High horsepower and water pump failure???? - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 11-12-2012, 05:16 PM   #1 (permalink)
silver03srt's Avatar
Member Number: 54252
Default High horsepower and water pump failure????
Just wondering if anyone else is having any sort of problems with their water pumps in high horsepower set ups.. 600+, I've now had two go out, leaking out the weep hole, trying to figure out if I just have bad luck or if anyone else is experiencing this? Not lifting the head no excessive pressure in cooling system.
Quote: Originally Posted by thatguy27 View Post
. Take it to a shop or your pistons might see jesus.
silver03srt is offline   Reply With Quote
Old 11-12-2012, 05:22 PM   #2 (permalink)
D-SRT's Avatar
Member Number: 80561
None. 3 hard years (going on 4) at north of 600+hp, with the original OEM pump.
Pumpking.
10.71@140. 1st SRT in TENS in CA.
Thanks to:
TUNED BY MINDMELT101@DRAG-ON Tuning. - http://drag-ontuning.com/blog/
GOKEY RACING for anything fabrication related
instagram for updates and pics: m_santiago37
D-SRT is offline   Reply With Quote
Old 11-12-2012, 05:53 PM   #3 (permalink)
Fresh Meat Moderator
tunerlover3's Avatar
Member Number: 76568
What kind of pump are you buying? Cause there are ones to watch out for.
Diablo CMR tuner ~Dan~
310HP 436TQ
XXXHP XXXTQ
Old 11-12-2012, 07:29 PM   #4 (permalink)
SRT of the Month
turbo666's Avatar
Member Number: 25206
I've used a Advanced Auto Parts pump on my current 700+ hp build and before on my mid 10 second stock bottom setup. Never had one fail. Sure you don't have pressure getting into coolant system and blowing it out? I've never seen blow before anything else, but just a theory.
04 SRT-4-10.18@150.3, and still a lot left in it...
Engine builds, dyno tuning, fabrication, and more available! PM me for pricing and details!
Contact me for great prices on your part needs!
http://www.facebook.com/BrutalSpeedAndTuning
Old 11-15-2012, 04:58 PM   #5 (permalink)
Yah, I'm sure there isn't anything getting in it as far as pressure wise, the cap would blow into the overflow before pump failure, just starts leaking out of the weep hole. I'm buying factory pumps. This one literally has maybe 2-300 miles on it, granted I've floored it a lot during that time, but didn't have a problem for a few thousand miles on the other one, first one was the plastic wheel one and second one was metal wheel pump. Anyone using a "performance" pump?
Old 11-15-2012, 05:16 PM   #6 (permalink)
contraption22's Avatar
Member Number: 8377
Over-tensioned timing belt?
2004 Neon SRT-4
contraption22 is offline   Reply With Quote
Old 11-15-2012, 05:17 PM   #7 (permalink)
93stang434's Avatar
Member Number: 49690
Do you have a manual timing belt tensioner?If so make sure your not putting too much tension on the belt.
Built short block,cncport.com head,BW s256
and and some other stuff=Aiming for the 10's on E85
BC co's,Hotchkiss sways,Prothane bushings,Pwerks strut bars,Mopar tension struts
93stang434 is offline   Reply With Quote
Old 11-15-2012, 07:04 PM   #8 (permalink)
Not over tensioning it, using the stock tensioner.
