6,500rpm's or less mark. Ever since I rode in kason23's car with the delta 44 it has made me want that faster spoolup time again.lol
Old 10-27-2009, 09:37 PM   #5 (permalink)
Trader Rating: (25)
I wouldn't even say that. 60-1 was cool in 1998. There's so many better options now. Take my 6057 for example. It will support roughly 100 more whp than a 60-1 and even my journal bearing .63ar hotside 6057 hits 30psi around 3800 rpms, and I gaurantee the down low response will kill that of the bb 60-1s. Ive had two journal bearing 61mm Precisions and neither one of them would hardly build any boost down low at part throttle driving. The 6057 is 100x more responsive than either of them were.
Old 10-28-2009, 04:16 AM   #6 (permalink)
What is the 6057 rated at hp wise? Mine is the 6031 and it's rated at 590hp. You are right though low end power is not that great, it hit's ok power at the 4,000rpm's mark and that's full boost at 22psi but it don't really come alive till like 5,000/5,500rpm's. I don't understand why these smaller turbo's like the 50trim can out perform a bigger turbo like mine around the 20psi mark and lower.
Old 10-28-2009, 05:40 AM   #7 (permalink)
turbo666's Avatar
Member Number: 25206
Trader Rating: (31)
4k rpms on a dbb 50trim? That's not right. Something has to be up and effecting your spool in a negative way. I've seen plenty of standard bearing 50trims hit full boost by 34-3500rpms, and I'm talking almost 30psi by then. When I had a .48 50trim I hit 28psi at 3200rpms. Fast spool for sure, but I didn't like the topend loss. I still always recommend the .63 to anyone over the .48 for street or strip.
Another thing to remember is the AGP 50trims spool faster then your typical Turbonetics. A Turbonetics .48 50trim won't hit full boost till around 34-3500rpms.
Nigel
04 Srt-4-AGP Borg Warner S360-RS, E85, and MUCH MORE coming soon...
7.493@99.56<-- granny shifting on 30r with 93/meth <--OLD SETUP!
FIRST TO MAKE BIG TURBO PCM BOOST CONTROL WORK ON DIABLO!
For custom tuning, installs, and transmission rebuilds PM me!
www.trudynosports.com
Old 10-28-2009, 11:38 AM   #8 (permalink)
I was talking about my 60-1 at the 4k. I have the ball bearing 60-1 on right now but am looking at getting a 50trim for the faster spool and stronger powerband for around 20/22psi.
Old 10-28-2009, 11:57 AM   #9 (permalink)
So what kind of numbers will the 48 a/r 50trim put down at around 20/22psi on 93oct pump gas with a completly stock engine?
Old 10-28-2009, 12:01 PM   #10 (permalink)
ticaaal70's Avatar
Member Number: 64715
Trader Rating: (24)
Completley stock? Like even stock intake mani/throttle body? Ima have to say about 390ish
ticaaal70 is offline   Reply With Quote
Old 10-28-2009, 12:17 PM   #11 (permalink)
I have all the normal bolt-on's and I do have the stock intake manifold with a 55mm machined throttle body.
Old 10-28-2009, 05:42 PM   #12 (permalink)
ticaaal70's Avatar
Trader Rating: (24)
Yep around 380-390
Old 10-29-2009, 10:47 AM   #13 (permalink)
SRToad4's Avatar
Member Number: 61889
Visit the 50 trim turbo owners thread for info on the turbo, lots of good info in there
Tuned by Tony @ UMS Tuning
390whp/380tq @ 21.5psi / 91 + Meth
SRToad4 is offline   Reply With Quote
Old 10-29-2009, 11:11 AM   #14 (permalink)
sponsorSRT03's Avatar
Member Number: 58797
i run my 50 trim .63 a/r on the streets and there is nothing wrong with spool. i full spool around 3400-3500 rpms and its awesum. Tq w this turbo is Fnin nice. 20 psi on stock motor, u'll be fine. depending on ur tune, u'll hit high 300's. but according to other people in the 50 trim dyno thread. im doing about 380whp and im at 28psi.
but personal opinion, at least a .63 a/r, the couple hundred rpm would not make that much of a difference.
sponsorSRT03 is offline   Reply With Quote
Page generated in 0.16856 seconds with 13 queries
