| Sponsored Links | |||
Advertisement | |||
#32 (permalink) |
![]() Join Date: Oct 2003
Member Number: 4562
I did reply in the PM as well, but i figure I would explain what we did while diagnosing your setup.
-Part dimensions (turbine shaft, and turbine seal bore in CHRA) were inspected for wear, and dimensions, all were within spec. -Turbo was rebuild, and balance was verified -Turbo was run in our VSR balancer with heated, pressurized oil, with no leaking past the seal. On all accounts, with multiple checks, the turbo is good in our eyes. Possible causes of the continued smoking: -too much crank case pressure causing more oil than normal to bypass through the piston seal (very rare btw) -oil drain tube blockage causing the same (more common) -too much oil feed pressure (normally not an issue with journal bearing turbos) -you still have residual oil in the manifold and dump tube that needs to clear out -you have oil leaking from elsewhere in the system like valve stem seals or cracked ringlands causing severe blow by. Now im not sure what other testing you have completed, but I would recommend looking in other areas to ensure that your car is tip top. We did as thorough a check on the turbo as possible, and it's good brotha! Certainly keep me informed of what you find Richard! -Bob Thanks for the further diagnosis on your end Bob, its much appreciated. Every part from top to bottom in my engine is brand new and only has 450 of soft brake in driving on each component. You guys did the ported head and valves no longer than 6 months ago. I had installed the following at your shop while the head was there..... Map S3 head with Brass valve guides New valve seals Rev+1 intake +2 exhaust valves Rev dual titanium valve springs Rev retainers With.... (installed at my local machine shop were the pistons/rings and bearings)................ Bc S3 cams Arp head studs JE 8.5:1 pistons Eagle Rods Acl rod bearings Deleted balance shafts(done by my during engine assembly,yes i closed the oil port with a screw as instructed in the how to) Also I have checked the oil return line for blockage and I found no obstructions. I used a wire coat hanger and heard it go all the way down to the oil pan. Also I would like to point out this fact that, every time I simply start the engine, I can go and remove the band clamp and there will be oil in it. I mean it can run and get to normal temperature and then shut it off and then there will be oil in the band clamp. I will be doing a compression and also a leak down test on sunday. I will post the results once they are both completed. Once the engine was started after installing the turbo after I got it back form map, I would let the car warm up and idle and my autometer electrical oil pressure gauge that I have installed in the head will have a normal reading of 18-22 psi at idle. So this is where I stand. I expect good things from this sundays tests as the engine is brand new. Last edited by Ude Lose; 05-06-2012 at 11:54 AM. |
#34 (permalink) |
SRT of the Month ![]() Join Date: Feb 2007
Member Number: 50825
bent valve or turbo needs rebuild
TUNED/BUILT by REALTUNE PERFORMANCE
10.15@144 (1.61 60') Race gas 10.98@126 (1.62 60') 93 octane /low boost ![]() best 60' 1.57 Realtune "Crushing competition not bank accounts." |
#39 (permalink) |
![]() Join Date: Jun 2011
Member Number: 84907
I may be calling it the wrong thing. Pretty much the same stuff they use for A/C leaks, but made for oil. Have to use a black light to see it, and you are able to see where the leaks are coming from.
#42 (permalink) |
![]() Join Date: Jul 2005
Member Number: 31159
more and more I'm thinking valve guides and/or seals.
LIFETIME NRA MEMBER
SUPPORT THE SECOND AMMENDMENT IN ITS FULLEST I'll be out most of the year it looks like. call it a "building" year. those who need me know where and how to find me. |
#43 (permalink) |
Member Number: 4562
I sure hope not. ill be sending the turbo back down to MAP this week.I have pictures that i havent got to post yet from yesterday, showing oil on the exhaust blades of the turbo. Ill post them when i get home from work. |
#44 (permalink) |
you said there's oil in the manifold itself?
is there oil in all 4 exhaust ports on the head?
LIFETIME NRA MEMBER
#45 (permalink) |
also have you poked into the intake plumbing yet to see if there's oil there.
LIFETIME NRA MEMBER
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
