Old 05-01-2008, 08:22 PM   #631 (permalink)
dbowling's Avatar
Member Number: 61677
You should break 400hp, but I don't know if you want to on 91. How about some water/meth injection? It might be ok, but I'm not sure
Backed by:[IMG][/IMG]
dbowling is offline   Reply With Quote
Old 05-01-2008, 08:54 PM   #632 (permalink)
matthew00029's Avatar
Member Number: 46349
Quote: Originally Posted by 2K4SRT_4 View Post
where did you get the FP 30r upgraded wheel?
Go to the group buy section, than go the forced performance, who is selling the 47lb stage 3's and go to their site. than look around the site at the FP turbos and you will see the GT30HTA and GT35HTA. both upgraded wheels. hope it made sense and helps...
With 8:1 pistons, 20psi, and low timing do you think 400 is possible in other words. I hope thats safe enough on just pump. on meth/pump I want 450hp and 25psi....
05 Black SRT-4 ACR: Looks stock
matthew00029 is offline   Reply With Quote
Old 05-02-2008, 03:17 PM   #633 (permalink)
Bwap's Avatar
Member Number: 42762
Finally got my AMS kit in. Everything goes in monday and I should have before and after dyno sheets posted up by thursday or so
Bwap is offline   Reply With Quote
Old 05-03-2008, 12:13 AM   #634 (permalink)
Mrcho's Avatar
Member Number: 40069
Im starting to install all my parts tomorrow.
I hope everything goes well. I wont be able to run it past 12psi as I didnt receive the AGP SCT Reflash yet...
2008: GT3076R + SCT + Nitrous = 2 spare axles & 11s...
2007: Stock turbo + S2 + Nitrous = 12.50 1/4
Mrcho is offline   Reply With Quote
Old 05-03-2008, 09:31 AM   #635 (permalink)
dbowling's Avatar
Good luck, look forward to hearing how it goes.
Old 05-03-2008, 09:36 AM   #636 (permalink)
dbowling's Avatar
The machine shop is the only thing holding up my build right now. My head is done, but my bottom end has yet to go into the shop. We are waiting on another guys bottom end which should have allready come out of the shop so that the block that is in his car right now can go into the shop and become mine. I am definitely getting anxious.
Old 05-03-2008, 11:16 AM   #637 (permalink)
can't stop spinning's Avatar
Member Number: 9183
No dyno sheet, but I did trap 130.32mph last night with my 3076. That's with the stock head/cams and block
100% stock engine, stock head, cams, blah blah blah
1st srt in Canada to get kicked off the track
can't stop spinning is offline   Reply With Quote
Old 05-03-2008, 11:29 AM   #638 (permalink)
dbowling's Avatar
Nice trap! ET?
Old 05-03-2008, 11:30 AM   #639 (permalink)
dbowling's Avatar
sorry, I'm blind. I see it in your sig now
Old 05-03-2008, 03:57 PM   #640 (permalink)
1fastSRT's Avatar
Member Number: 11053
Trader Rating: (23)
Heres mine on 20psi, 93 pump, w/i off, SCT tuned
Not sure whats up with the dip since I wasnt around when my car was tuned but it really doesnt matter since this is just a daily tune,very safe afr's and low timing from what they told me. I do know it was enough for me to pull a car length from 40-150 from the new Yamaha R6
[IMG][/IMG]
1fastSRT is offline   Reply With Quote
Old 05-03-2008, 04:11 PM   #641 (permalink)
dbowling's Avatar
Lookin' good 1fastSRT. All these dyno numbers and track times are really making me antsy to get my car back.
Old 05-04-2008, 12:10 AM   #642 (permalink)
Member Number: 9183
actually I only ran a 11.7 yesterday. I couldn't get any traction. I was spinning all the way through 2nd
Old 05-04-2008, 02:26 PM   #643 (permalink)
Mrcho's Avatar
Working on the car here.
Balance chain removed, ARP head studs + dcr washers and nuts installed, cross member removed, stock turbo manifold o2 housing wga removed, intake manifold removed for porting and tb install, dcr coolant tank installed... still have a long way to go .... we have to make an o2 housing ourselves, this may take some time .. I cant even install the damn turbo yet because Im missing an exhaust manifold gasket, Its ordered but wont get in until Tuesday...
Old 05-22-2008, 10:36 AM   #644 (permalink)
Justin_w's Avatar
Member Number: 36253
Default plugs gapped at?
Hey guys what gapping are you running on your plugs?
MODS: GT3076R Turbo Kit,Cooling Mist Alky Kit,MPB TBE,MPX throttle Body,MPX Front mount Intercooler,ATP uppipe w/ Turbo XS BOV,MSD Wires, DCR Top End Oil Mod, AGP Dogbones, Pt Stage 3 Clutch, AGP Intake, Torbonetics Wastegate,Exhaust Depo Charge Pipe,B-Woody H brace and traction bars. BC Full Coilovers, AEM True Boost/wideband,Madd dog STS. DC front and rear strut bars, 180 T-stat, Stage 1 ECU, Ported F & F mani
Justin_w is offline   Reply With Quote
Old 05-22-2008, 07:24 PM   #645 (permalink)
TurboMoparGod's Avatar
Member Number: 33697
Trader Rating: (29)
[IMG][/IMG]
Looks like 3800rpm full spool?
www.ForwardMotioninc.com
Sales@ForwardMotioninc.com
Stock turbo 12.82@107mph DR's
E1 Turbo 12.48@115mph DR's slipping stock clutch
E3 Turbo and new FM clutch XX@XXX
TurboMoparGod is offline   Reply With Quote
