Old 05-20-2006, 02:08 PM   #16 (permalink)
MoparbeastSRT4's Avatar
Member Number: 32388
WOW, Great #'s
http://www.cardomain.com/ride/2098862/1
Power Mods
Mopar Stage 1|Mopar CatBack|NWs V5 DP|AGP WG+PTP's spring|Greddy TT|Profec B Spec II|MPx FMIC|AEM SRI|AEM UEGO|Scan Gauge|ED Pipes+HKS BOV|MSD SPW+NGK@.32|MM Inserts|WeaponR CC|PTP's 75 FPR Mod, MAPTIP Clamp, Cooling Kit, Check Valve|
Quote: Originally Posted by yeah
My srt is possessed with deamons.
MoparbeastSRT4 is offline   Reply With Quote
Old 05-20-2006, 02:18 PM   #17 (permalink)
wannasupra's Avatar
Member Number: 32741
come on lucy, where's the vids?
A new lease on life...
Old 05-23-2006, 09:41 PM   #18 (permalink)
Member Number: 12194
I am seeing/hearing all sorts of max boost numbers for the GT35r. AMS said it got maxed out at 30, someone else made their dyno at 35, and my friend who's into SRT4s says it's 40! Which one is it!
ChrisUlrich is offline   Reply With Quote
Old 05-23-2006, 10:15 PM   #19 (permalink)
Maj Dump's Avatar
Member Number: 18866
Here's Ultimate Racing's GT35R .82ar
Check out their post regarding everything done.
Stock cat back exhaust
Life is what happens while you're making other plans.
2004 Dodge SRT-4 Silver - Bone stock
1983 Ford F100 step side - Ford 460 7.6L
Maj Dump is offline   Reply With Quote
Old 06-12-2006, 10:23 AM   #20 (permalink)
ayoungblood's Avatar
Member Number: 7132
Trader Rating: (30)
Depends what A/R.
I have a .63, ill prib push mine as high as 30-32.
A .83 35-37
A 1.06 prob will goto 40 but not spool till ~ 4500 on the stock 2.4
2k4 Srt-4 -- Stock
TONS of parts for sale!! (Three threads worth!)
ayoungblood is offline   Reply With Quote
Old 07-01-2006, 05:59 PM   #21 (permalink)
Member Number: 39007
636 to the floor? What kinda times is that putting down?! What kind of traps?!
13.0 @ 145 If I had to guess. hahaha. Those are some sick mods though, im green with envy.
JMB
Red 04, t04z, meth, spray, crane 18's
639hp/649 tq
RarB!tch is offline   Reply With Quote
Old 09-03-2006, 01:05 PM   #22 (permalink)
Member Number: 29336
Trader Rating: (50)
Thats pretty sad considering I made 450/475@24lbs on a Turbonetics Ceramic ball bearing 50trim
phucough is offline   Reply With Quote
Old 09-03-2006, 01:07 PM   #23 (permalink)
Member Number: 27506
at what boost did u make that power? and are you on the stock exhaust
DGR8srt is offline   Reply With Quote
Old 09-03-2006, 06:26 PM   #24 (permalink)
Member Number: 7132
Trader Rating: (30)
And at 24 psi your 50 trim is about to take a shit, while this turbo made 440 at 20 psi and is barely breathing and will run as high as 35psi.
Good try though.
Old 09-03-2006, 06:31 PM   #25 (permalink)
^^ i thinking the same thing....why would u even consider comparing?
Old 09-03-2006, 10:33 PM   #26 (permalink)
Member Number: 19937
Trader Rating: (37)
Good try though.
Absolutely false! You are right about them not being a comparison though. That GT35R will obviously outshine the 50 on higher boost since it is alot bigger.
dubgunit is offline   Reply With Quote
Old 09-04-2006, 02:56 AM   #27 (permalink)
srt4moster's Avatar
Member Number: 24528
when would a gt35r with a .63 a/r spool?
srt4moster is offline   Reply With Quote
Old 09-04-2006, 01:50 PM   #28 (permalink)
Member Number: 7132
Trader Rating: (30)
Thats what I have and I love it.
Starts to make power at around 3600 and full boost ~3800-3900, its so hard to tell because once boost hits it blows the tire off.
Old 09-07-2006, 11:34 AM   #29 (permalink)
Whats the projected trap speed at Sea Level with a GT3582r at full boost on a built top end? Figuring 650whp
Well... my buddies GT35r makes full boost at 4k... why did you go with the smaller a/r?
Old 09-07-2006, 07:42 PM   #30 (permalink)
Member Number: 7132
Trader Rating: (30)
Ill still be able to push 32lbs on this .63 a/r. I figured I want that 300rpms rather than an extra 40 or 50 horse.... 600 vs 650.
Prob high 10, low 11 @ ~130
Page generated in 0.16189 seconds with 13 queries
