so im seeing numbers way higher than 380whp...are the stock bottom ends holding up with a proper tune? im getting the 3076 and hope to hit 400-450whp, plan to do bottom end work but if i can run with those numbers without it i will for a little bit.
the QW fmic flows about as good as a coffee stir in a milkshake...
Everyone says this, but I am yet to see any numbers on it. During the IC shootout they did on here, the QW was not included. I do not have the QW, but I think I have the same one. I have the XS power sold through, Unorthodoc Motor sports here on the forums.
GT3076R, and everything to make it work. Full suspension set up. Still looking for more!
Hey guys. Looks like all of you are putting up huge numbers. Thats great. I am getting my car dynoed in 2 days. It is going to be done at Dyno4mance, and going to get a tune by macellero's performance. My numbers will read low due to the dyno they are using. I forgot the type, but it it suppose to read 13-17% lower than a dynojet. I am expecting this, so I am expecting pretty low numbers. I was hoping for high 300's, but on this dyno, I am expecting low 300's. Here is what I have.
psi-fi motor mounts top/bottom
ngk iridium plugs, one step colder
injen ses 8022 3" cat black exhaust
injen 3" downpipe (no cat)
P Werks Grounding Kit
Mopar Stage One Kit
Magnecor spark plug wires
Boomba Intake Gasket
RPM 62MM Throttle Body & 62mm Spcr
Hallman Manual Boost controller
Uncommon Motorsports Large FMIC (XS power on top)
Bwoody Traction Bar and H-Bar combo
AGP GT3076R Build Kit
Apexi SAFC 2
RC 750's
Samco Silicon Radiator Hoses
AGP 3" Cold Air Intake
AGP LHP and UHP
HKS SSQV
Walboro 255 lph fuel pump
modern performance 8 T-Bolt clamps
Auto Meter 30 psi boost Gauge
PTP Check Valve
NGK Wideband O2 sensor
I tried to erase most things that wouldn't matter, as I have a ton more. Mostly suspension, stereo, and cosmetic. I am at 21-22lbs of boost. on 225's, it seemed no better traction wise than the 205's, oh well. Wish me luck! I will be back Saturday night with numbers.
does anybody know the silicone diameter between the turbo and the hotside pipe? this is for a 3076r
Good question, whats the length it should be as well? The one I have on is icorrect. It is to long, accompanied by a long story, lol. Bump for the answer
where did you get that Bwoody Traction Bar and H-Bar combo iridefast? im gonna need them when I get my 3076 on.
I bought it awhile back when B-Woody had a group buy on them. Several people are selling them now, and I even saw a thread in the group buy area for a christmas deal on them, But did not check the price
the diameter is 2". ben from agp just told me. how long does the tube need to be. mine just doesn't sit right.
see, but I think it is a 2" to 2.5" reducer because I think the hotside pipe if a bit wider. I know mine has a reducer on it for sure, but I had to attach 2, which made it to long. That is my problem, but need to find the right sizes, before I buy a new one
well the lower pipe is 2" from the that one hump you needed to leave when cutting it. then it expands to 2 1/2" to the intercooler. at least i think that works. i know i just need to rotate my turbo for a better fit. no big deal
Was not a good day. Things got worse on the way home. Also, I have never boost leak tested the car with the all new setup, I am having a hard time making a 4" boost leak tester that fits in the small area. You guys have any recommendations?
