Grinding noise when starting car - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 12-07-2012, 03:30 AM   #1 (permalink)
HUB SRT's Avatar
Member Number: 70890
Default Grinding noise when starting car
Just rebuilt the whole car these past four months. Car has been running fine except for occasionally hearing a grinding noise from under the intake manifold when I start the car. I feel it's the starter. Seems to be happening when it disengages (too slow). This is a brand new starter too. Does anyone know what would cause this or if its even the starter causing it?
Also, the ebrake light came on while driving, but the ebrake isn't engage. Any ideas?
Thanks!!!
2005 SRT-4
HUB SRT is offline   Reply With Quote
Old 12-07-2012, 05:50 AM   #2 (permalink)
Member Number: 37506
ebrake means your low on brake fluid. as far as your grinding? i would remove the starter and check to make sure it looks ok and installed properly also peek into the clutch window and see if a foreign object might be in there.
Vapochill is offline   Reply With Quote
Old 12-07-2012, 06:00 AM   #3 (permalink)
Member Number: 11361
sounds like a starter, easy fix
don't keep grinding it, might knock off a fly wheel tooth.. and that's a big job
fixit is offline   Reply With Quote
Old 12-07-2012, 12:36 PM   #4 (permalink)
InsoOmniak's Avatar
Member Number: 91440
if ebrake light comes on when not engaged it's probably cause you're low on brake fluid
'04 NSRT-4
'03 SVT Cobra
InsoOmniak is offline   Reply With Quote
Old 12-07-2012, 12:52 PM   #5 (permalink)
Johnmalicki's Avatar
Member Number: 88548
Had the same grinding issue on one of my cars.
It had the issue you described, it wouldn't disengage quickly or all the way.
Swapped it out one morning, problem solved.
Johnmalicki is offline   Reply With Quote
