Old 10-29-2009, 03:13 PM   #1 (permalink)
Member Number: 53240
Default Great Compression!!!!<<....
well today i gave my 05 srt4 with 59k a compression test..motor was at operating temp..held the throttle open aswell..i got 168 across all 4!!..and 160 across all 4 with throttle closed..im real happy with the results..
60ft.2.1 (street tires)
mph:101.54
sri,s2kit,tbe,fm.wga,sts,act clutch,wb,scangauge,30/30 boost gauge,hks bov,ed charge pipe,solid mounts.
Killasrt444 is offline   Reply With Quote
Old 10-29-2009, 07:55 PM   #2 (permalink)
what kinda compression r u guys getting when ur cars were at 59k?
Old 10-29-2009, 08:03 PM   #3 (permalink)
conroy9940's Avatar
Member Number: 46401
Trader Rating: (114)
last i checked i was at around 145 around 60k, im at 85k now and replacing the motor soon (not that i need to jsut don't feel like ruining a block)
Pittsburgh Penguins 14-8-0 28 points
Old 10-29-2009, 08:28 PM   #4 (permalink)
really only 145 across at 60k??..my car has always been stock turbo,and now im running 19psi with the fm wga the last 5 k..were u runnign alot of power for a long time?
Old 10-30-2009, 09:49 AM   #5 (permalink)
04blusrt_4's Avatar
Member Number: 60369
I have beat the living shit out of my car with stock, stage 3, and now D55 power and had 165 across all 4 about a month ago at 55k miles.
Stock turbo (290/330) at 24psi spike down to 16 - 15k miles
Stage 3 (377/425) at 27psi spike down to 22 - 13k miles
D55 (447/446) at 27psi - 10k miles
Tuning owns compression
*NE 400 Club*
Old 10-30-2009, 02:00 PM   #6 (permalink)
nice man!!..these motors r really built well!
Old 10-30-2009, 02:08 PM   #7 (permalink)
true..im guessing u keep up real good with the matience like i do..
Old 10-31-2009, 02:47 AM   #8 (permalink)
Xx_R/T_xX's Avatar
Member Number: 18749
50k on mine..167 all 4..like 04blue said,if ur tune is solid and isnt all over the place,ur motor will last u
BIG TURBO!
Xx_R/T_xX is online now   Reply With Quote
Old 10-31-2009, 02:49 AM   #9 (permalink)
Member Number: 30696
i was getting 165 until the day the head gasket went :-D
amdguy is offline   Reply With Quote
Old 11-05-2009, 09:46 AM   #10 (permalink)
Member Number: 18939
I replaced my rings and HG at 45k since I had to pull the pistons to change the bearings and am currently running 170 across all four with 62k on the motor (17k on the rings).
2004 Flame Red SRT-4 - 14.298 @ 95.5 - Stock
K&N Filter, DCR Oil Mod, Chargepipe Mod, DIY Hotside Pipe, In-Car Bleed Valve, 180º T-Stat, Prothane MM Inserts.
PM me if you are in the market for Guitars, Drums, Recording equipment, Etc for the SRTForums discount!
Fast420A is offline   Reply With Quote
Old 11-05-2009, 04:52 PM   #11 (permalink)
Member Number: 75469
Ok so my srt-4 that I just bought about a month ago showed 140 across the board. Car has 53k on it. Am I losing compression or do I have low compression aftermarket pistons that I dont even know about?
Turbonetics .50/.63, Turbonetics Evolution WG, Wiseco Pistons 8.8:1, Eagle H beams, Clevite bearings, PSi Fi Solid mounts, AEM CAI, BWoody Check valves, RC 750s, Custom Return Line, Custom oil catch, AGP exhaust manifold, 3" custom turbo back, custom MBC, Innovate LC-1, DSP, Turbo XS BOV, 25psi
LinkLow is offline   Reply With Quote
Old 11-06-2009, 08:23 AM   #12 (permalink)
04blusrt_4's Avatar
Gas pedal to the floor when you did that? Motor somewhat warm?
Old 11-06-2009, 10:28 AM   #13 (permalink)
yes and yes...my guess is rings...I'm sure the car saw abuse from the previous owner
Old 11-06-2009, 11:49 AM   #14 (permalink)
well bad commpression can be bad intake/exhaust valve's or piston rings..and the last thing would be the head gasket..but thats rare
Old 11-06-2009, 12:00 PM   #15 (permalink)
I will start with a leakdown test and go from there. Might as well replace everything that could be a possible problem while I have it torn apart. I appreciate the help
Page generated in 0.17733 seconds with 13 queries
