Holy SMOKES! - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 03-24-2012, 04:54 PM   #1 (permalink)
Ude Lose's Avatar
Member Number: 4562
Default Holy SMOKES!
I cant figure out why my car is smoking severely. I just built the entire engine do to the fact that it was smoking.
I drove it an hour home from where I store it and all was fine up until the last ten minutes. The car started pouring smoke out of the exhaust. I dont know what to do.
The engine build information can be found here....
Ude lose's ROTM thread February 2012
Its at the point now as to where I cant even drive the car (not that I would in this state) without creating a smoke screne behind me.
My exhaust system is as follows, Lcr S3 3.5 to 3 inch O2 housing, 3 inch dp with electric cutout, stock SRT mid section, Sxt appearance package dual tip muffler.
At first I thought that there was oil trapped in the exhaust system and it was just burning off. But at the rate this smoke is coming out, I dont think that could possibly be the culprit anymore.
I have a brand new pcv valve, a catch can, and a inline check valve.
I also replaced the oil returnline gasket today.
I thought that maybe the oil seal in the turbo was bad. So i sent it out and got the 69x upgrade from Bob at F&F.
I read that the check valves occasionally go bad, so I removed that and it still smokes. Just not as bad.
I also checked the spark plugs and they were dry. #1 was a tad bit more dirty than the rest but nothing to be worried about.
I'm totally stumped as to what is making my car smoke like a freight train.
If anybody has any ideas please let me know.
Ude Lose is offline   Reply With Quote
Old 03-24-2012, 05:29 PM   #2 (permalink)
Sota's Avatar
Member Number: 31159
you sure it's oil smoke and not coolant?
LIFETIME NRA MEMBER
SUPPORT THE SECOND AMMENDMENT IN ITS FULLEST
I'll be out most of the year it looks like. call it a "building" year. those who need me know where and how to find me.
Sota is offline   Reply With Quote
Old 03-24-2012, 05:30 PM   #3 (permalink)
Sota's Avatar
what does the turbo inlet look like? any signs of oil on the compressor?
LIFETIME NRA MEMBER
Old 03-24-2012, 06:41 PM   #4 (permalink)
TenZen's Avatar
Member Number: 84907
Kind of got the same thing, but the problem is never constant. It will do it one day, then won't do it for 2-3 weeks.
Quote: Originally Posted by brokestatus View Post
Just because I love 14 y/o girls does not make me a pedophile. It makes me an OG. Like, pilgrim status.
TenZen is offline   Reply With Quote
Old 03-24-2012, 06:42 PM   #5 (permalink)
Ude Lose's Avatar
Member Number: 4562
I'm pretty sure its oil smoke.
The turbo inlet had a drip of oil on it.
the weird thing was that the v band clamp had oil in it.
I'm sooo confused
Old 03-24-2012, 06:47 PM   #6 (permalink)
Ude Lose's Avatar
Member Number: 4562
I bought the car new in 03. If I wasn't emotionally attached I would sell it and dump the money into my evo. That thing is an animal already, I wonder what it would be like with $6k into the engine
Who am i kidding, I would never get rid of my SRT no matter how bad it pisses me off sometimes.
I also read a thread from AGP that does not recomend using a check valve at all. Especially inline with a pcv valve.
Old 03-24-2012, 06:55 PM   #7 (permalink)
Member Number: 11361
if compression is good, ~150#/cyl -- pull the turbo, i be the turbine is coated with oil
spark plugs are probably oil fouled too
Build Thread:http://www.srtforums.com/forums/f451...w-123k-612933/
PCM=S0, DSP rescaled, 3bar map/tip
injectors= Siemens 80# (ebay $200)
built motor, 8.8:1 weisco, eagle-h, strap & windage
S3R DCR manifold ($500) w/evo8 turbo (ebay $150) - 20G/47# ebay ($200)
Evo 8 WGA
24x12x4 w/cast ends - CXRacing (ebay $200)
DataLogger DataQA, $25
Wideband UEGO (ebay $150)
vette rims 275/40/17
needswing v5
SouthBend S3
fixit is offline   Reply With Quote
Old 03-24-2012, 06:56 PM   #8 (permalink)
Ude Lose's Avatar
Member Number: 4562
Just got it from Bob.
Damn, what should I tell him if it is the turbo, or how would I know?
I mean this thing is making S M O K E
Old 03-25-2012, 04:57 PM   #9 (permalink)
Ude Lose's Avatar
Member Number: 4562
I took the v band clamp off of the turbo/manifold yesterday and there was oil in it,as much oil as that little clamp can hold. I cleaned it and reinstalled.
Today the car is still smoking. I took the muffler off to see if that may have had unburnt oil in it and drove the car. Car is still smoking. I reinstalled the muffler.
I took the V band clamp off of the turbo/manifold again today. Has oil in it again.
Im no expert but I think oil is somehow getting past the turbo and getting into the manifold and creating smoke coming out of the exhaust.
This is a fresh turbo that i received from bob an F&F less than a week ago.
Basically there is oil getting past the turbo somehow.
What would you all assume the problem is?
Old 03-25-2012, 04:59 PM   #10 (permalink)
Sota's Avatar
talk to bob tomorrow.
LIFETIME NRA MEMBER
Old 03-25-2012, 05:04 PM   #11 (permalink)
Ude Lose's Avatar
Member Number: 4562
I just pmed him. /
Soo confused
Old 03-25-2012, 05:05 PM   #12 (permalink)
Member Number: 88602
i have a 04 i just bought it 2weeks ago and i thought it needed a turbo so bought a new turbo and it still smokes REALLY BAD! out of the exaust im thinking maybe my valve seals or head gasket might be bad but i dont know
dodgesrt404 is offline   Reply With Quote
Old 03-25-2012, 05:05 PM   #13 (permalink)
strokedracer05's Avatar
Member Number: 77818
Seals are probably bad but bob is the man talk to him and see what he says
new setup for 2012:Bob at form and functions new stage 3 wheel stock motor from oil pan to valve cover shooting for 10s with lots of timing and boost on racegas!!!
strokedracer05 is offline   Reply With Quote
Old 03-25-2012, 07:35 PM   #14 (permalink)
Ude Lose's Avatar
Member Number: 4562
Yeah man, I hope he takes care of me. The turbo has 50-60 miles on it the most. Never went past 8-10lbs of boost.
I have never even gone wot on my new engine build yet.
Soo disappointed, I am beginning to grow tired taking this turbo in and out of the car.
Old 03-26-2012, 08:46 PM   #15 (permalink)
Ude Lose's Avatar
Member Number: 4562
I will be sending the turbo back to Bob for a diagnosis
