Old 05-28-2006, 08:45 AM   #1 (permalink)
KeyboardCommando's Avatar
Member Number: 38988
Trader Rating: (15)
Default GT3076R Turbo Owners? Post dynos and setups here!
I see a lot of people with the GT3076R over the GT3071R. This is the place to post up your mods, dyno charts, dynos and videos of the GT3076R !!!
KeyboardCommando is offline   Reply With Quote
Old 05-28-2006, 08:43 PM   #2 (permalink)
blew x u's Avatar
Member Number: 34069
Trader Rating: (60)
with no sheet to back it up i'm sure there will be haters but I put 451hp 472ftlb on 93 octane @24 psi mods are alot, obviosly 3076R, bottle neck fix, 255, boomba rail, rc 750,s agp returnline, safcII, HKS bov, ed hard pipes, 60mm billit tb and spacer, AGP race fmic, hallman icbc, msd coil, magnacore wires steo colder iridiums, 3" turbo back w/ aero turbine and dump, jmb ultimate intake, tmw short throw, agp motor and tranny mounts, eibach coil overs, centerforce clutch, fan mod, 180 therm.,
I orderd 2 days ago crane 14's/fidanza cam gears, bottom end rebuild w/ je 8.5:1 eagle rods..., dcr 5 layer head gasket custom oil pick up tube/ big oil kit, boomba intake mani gasket.
471hp 521tq street tune best et 11.4 @ 128 1.906 60ft. "BONE STOCK" fast women and hot cars yeahhhh!!!
blew x u is offline   Reply With Quote
Old 05-29-2006, 01:15 AM   #3 (permalink)
Trader Rating: (15)
iiiiiinteresting..........I have every mod (same mod different company) minus the TB...kit to be put on next week and retuned
Keep your signature clean. Do not curse in your signature. Next time it will be a vacation time.
Edited by Peteblksrt4.
Old 05-29-2006, 06:49 AM   #4 (permalink)
MASSSRT's Avatar
Member Number: 23778
That sounds believeable to me
nice numbers, oh and turbo by the way LOL
11.60 @ 129.8
LIFTING, NO BURNOUT, FULL INTERIOR
MASSSRT is offline   Reply With Quote
Old 05-29-2006, 09:04 AM   #5 (permalink)
Trader Rating: (15)
I think this should get a sticky. Theres a lot of 3076R users. Just look in the 3076R sticky...everyone talked about this turbo over what Nivo wanted... Now this will keep thte 3076R guys out of the 3071R sticky...if they sticky this that is...
Old 05-29-2006, 12:09 PM   #6 (permalink)
2K4SRT_4's Avatar
Member Number: 13287
Trader Rating: (30)
i have a GT3076r. i don't have number yet. but i will be running 22 psi with AGP's racing ic, Lozenros TB w/spacer and fuel rail, RC750 cc injectors, MSD coilpack and wires with 2 step colder plugs, Aaron neon returnline, AGP uppipe with HKS, W/I injection (M5) 50/50 mix, no intake just HKS on the turbo, DTEC FCBC with wideband, B&B downpipe with custom side exit exhaust. i think that is it. not sure if i am missing anything.
U N D I S P U T E D
The best engine in the world is the vagina, it takes any size piston, its self lubricating, starts with 1 finger, and every 4 weeks does its own oil change. It's just a pity the management system is so fucking temperamental.
2K4SRT_4 is offline   Reply With Quote
Old 05-30-2006, 10:52 PM   #7 (permalink)
Member Number: 14328
with no sheet to back it up i'm sure there will be haters but I put 451hp 472ftlb on 93 octane @24 psi mods are alot, obviosly 3076R, bottle neck fix, 255, boomba rail, rc 750,s agp returnline, safcII, HKS bov, ed hard pipes, 60mm billit tb and spacer, hallman icbc, msd coil, magnacore wires steo colder iridiums, 3" turbo back w/ aero turbine and dump, jmb ultimate intake, tmw short throw, agp motor and tranny mounts, eibach coil overs, centerforce clutch, fan mod, 180 therm.,
Whose turbo kit do you have?
AMS GT35r kit
DCR 1200 cc/Boomba Fuel rail/Walbro 255/Realtune return
Maxxfab SEE no cat or res (Ignorant)
/AEM EMS/DCR Spark Plugs/Granatelli Spark Wires
AGP MM/Traction Bars/Mopar S3R coilovers/Hotchikis Sway , ACT 6 puck
catch can, DCR Oil Flow Mod
AGP Race FMIC
Gold Axis Reverbs 17 x 7.5
LeadPipe is offline   Reply With Quote
Old 05-31-2006, 06:10 PM   #8 (permalink)
2K4SRT_4's Avatar
Trader Rating: (30)
AGP turbo kit here
Old 05-31-2006, 06:16 PM   #9 (permalink)
Member Number: 10600
Trader Rating: (66)
setup:
Kinetic 3076r Kit
dtec fcbc
rc750cc injectors
walboro 255
bottleneck fix
nemo fuel rail w/ -6 feed and return lines
rage tek ported head
crane 0016 cams and valve springs
fidanza gears
dcr head gasket
dcr head studs
dcr oil pump w/ billet gear and upgraded pickup tube assembly
dcr windage tray
xtremeboost thermal coated pistons
total seal rings
clevite main/calico rod bearings
agp cai
devilsown water injcetion
cti fmic
cti ic pipes
bdj 3'' exhaust w/ magnaflow muffler
agp mm's
dyno #s coming soon.....
Jeff@Slowboy is offline   Reply With Quote
Old 05-31-2006, 08:41 PM   #10 (permalink)
Member Number: 25135
Quote: Originally Posted by jeffb006
setup:
Kinetic 3076r Kit
dtec fcbc
rc750cc injectors
walboro 255
bottleneck fix
fidanza gears
dcr head gasket
dcr head studs
dcr windage tray
total seal rings
agp cai
cti fmic
cti ic pipes
agp mm's
richyc is offline   Reply With Quote
Old 06-01-2006, 11:05 AM   #11 (permalink)
Trader Rating: (15)
setup:
Kinetic 3076r Kit
dtec fcbc
rc750cc injectors
walboro 255
bottleneck fix
fidanza gears
dcr head gasket
dcr head studs
dcr windage tray
total seal rings
agp cai
cti fmic
cti ic pipes
agp mm's
maxed out turbo I see
Old 06-01-2006, 09:40 PM   #12 (permalink)
blew x u's Avatar
Trader Rating: (60)
AGP sorry so belated
Old 06-05-2006, 09:09 PM   #13 (permalink)
cybr's Avatar
Member Number: 31841
Trader Rating: (40)
GT3076r kit, tuned bad to begin with, bad compression on engine... That's why it spooled laaate
Family time Got 50/50 with my kids, couldn't be happier. Good luck in all your endeavors.
Mad Props to PFI, RX, and Kevin Warren!!!
http://myspace.com/cybr
cybr is offline   Reply With Quote
Old 06-05-2006, 10:05 PM   #14 (permalink)
Member Number: 7206
GT3076r
255lph fuel pump
750cc injectors
mpx 3" exhaust
custom 4" intake
iceman tb
msd coil..plugs
quickwipps fmic
hks bov
apexi afc
425hp ...tq conservative tune
11.60@120.64 mph on old slicks
mods: what mods.
SRT4BeatinUrV8 is offline   Reply With Quote
Old 06-06-2006, 10:02 AM   #15 (permalink)
Trader Rating: (15)
Quote: Originally Posted by SRT4BeatinUrV8
GT3076r
255lph fuel pump
750cc injectors
mpx 3" exhaust
custom 4" intake
iceman tb
msd coil..plugs
quickwipps fmic
hks bov
apexi afc
PM me where you are in Illinois... Anyway...with that QW fmic...if you were to swap that out for a REAL fmic you WOULD see even MORE POWER without changing a single setting
