Garrett T3/T4E 50 / 57 / 60 trim? - Dodge SRT Forum
post #1 of 14 (permalink) Old 10-24-2007, 03:05 PM Thread Starter
Quoted: 0 Post(s)
I hear most people talking about 50trim. I have knowledge about what it is. But I have yet to hear a comparison between these three. I can't really search for it because it's only double digits and i bleieve the search requires a minimum of three. So how much more laggy would the 60trim be compared to the 50trim. .63ar in all.
60 trim:
COMPRESSOR SPECS:
flow: 53 lbs/min 678cfm
.60 A/R HOUSING
60 TRIM WHEEL
TURBINE SPECS:
.63 A/R HOUSING
STAGE 3 WHEEL
oil lubricated centersection.
supportable of 475whp!
57 trim:
COMPRESSOR SPECS:
.60 A/R HOUSING
60 TRIM WHEEL
TURBINE SPECS:
.63 A/R HOUSING
STAGE 3 WHEEL
supportable of 500whp!
50 trim:
COMPRESSOR SPECS:
flow: 46 lbs/min 588cfm
50 TRIM WHEEL
TURBINE SPECS:
.63 A/R HOUSING
STAGE 3 WHEEL
supportable of 450whp!
AGP 50 trim, which one comes with the kit? 50 trim turbo, 76 trim Stage 3 turbine wheel ?...I'm all lost now...
rans04srt4 is offline
post #2 of 14 (permalink) Old 10-24-2007, 03:09 PM
contraption22's Avatar
Quoted: 2 Post(s)
What are your power goals?
2004 Neon SRT-4
contraption22 is offline
post #3 of 14 (permalink) Old 10-24-2007, 03:12 PM
Quoted: 0 Post(s)
in a general manner, a 50trim will make more power and utilize a better powerband in moderate boost compared to the 57/60trim. they just arent as efficient (especially the 60trim on stock rev limit)
not to say they dont get the job done...there is a guy on here running 11.5 on a 57trim and is getting faster and faster each weekend.
if all you're really doing is moderate boost (20-24) and using the stock rev, a 50trim would be your best bet.
christian? is offline
post #4 of 14 (permalink) Old 10-24-2007, 03:16 PM
bpsrt4's Avatar
Quoted: 0 Post(s)
Yeah but Tim's car =
bpsrt4 is offline
post #5 of 14 (permalink) Old 10-24-2007, 03:23 PM
Quoted: 0 Post(s)
never said it wasnt. i can plaster a bunch of pink giant dildos all over my car, and it still is no contest w/ tim's.
not that i have a bunch of giant pink dildos or anything tho.
post #6 of 14 (permalink) Old 10-24-2007, 03:26 PM
bpsrt4's Avatar
Quoted: 0 Post(s)
bpsrt4 is offline
post #7 of 14 (permalink) Old 10-24-2007, 04:24 PM Thread Starter
Quoted: 0 Post(s)
No power goals, Just want to have some fun on the highway....going to add it to S2 and boost 12-15psi depending on AFR. Not even going to clamp or tune it with an AFC. The last time I had a mapclamp on the car, it caused some problems and ever since i took it off, problems went away. I want enough air for A/F ratio to be in the 11s and not dip into 10s near redline, thats why i was thinking about the bigger turbo. (Is that only logical thinking and not actual)
post #8 of 14 (permalink) Old 10-24-2007, 06:49 PM
bpsrt4's Avatar
Quoted: 0 Post(s)
at those boost levels your not going to be making all that much power...those turbos aren't in there efficiency range until 20+ psi
at that amount of boost you'll be struggling with bolt on stock turbo srt's
I would get an safc if you want to save money...don't forget a wideband...stage 2 injectors should be good to at least 350whp
bpsrt4 is offline
post #9 of 14 (permalink) Old 10-25-2007, 12:07 AM
Quoted: 0 Post(s)
troof.
a 12-15psi big turbo will get womped on by a tuned stocker at 21.
what problems did you incur w/ that ptp mapclamp i sold u a while back rans?
and i hope you mean 350hp w/ s2inj AND a returnline. i ran out of injector at around 290-310hp w/ no returnline.
post #10 of 14 (permalink) Old 10-25-2007, 12:14 PM
Quoted: 2 Post(s)
Going by what your goals are, I would recommend an E1 or E2. No need to go with a T3/T4 if you want to stay within S2 fuel supply. If you want room to grow, the 50 tirm (or better yet, Super50)is the best match to our engines.
2004 Neon SRT-4
post #11 of 14 (permalink) Old 10-25-2007, 12:57 PM
New Member
Jon@AGP's Avatar
Quoted: 0 Post(s)
60-trims tend to surge under load, so we don't have that turbo as an option anymore on our website with a turbo kit (if you really want a 60-trim I can still build them though). A 60-trim compressor will flow similarly to a GT3076R.
A good way to describe a 57-trim is being a less efficient 50-trim. The 57-trim won't make much more than about 450-460hp when completely tapped out, but will spool about the same as a 50-trim.
We have been using the 50-trim for years and found to be the best combination on pump gas in terms of spool and power delivery.
Jon@AGP is offline
post #12 of 14 (permalink) Old 10-25-2007, 04:28 PM Thread Starter
Quoted: 0 Post(s)
Thanks for the info Jon. I was under the impression that a biger turbo ie, 57trim or 60trim would be pushing more air near redline versus a 50trim. Therefore A/F ratio won't dip too low @ say 5.5k to redline. (yes i know this is why we have tuning devices to take fuel away) But since I wasn't planning on getting bigger injectors (have S2) (not planning on making 400hp for the need of 650s or 750s) I was thinking I could add a bigger tubo, sacrafice spool time and have a semi decent fuel curve (still running rich, but not in the 10s) without using a piggyback. If it'll have a nice power cruve and hit 330hp I'll be happy. I know I can spend more money and do it right...make 400+hp blah blah blah, but I was only planning on keeping the car for 2 more years MAX.
post #13 of 14 (permalink) Old 10-25-2007, 09:50 PM
Quoted: 0 Post(s)
all you're looking for is 330?
get an sst or e1.
one of these weekends if you arent busy, meet up w/ me and mana4real.
he has an e1 on s2inj w/ stock mani/02, while im full bolt ons, custom mani, etc.
these big wheel stockers are fun, and seem to be what you're looking for (
hp wise)
post #14 of 14 (permalink) Old 10-25-2007, 10:35 PM
New Member
Jon@AGP's Avatar
Quoted: 0 Post(s)
You are doing it somewhat backwards.
You don't want to size a turbo solely to offset the need to run a piggyback. When ANY injector that is different than what the PCM is calibrated for is being used you want to use a piggyback.
Jon@AGP is offline
User Tag List
Linear Mode Linear Mode
