Old 11-29-2008, 01:49 PM   #1 (permalink)
supermech21's Avatar
Member Number: 42969
Trader Rating: (72)
Default Guess these rods????
Heres a couple pics of some rods i bought...one for my build another for a spare back up...Theres really only one pic that you can see a visible difference in the strength of these rods:
Different oiling holes for the pins? I guess? The one on the left has 2 sets of holes, one on the right just one on top.
Teh future
Old 11-29-2008, 01:52 PM   #2 (permalink)
DDogsrt461BLK 3.0's Avatar
Member Number: 32500
pauter & eagle
DDogsrt461BLK 3.0 is offline   Reply With Quote
Old 11-29-2008, 01:53 PM   #3 (permalink)
cuda340's Avatar
Member Number: 24886
Trader Rating: (30)
Okay...the one on the left is a Pauter and the one on the right is either an Eagle or BC rod
Powered by
HATED...
cuda340 is offline   Reply With Quote
Old 11-29-2008, 02:27 PM   #4 (permalink)
Trader Rating: (72)
well damn.
Old 11-29-2008, 02:32 PM   #5 (permalink)
cuda340's Avatar
Trader Rating: (30)
Quote: Originally Posted by supermech21 View Post
well damn.
LMAO....what??? If you wanted to stump someone you shoulda asked who makes your tubular mani. I've never seen one like that...
Old 11-29-2008, 02:48 PM   #6 (permalink)
Trader Rating: (72)
cti...he does good work
Old 11-29-2008, 02:58 PM   #7 (permalink)
what I don't understand is why the stock rod has no oil feed hole for the wrist pin, the only hole is down off the connecting rod rides on the crank, but yet every other after rod does?
Old 11-29-2008, 03:14 PM   #8 (permalink)
cuda340's Avatar
Trader Rating: (30)
If I remember correctly the stock rods use a pressed pin. The aftermarket ones are all bushed and use a bronze bushing which need to be lubed to prevent wear.
Old 11-29-2008, 11:59 PM   #9 (permalink)
chuck's_srt-4's Avatar
Member Number: 12569
Nope! Stock rods are bushed and use a full floating pin with spiral locks as well!
MY FAVORITE EQUATIONS:
Fuel Volume = (HP * BSFC) / (# of injectors * IDC)
CFM = C.I.D. * RPM * V.E. *.5 / 1728
P.R. = (PSI Boost + 14.7) / 14.7
HP = TQ * RPM / 5252
chuck's_srt-4 is online now   Reply With Quote
Old 11-30-2008, 12:01 AM   #10 (permalink)
cuda340's Avatar
Trader Rating: (30)
LOL, it's been a long time since I've seen a stock rod/piston...
Old 12-01-2008, 05:39 PM   #11 (permalink)
duster360's Avatar
Member Number: 45182
As far as stress concentration analysis around the pin is concerned, the one with only 1 oil hole will be much stronger than the one with two. I don't know about the rest of the rod, but around the pin it will be stronger.
The rod with 2 oil holes puts them right in the middle of a very high stress point in the rod. VERY BAD! Mopar Performance has recomended against putting pin oil hols in this location on the rod for at least 40 years.
With a constant spray of cool oil, I seriously doubt the pin will be lacking oil without an oil hole. Most engines don't have piston oil squirters so aftermarket rod manufactures simple put pin oil holes in all thier rods.
Page generated in 0.16583 seconds with 13 queries
