Hey guys just as the title stats i have gone threw 3 count them 3 turbonectic turbos y i do not know the seals just wont sit right i am guessing dont know tho.
The turbo is a 50trim non ddb. If anyone has any idea what i should check to see what else could cause this please let me know.
MODS
stage 2
50trim non ddb
agp 3in cai
agp return line set at 43psi
BC cams
fadanza gears
ported intake mani
64 mm throttle body
turbonetics cold side pipe w/raptor bov
cti full hot side piping
side exit exhaust 3in turboback
O yeah and the turbo has never seen over 20psi PLEASE HELP
there is more mods but i dont beleive they will have anything to do with the problem
All DCR ALWAYS TUNED BY TURBOTUNE (MARK)
Mark Riley (TurboTune) 9-7-1949 - 12-4-2008 RIP and God Speed
You most likely need an oil restrictor that goes inline with the oil inlet line. It makes your 1/4" hole about 1/8" give or take so not that much oil can flow through it. When you initially start your car up it can see as high as 85psi of oil pressure. These turbos only need about 35psi to operate optimally
O4 PT Cruiser non GT
Stock b****es, come get me
i baby this car. I do go into boost but it has never seen over 20psi. What do you mean bye beat the car? Please give me an idea i am not sure what you mean bye that. If you mean am i in boost 24 7 no i am not
Quote: Originally Posted by lvlistchif
do you drive on the turbo hard? also what size is your oil feed and return line?
I have the restrictor inline already it came with the turbo from turbonetics so i dont think it is getting to much oil. any other idea
no i havent gone through 3 turbos, but stage 3 is holding up beautifully, that may be an option.
went that way once had it been there done that i also had the 20g and i said it was time to go a little bigger so i did. I should have maybe stayed with the 20g or the s3r
im goin stage 3 after i fucked with forwardmotioninc.com the worst turbo company ive ever fucked with. Ill never mess with these bullshit shit endors again.
beemer,benz or bently,...nissan,honda,chevy, damnit meet me at the getty cause my dodge is always ready.
everyone has been saying bov does anyone know what the raptor bov should sound like is it a flutter when not in high boost or is it a quick release no flutter can some one let me know
Hasn't Turbonetics done a failure analysis on the bad turbos? You need to get with them to find out what the outcome of that analysis was.
I had a problem with heat coking the oil before it could get to the journal bearing and that would cause my seals to go out from the massive shaft play. The problem was solved when Turbonetics rebuilt my turbo with a water cooled center section.
Wes
'03 Solar Yellow
400hp/371tq @ 23psi
12.3@119.71 mph (Best trap 122.05) DRs SIR (3100ft)
