Old 07-10-2008, 08:22 AM   #676 (permalink)
$PK$'s Avatar
Member Number: 47676
I just had my GT3076R installed and tuned by Jannetty Racing.
401whp 419wtq
3076R, 625s, returnline, SCT Flash tune FTW!
401whp 419wtq on pump gas tuned by Jannetty Racing Enterprise
$PK$ is offline   Reply With Quote
Old 07-10-2008, 08:30 AM   #677 (permalink)
vcious's Avatar
Member Number: 50913
nice. psi? any meth or straight pump?
stage2,Hahn s20g kit, QTP 3" dp w/dump, 3" sri, ED "beast" fmic,agp/turbonetics hp's, whalbro255, agp rL kit, RC 750's, CM w/m injection, 180 therm., catch cans, msd wires/coil, ngk plugs, agp wga,Hallman mbc, "raptor" bov, mm inserts, weapon-r torque damper(stiffy), spec stage3clutch/flyweel, b/s chain cut, s-afc II, PLX wideband,T-XS knock light, autometer(boost30psi,water,volts)A.F.scanguage pro, NDE TSC box
406whp, 425wtq
vcious is offline   Reply With Quote
Old 07-10-2008, 11:16 AM   #678 (permalink)
$PK$'s Avatar
Running 25psi dropping to 23psi, with some meth on pump.
Old 07-15-2008, 04:09 AM   #679 (permalink)
Member Number: 47553
my wastegate was leaking and my dump pipe (bad gaskets )oh yeah also leaking bov
i had it tune at ums tuning in arizona i only got charge $50 because of the leaks but i really need to find some one who tunes aem ums(just got it) in socal that really knows what his doing
357hp 357tg at 17psi ( i was trying to boost 24psi but drop to 17)
my hp try's going up but couldn't
thesrt-4thatcould is offline   Reply With Quote
Old 07-15-2008, 04:03 PM   #680 (permalink)
srt4me18's Avatar
Member Number: 50825
My boost does not drop off at all Make the drive to ohio Aaronneon FTW.... tons of 125mph passes on 25psi
hp61
AEM Ems, STock Head, Stock Cams, STock block
Aaronneon Tune=badass
60' 1.75
1/8 7.52@101.55
1/4 11.45@125mph
1.66 60' wasted on a 13.2@64mph
srt4me18 is offline   Reply With Quote
Old 07-15-2008, 04:20 PM   #681 (permalink)
matthew00029's Avatar
Member Number: 46349
Who has the highest HP using the 30r? Whoever you are I'm coming for that title...TRUE 2.6L stroker, Race ported head, AEM EMS, Meth, pautowerks stage 3 tranny and of course AGP 30r kit. Shooting for mid to high 500's. Anyone think I will hit it?
05 Black SRT-4 ACR:
DCR True 2.6l stroker
AMM Race ported Head
Pautowerks S3 Tranny
Mopar S3R Coilovers
AEM EMS
AGP 3076HTA........Looking for 10's
matthew00029 is offline   Reply With Quote
Old 07-15-2008, 04:36 PM   #682 (permalink)
srt4me18's Avatar
low 500's sounds doable!!! good luck.. Pretty sure >> Cant stop spinning has the fastest at 11.2@128 or something like that..
Old 07-15-2008, 04:39 PM   #683 (permalink)
No HIGH 500's is my goal. I forgot it has a custom compressor wheel so this ain't no regular gt30. I am shooting to take his time down as well. I want tens with my build. I know its harder to do than talk but thats my main goal...10's.
Old 07-16-2008, 04:32 PM   #684 (permalink)
1fastSRT's Avatar
Member Number: 11053
Trader Rating: (23)
what wheel u running? Ive been thinking about sending mine to ForcedPerformance to get the wheel upgraded myself to the 57lb
1fastSRT is online now   Reply With Quote
Old 07-16-2008, 05:24 PM   #685 (permalink)
2K4SRT_4's Avatar
Member Number: 13287
Trader Rating: (28)
thats what he did. upgraded it through force performance.
Rageteks DNP manifold for my GT3076r. This should be fun.
Turbonetic EWG forsell $150 shipped
GT35 T04S compressor housing. $200 shipped
Water-Methanol Nozzle size caculator
2K4SRT_4 is offline   Reply With Quote
Old 07-16-2008, 10:54 PM   #686 (permalink)
can't stop spinning's Avatar
Member Number: 9183
quickest et is 11.291 @125.94 with some spark blowout in 4th that run
highest trap is 130.32, with numerous 128-130 mph traps
halfvipr was the first to crack the 130mph barrier, but I believe he had crane 16 or 18's, and possibly a built head.
100% stock engine, stock head, cams, blah blah blah
1st srt in Canada to get kicked off the track
can't stop spinning is offline   Reply With Quote
Old 07-17-2008, 09:57 AM   #687 (permalink)
Member Number: 64760
Trader Rating: (10)
if you change out the wheel to a totally different compressor mapping/size...then what makes it a 30r? because it has a 4" cover?...
DRASTIC.
91PumpKing. is online now   Reply With Quote
Old 07-17-2008, 10:16 AM   #688 (permalink)
Is a big wheel stage 3 still a stage 3....YES!!!!! Why would this be any different? Oh ya I forgot you know everything.
Old 07-17-2008, 10:21 AM   #689 (permalink)
$PK$'s Avatar
Dude, you could call a big wheel stage 3 a stage 3, but really its not a stage 3 anymore. If you take out the main thing that makes the 3076r a 3076r and change it, its not a true 3076r anymore.
Not hating on the idea (well maybe a little after my expirience with big wheel stage 3s/fucking up efficiency,spool,power,everything), good luck with it and I would really like to see the #s. But for the record, it s no longer a GT3076R.
Old 07-17-2008, 10:31 AM   #690 (permalink)
Ya its not a true 30r but its still a 30r. Its actually called the 3076hta for record. I know what your saying but doesn't the turbo itself mar it a 30r? Not just the compressor wheel? Everything else is untouched. Ill agree its not a true 30r but still is the same turbo.
