hahn 20g setup - Dodge SRT Forum
post #1 of 15 (permalink) Old 02-26-2009, 04:48 PM Thread Starter
Quoted: 0 Post(s)
hahn 20g setup
i am planning on doing a hahn 20g setup on my srt4 and i have some questions about which supporting mods should be used with the turbo.an srt owner told me that he would reccomend running a stage 2 without toys.i am not sure if he meant all of the components or just the injectors.i am planning on going with a dsp and an aem wideband.i will most likely be running a denso supra fuel pump.i also dont know if i should leave the wastegate that comes with the 20g or use an agp one.i also want to know if i should run pcm controlled boost or wastegate since i am will be using a dsp.what else would you guys reccomend?this is my daily driver so i am also looking for driveability.
thanks
zerosrt4 is offline
post #2 of 15 (permalink) Old 02-28-2009, 07:26 PM Thread Starter
Quoted: 0 Post(s)
anyone?
zerosrt4 is offline
post #3 of 15 (permalink) Old 02-28-2009, 08:01 PM
tgspeedracer's Avatar
Quoted: 0 Post(s)
yes run stage two without toys and you will be happy. you want all of stage two, it allows you to run more boost, and get more power out of the kit
Best ET 11.41
Best MPH 131
@5860ft elevation
Peak whp 567
tgspeedracer is offline
post #4 of 15 (permalink) Old 02-28-2009, 08:11 PM
nutz's Avatar
Quoted: 0 Post(s)
the 20g will top out at about 24-25 psi (26 is pushing it) @ about 135,000 rpm of shaft speed, the turbo is very efficient so timing can be raised slightly, as for a stage 2 i guess thats OK but the timing sux on a stage 2 (does well on a clamped stg 0) if you are doing a diablo tune i guess you could work in some timing ???????? but most 400++ numbers are on stg 1 or stg 0 clamped w/ portfueler or w/safc
nutz is offline
post #5 of 15 (permalink) Old 03-01-2009, 12:22 PM Thread Starter
Quoted: 0 Post(s)
thanks guys.is there any hp numbers for a 20g running s2 w/o toys?i am planning on making the drive to rage tek once i have everything on the car so i can get it tuned since i am in florida.
zerosrt4 is offline
post #6 of 15 (permalink) Old 03-01-2009, 12:23 PM Thread Starter
Quoted: 0 Post(s)
which wastegate should i use?s2,agp or the one that comes on the 20g?
zerosrt4 is offline
post #7 of 15 (permalink) Old 03-01-2009, 06:35 PM
nutz's Avatar
Quoted: 0 Post(s)
hahn uses a different type of WGA, so i would use the one provided untill you can upgrade to the hahn HP or mod for an agp
nutz is offline
post #8 of 15 (permalink) Old 03-01-2009, 06:37 PM
nutz's Avatar
Quoted: 0 Post(s)
my guess is you wont hit more than 320 without a way to manage timing (safc/dsp/sct) but it should still be fast and spool good just wont be able to max out
nutz is offline
post #9 of 15 (permalink) Old 03-01-2009, 08:14 PM
Quoted: 0 Post(s)
sig vvvv
stage2,safc2,DSP,Garret 60-1,Hahn mani,atp 3"o2,QTP 3" dp w/dump, 4" sri,ported IM/TB,ED "beast" fmic,AGP/Turbonetics hp's, Whalbro255,AGP rL kit, RC 750's, CM w/m injection, 180 therm., catch cans,Granitelli wires, NGK plugs, AGP wga,Gizmo ebc, "raptor" bov, mm inserts,WR torque damper, Spec stage3clutch/flyweel, b/s chain cut, PLX wideband, Autometer(boost45psi,volts,oil)scanguage, NDE TSC box
---whp,---wtq
vcious is offline
post #10 of 15 (permalink) Old 03-02-2009, 11:02 AM Thread Starter
Quoted: 0 Post(s)
well i plan on already having the dsp purchased long before i put the turbo on.once i do,i will have rage tek do a nice tune with my dsp.i just think since i am close to them i should have them tune my dsp as opposed to me trying to play tuner
zerosrt4 is offline
post #11 of 15 (permalink) Old 03-02-2009, 11:05 AM Thread Starter
Quoted: 0 Post(s)
Originally Posted by vcious View Post
sig vvvv
real nice numbers on a safc2.are those numbers on pump or race gas?
zerosrt4 is offline
post #12 of 15 (permalink) Old 03-02-2009, 12:59 PM
Quoted: 0 Post(s)
93pump/100%meth/28psi=lots a fun
vcious is offline
post #13 of 15 (permalink) Old 03-05-2009, 06:11 PM Thread Starter
Quoted: 0 Post(s)
what do you guys think of running a full 3 inch side exit?i have one in the garage.its a 3 inch ptp dp catless and a 3 inch pipe.no resonators
zerosrt4 is offline
post #14 of 15 (permalink) Old 03-05-2009, 06:26 PM
nutz's Avatar
Quoted: 0 Post(s)
sig vvvv
what injectors and how much map were you pulling w/ the safc
BTW , nice #'s that thing is about maxed
nutz is offline
post #15 of 15 (permalink) Old 03-05-2009, 10:36 PM
Quoted: 0 Post(s)
750's and was pullin alot. was in the mid 20's i tkink, but the meth took care of any knock i had from extra timming.
and thats why i dont have it in my car anymore.
vcious is offline
User Tag List
Linear Mode Linear Mode
