Old 01-13-2007, 09:38 AM   #181 (permalink)
2K4SRT_4's Avatar
Member Number: 13287
Trader Rating: (28)
I would say it find a hardware store and see if you can get a sub for it.
Rageteks DNP manifold for my GT3076r. This should be fun.
Turbonetic EWG forsell $150 shipped
GT35 T04S compressor housing. $200 shipped
Water-Methanol Nozzle size caculator
2K4SRT_4 is offline   Reply With Quote
Old 01-13-2007, 07:15 PM   #182 (permalink)
UsmcSrt4's Avatar
Member Number: 39607
went to advance auto and got one, got everythign in now except for the oil lines, ran out of daylight. also i justt hought of something and forgot to look, is there a hole for the O2 sensor or do i have to tap one in?
Mods
Screamin Demon Coil,MSD 8.5mm Wires,NGK Plugs,Tein S-Techs,ACT 6 Puck,Boomba Fuel Rail,750cc Injectors,Turbo XS Type RFL BOV,AGP FMIC,AGP Polished Catchcan, 3" Turbo Back Exhaust,ATP UHP,Aeromotive Fuel Return w/ FPR,160 degree thermostat,AFC Neo,Polished AGP GT3076R Kit - Best run 12.9 (untuned and bad night) Tein S-Techs http://www.cardomain.com/ride/2578807
UsmcSrt4 is offline   Reply With Quote
Old 01-13-2007, 08:03 PM   #183 (permalink)
Member Number: 18254
I have A GT3076R on my car at it has a E compressor and its has a 3 inch inlet and instead of 4 inch. The exhaust side has an 82 AR with 2 1/2 inch outlet it starts to make boost it 1400 rpm and is hitting 12 pounds of boost at 3400 rpm. My car has not been dyno with this turbo yet but soon.
Turbo Tony is offline   Reply With Quote
Old 01-14-2007, 08:16 AM   #184 (permalink)
KeyboardCommando's Avatar
Member Number: 38988
Trader Rating: (15)
for the STOCK o2 there should be one already drilled on there... for a WIDEBAND o2 you'll probably have to drill one unless you had a place either install it or you installed it already or got an exhaust option with a 2nd bung for later with a plug to block it off till you got your wideband in...
To all mods: These boards are overly cluster fucked. you hear me? theres too much bullshit on all the sides...
KeyboardCommando is offline   Reply With Quote
Old 01-14-2007, 08:18 AM   #185 (permalink)
Trader Rating: (15)
GT3076R wit ha 3" cover? I've NEVER heard of that before...........the ONLY GT3076R turbo's that i've EVER seen are either
A.) 4" inlet w/port shroud compressor housing or...
B.) 4" inlet WIHOUT port shroud compressor housing... (this is what my turbo is)
However the GT3071R has a 3" compressor cover...
Old 01-14-2007, 08:24 AM   #186 (permalink)
2K4SRT_4's Avatar
Trader Rating: (28)
i wanted to say something. but didn't want to end up being stupid. I also thought a E compressor is on a t3/t4 turbo housing?
Old 01-14-2007, 06:19 PM   #187 (permalink)
I am trying to be nice here. There are options that you don't know about. I assure you. A real garrett performance dealer can help you .
Old 01-14-2007, 07:35 PM   #188 (permalink)
2K4SRT_4's Avatar
Trader Rating: (28)
well i know i wasn't being mean when i called it. just pointing out the strange.
Old 01-14-2007, 07:48 PM   #189 (permalink)
2K4SRT_4's Avatar
Trader Rating: (28)
AGP is a real garrett performance dealer and that is not one of there option for this turbo. where did you get you kit from?
Old 01-15-2007, 05:15 AM   #190 (permalink)
I just checked garrets website and AGP is not a performance dealer. I am 100% sure that AGP makes turbo kits and high performance parts. A lot of garrets options are not advertised and you physically have to call them. Just to let you know before you call that ATP only deals with select turbos. Tial does not sell to the public and I have never called limit engineering. Since precision turbo lost their performance dealer title I used turbos direct.
Old 01-15-2007, 05:19 AM   #191 (permalink)
http://www.turbobygarrett.com/turbob...tributors.html[/u]
I hope this helps
Old 01-15-2007, 07:42 AM   #192 (permalink)
2K4SRT_4's Avatar
Trader Rating: (28)
http://www.atpturbo.com/Merchant2/me...egory_Code=GRT
(I know you went to turbo direct.)so basically you got one of the option on this which is the T04E. Right?
Old 01-15-2007, 08:49 AM   #193 (permalink)
I am not for sure but it said something like this E-60-1 or E-61 the writing is on the back of the compressor where you can't see it. I would have to call and check on it.
Old 01-15-2007, 11:49 AM   #194 (permalink)
I would like to know who has stage 2 with a return line fuel pump. I would like to know how many pounds a boost are they getting with stage 2 injectors before upgrading. GT3076 cars only
Old 01-15-2007, 01:31 PM   #195 (permalink)
2K4SRT_4's Avatar
Trader Rating: (28)
well i have a S2 pcm with returnline. and boosting 24psi. with the S2's i think you can get 15psi max. not sure. but i think that is the farthest you should go on those injectors.
