Old 09-11-2007, 08:59 PM   #166 (permalink)
canadian_made_srt-4's Avatar
Member Number: 22368
Trader Rating: (33)
ya the car acted way different on the dyno after we found the leak.
My tuner is super confident we can get a 500-525WHP out of it after the exhaust and 2 more psi.
From 18psi -22psi we gained almost 22WHP per PSI at 20psi we made 408WHP so two more psi gained me 45WHP !
so say 25hp from the exhaust thats 478WHP then 2psi at the same rate of power gain as the last time we would be around 523WHP.
THATS ALL ON PUMP GAS
this was also on a dyna pak dyno which reads 10% lower then the dyno jet dyno. I'm sure if we straped it to a dyno jet the way it is we would be over 500WHP already but I rather use the same dyno every time so I can see what effect the changers I have made have on the graph.
In the end a dyno is a tuning tool and the number I put down at the track are what you can brag about.
543WHP HIGHEST WHP PUMP GAS SRT-4 IN CANADA Parts for sale http://www.srtforums.com/forums/f293...6/#post7038270
canadian_made_srt-4 is offline   Reply With Quote
Old 09-13-2007, 12:23 AM   #167 (permalink)
Member Number: 32177
Trader Rating: (12)
im thinkin about sellin my big wheel stg3 and gettin the AMS Gt35r and a AEM EMS, im doin my head over the winter do you all think this would be a good setup, im only lookin for 500hp or so.....thanks
Stock and 4 SALE!
blknite22 is offline   Reply With Quote
Old 09-13-2007, 07:24 AM   #168 (permalink)
Member Number: 55210
Trader Rating: (13)
I was in the debate between the dbb 50trim and the gt35r...if you looking for 500 "max" hp I would go with the 50trim but if you looking for 500hp on pump i'd go with the 35r...
K Rock 12 is offline   Reply With Quote
Old 09-13-2007, 10:12 AM   #169 (permalink)
Member Number: 28960
Trader Rating: (25)
isnt your bottom end built? if so, then it would be an awesome setup...you really need a built setup to get the most out of the 35r...
-wes
2005 srt4
2002 rsx-s
1992 tsi awd
1990 "project gsx"
1963 GMC Truck "slownlow"
jwcardy is offline   Reply With Quote
Old 09-13-2007, 11:18 AM   #170 (permalink)
Trader Rating: (12)
-wes
nope im on stock bottom end and stock head...but like i said ill be doin the head this winter and sellin my BW Stg3 so, i have a buddy with a AMS Evo and another byddy who just took off his 35r his evo and he made 550 stock motor so thats where i was wantin to go lmk
Old 09-18-2007, 10:22 PM   #171 (permalink)
Trader Rating: (25)
ahhh shiat
Old 10-14-2007, 06:16 PM   #172 (permalink)
d_fl8ted1's Avatar
Member Number: 11549
Trader Rating: (81)
ok this winter i am going to the 35r setup.... i have a built engine except for the head.... which will also be done this winter by ams with port polish, valve job and bigger valves...... and the aem ems.......with 1000cc injectors... so here are some questions i have for the 35r owners....
1. how much boost on pump gas? race gas?
2. What power/torque with pump gas with tune should i expect? i dynoed 444 on my current setup with my 50 trim...
3. How much power/torque on race gas with the 8.8 to 1 wiseco pistons...??
I am trying to get this car into the 10s.... i ran 11.83 on pump gas this year with a terrible run.... i am now in the mid 11s
any info would be good and greatly appreciated....
On the 8th day GOD created drag racing
d_fl8ted1 is offline   Reply With Quote
Old 10-14-2007, 07:08 PM   #173 (permalink)
Trader Rating: (33)
on 94oct pump gas 22psi I made 512whp 489wtq
with 21psi boost, 94oct fuel and the stock cat back I only made 453whp.
mods
mod list
Built engine .020 over
DCR race pistons
Eagle rods
knife edged crank
Calico bearings
Johnson crank scraper & windage tray
DCR oil pump
P&P head
Crane 16's fidanza cam gears
Ti springs, retainers and lifters
DCR head studs
DCR oil mod
P&P intake mani
DCR 55mm TB and spacer
Boomba intake spacer
MSD 1000cc
-6an fuel lines
Boomba rail
Walboro 255 modded
AEM EMS
GT35R turbo
Equal length mani
3'' dump
Tail 38mm WG
DCR PS2 clutch
Bwoody CC
custom 4'' intake
Old 10-14-2007, 07:59 PM   #174 (permalink)
Blue05SRT's Avatar
Member Number: 18209
I just had a buddy of mine dyno 442whp at 24 psi on a bone stock block and head. Just supporting mods and an AEM. I'll try to get some dyno sheets up.
"Celebrities walk on red carpet because they are famous, I walk on toilet paper because i'm the shit"
*MY SPACE*
http://www.myspace.com/chickenpattysrt
Blue05SRT is offline   Reply With Quote
Old 10-18-2007, 02:24 PM   #175 (permalink)
Trader Rating: (13)
A few weeks ago I blew two stock pistons on my gt3071 setup, however just got done building the block and dropped in a 35r with a .63 a/r..I was looking to run 20psi pump and 30 race gas with 750cc and many supporting mods an was hoping for around 500-550hp on 30psi...tuning with aem ems
Old 10-19-2007, 05:10 PM   #176 (permalink)
ReDsRtKiD's Avatar
Member Number: 46248
Where you at in jersey?
I don't know but I THINK 30 psi is too high for 750's on a 35r. If not does anyone know about where 750's max on a 35r?
New Set-up comin' soon..
6/11/08-5/07/09 91pumpking
ReDsRtKiD is offline   Reply With Quote
Old 10-19-2007, 09:25 PM   #177 (permalink)
Trader Rating: (33)
I think the 750's are going to cap out around the 550whp mark I believe I'm running 1000's. What is going in the car for a fuel pump cause I know the walboro with run out of fuel before you will reach the max on the 750's.
30psi on race gas with a 35R and a built motor should make over 600whp.
Old 10-20-2007, 09:27 PM   #178 (permalink)
Trader Rating: (13)
I live down in middletown however im always in union so...
Old 12-27-2007, 03:19 PM   #179 (permalink)
Member Number: 35555
Do any of you guys have some track time and more importantly Mph and vehicle weights on these GT35R's? Would give a clear picture then dyno numbers which can be off alot from one dyno to another.
1997 Talon (3350Lbs with Driver)
10.6 @142Mph on 18's
No Nitrous
Daily Driver
Revolution is offline   Reply With Quote
Old 01-17-2008, 03:04 PM   #180 (permalink)
Trader Rating: (13)
Would rc 750's, a return line kit, and a bottleneck fix on a walbro 255 be enough supporting fuel for 35psi?? Or should I through in the 1200's??
Page generated in 0.32160 seconds with 13 queries
