Old 09-08-2006, 03:04 PM   #31 (permalink)
Mike_Blue_RT's Avatar
Member Number: 26089
Approximately how much does a GT35R full set-up (EVERYTHING) cost? Sorry if this is off topic.
-Mike
-Mopar Stage 3 and other various aftermarket performance enhancing modifications.
Mike_Blue_RT is offline   Reply With Quote
Old 09-08-2006, 07:16 PM   #32 (permalink)
ayoungblood's Avatar
Member Number: 7132
Trader Rating: (30)
-Mike
Everything???
Well if you wanna use a GT35r, you wanna run 550whp+ So...
Built motor - 3 grand
Trans stuff - 800
Turbo kit - 2500
All bolt ons - 2000
Custom fuel system - 500
BS..... Another 1 or 2G
So total just under 10 grand....
2k4 Srt-4 -- Stock
TONS of parts for sale!! (Three threads worth!)
ayoungblood is offline   Reply With Quote
Old 09-08-2006, 10:16 PM   #33 (permalink)
-Mike
Everything???
Trans stuff - 800
Turbo kit - 2500
All bolt ons - 2000
THANK YOU . . . FINALLY THE INFO I WAS LOOKING FOR AND NO BS . . . YOU ARE THE MAN
Old 09-08-2006, 11:48 PM   #34 (permalink)
LucyBop's Avatar
Member Number: 9095
Quote: Originally Posted by phucough
Quote: Originally Posted by Maj Dump
Here's Ultimate Racing's GT35R .82ar
Check out their post regarding everything done.
Stock cat back exhaust
Thats pretty sad considering I made 450/475@24lbs on a Turbonetics Ceramic ball bearing 50trim
And at 24 psi your 50 trim is about to take a shit, while this turbo made 440 at 20 psi and is barely breathing and will run as high as 35psi.
Good try though.
Absolutely false! You are right about them not being a comparison though. That GT35R will obviously outshine the 50 on higher boost since it is alot bigger.
I think it outshines a 50trim even on lower boost levels...
Having had both turbos, my GT35R would walk my 50trim setup at 20psi, 22psi, 24psi, 30psi, ect...
In fact the 35R at 22psi and C16 feels as strong as what my 50trim at 30psi did with this exception, the 50trim you can feel it run out of steam towards redline, begging to be shifted, where the 35R pulls hard and strong all the way to redline with no noticable drop off in power, this thing just slams you in the seat and pulls and torque steers like a runaway freight train.
However, this isn't a fair comparision, because the 35R is on a fully built engine, where as when I had the 50trim I was on a stock engine.
You look at many of the 50trim dyno graphs floating around here you will notice after this turbo hits its peak power numbers, it tends to drop off rather significantly by the time it hits redline, and you don't see this with a 35R, notice my 50trim graph:
This is the highest HP we got out of the 50trim, boost was 30psi, notice you will see HP drop and TQ plummet towards redline.
Now observe the GT35R chart, HP holds steady and TQ falls alittle but not at the rate of the 50trim... GT35R chart was at 35 - 38 psi? Boost guage only goes upto 30...
When we were dynoing, the GT35R held HP/TQ at lower boost levels all the way to redline.
Now don't misunderstand me, as I love the 50trim and I have 1st hand experience with it, it can be quite potent and strong on pump gas, but the GT35R is simply a stronger and meaner and a more violent snail, this thing loves higher boost and C16! But I will also add even with pure pump and a mere 17 - 18 psi, the GT35R is still a tough out, atleast on my car.
637hp/596tq!!
LucyBop is offline   Reply With Quote
Old 09-09-2006, 12:26 AM   #35 (permalink)
Member Number: 12194
If you can run 20psi on pump... C16 wouldn't add anymore power.
ChrisUlrich is offline   Reply With Quote
Old 09-09-2006, 01:04 AM   #36 (permalink)
LucyBop's Avatar
Member Number: 9095
You might think so, but not the case with my car, it just loves C16 at low boost, mid boost, high boost.....
It just loves it...
I typically run a mixture of pump and C16 for low boost, and I do notice the car not running or even idling as great as the mixture shifts or dulutes to pump gas...
Now the car still runs quite strong on pure pump, but she sure does perform better with C16.... I think she is addicted to the stuff...
Old 09-09-2006, 01:29 AM   #37 (permalink)
Member Number: 19937
Trader Rating: (37)
As you said though Lucy, it's not really a far comparison because the 35R is on a built engine, but l understand what you're saying.
dubgunit is offline   Reply With Quote
Old 09-09-2006, 01:45 PM   #38 (permalink)
Racerxvsspeedracer's Avatar
Member Number: 32196
Trader Rating: (15)
It just loves it...
What are the track time's for both of these set up's? You were in the 11's with the 50 trim right? What does the 35r run at the track thanks.
A853 CREW (ONLY UNO)Project TRAIN DONE!11/13/09 F&FPorted E/M Agp RACE Bfmic Agp uhp+hks
Ported Stock turbo,Stock Head, Stock cams
329.69Hp, 395.77Tq STD 297Hp@6K
320.87Hp, 385.18Tq SAE E-85 CORN FED BABY!
Racerxvsspeedracer is offline   Reply With Quote
Old 09-09-2006, 02:10 PM   #39 (permalink)
Limey's Avatar
Member Number: 37526
I'm intrested too in the track times. I am building a motor and going to add the gt35r kit from AMS.My goal is to shoot for the 700HP mark.
I would love to see and vids of lucybop's car.Do you have any floating around?
Limey is offline   Reply With Quote
Old 09-11-2006, 03:45 PM   #40 (permalink)
Why would higher octane add hp if you're not detonating? But even at that point you're not adding horsepower... just getting it back since the detonation makes the knock sensor go nuts and retards timing a bunch.
Octane isn't a power adder
Old 09-11-2006, 03:46 PM   #41 (permalink)
According to several people... 700whp is a stretch for the GT35r. GT42r would be a wiser choice for 700whp
Old 09-11-2006, 07:19 PM   #42 (permalink)
Lucille's Avatar
Member Number: 11138
I never claimed Octane is a power adder, nor is my car detonating...
It simply runs better with VP's fuel and loves it, whether that makes sense to you or not it doesn't matter much to me at this point.
636hp, 596ft tq
Lucille is offline   Reply With Quote
Old 09-12-2006, 11:30 AM   #43 (permalink)
KeyboardCommando's Avatar
Member Number: 38988
Trader Rating: (15)
Aboslutely not man... A GT42R won't even FIT on the back of the car so why recommend it? An AGP HP66 is more like it...which is also compareable to the GT37R...thats IF your going for 700whp...
KeyboardCommando is offline   Reply With Quote
Old 09-12-2006, 02:07 PM   #44 (permalink)
Member Number: 3175
Trader Rating: (41)
Absolutely not man... A GT42R won't even FIT on the back of the car so why recommend it? An AGP HP66 is more like it...which is also compareable to the GT37R...thats IF your going for 700whp...
yup...as it is a T67 set-up has only 1/4" left clearance at the firewall...the gt42r comp house would need to share already being used real-estate!
anyone know of a gt37r set-up being run in a srt4?
curious to know
thx
jersturbo is offline   Reply With Quote
Old 09-12-2006, 02:25 PM   #45 (permalink)
Trader Rating: (15)
curious to know
thx
4U2NV is using the GT37R on the full AMS turbo kit but his car is STILL at AMS because they can't figure out the 6200? rpm breakup on the AEM EMS...
Page generated in 0.15549 seconds with 13 queries
