Faster spooling turbo than the Garrett dbb 3076 - Page 3 - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 01-04-2013, 11:39 PM   #31 (permalink)
SRT of the Month
2011 Calendar Car
1LAPSRT's Avatar
Member Number: 38267
What's funny about that Dyno session too is that we drove the car through almost 90 minutes of Houston traffic to get to FWD from MPx, and it only sat about 10-15 minutes before pulling it onto the Dyno. No trailer/Dyno queen here!
Modern Performance SRT4 - Dominating the road race community for over 5 years!
2012 MPx SRT4 Racing and Event schedule:
http://www.srtforums.com/forums/f77/...2012-a-627265/
Old 01-04-2013, 11:43 PM   #32 (permalink)
SRT of the Month
2011 Calendar Car
1LAPSRT's Avatar
Quote: Originally Posted by D-SRT View Post
With that tq curve, I believe it. Are you able to utilize all that power, and put it down on your tire setup, or was this just a dyno only run?
The crazy thing is...you could easily run 32-35psi...and maybe not have much steam left hp wise, but the tq would be ridiculous.
Running the 275/35/18 Hankook RS3 we are able to handle a lot of that power, but my boost box really keeps it in check until I get into the higher gears...
This is my street and track tune. No changes needed... other than common sense when on the street.
The Garrett engineer told me the same about the boost level. Still on 3 bars for now and no real need to turn it up anyway.
Old 01-04-2013, 11:43 PM   #33 (permalink)
Racerxvsspeedracer's Avatar
Member Number: 32196
~59-60lb/min compressor side, with a gt35r turbine wheel...
Not a chance it will make 750hp... GTX3582, or HTA3582 will, on complete kill mode.
It's not what the GTX says... Each turbo is 1 step up from the last. Just looks at Douge GTX3071 Hp.
Garrett GTX3576R AU$1,969.00 (including 10 % G803714-5001S
Specifications:
Ball bearing Oil & water cooled 680hp-750hp Compressor wheel is 11 full-blade design Forged, fully-machined Billet compressor wheel featuring next-generation GTX aerodynamics 0.60a/r Compressor Housing (Surge Slotted) 4" Compressor Inlet 2.0" Compressor Outlet These units are sold without a turbine housing, unless an option is selected from the drop down menu below. Please note there are various Garrett Housings available utilizing internal and external wastegate.
And good to see you back!
17x8 245/40/17 ST40 BBK Project TRAIN DONE!11/13/09
04 -E-85 Ported Stock Turbo,Stock cams&Head,Stock Motor,Safc Neo
329.69Hp, 395.77Tq STD 297Hp@6K 320.87Hp, 385.18Tq SAE
WTB Locked DSP,Built 5speed,SCT Prp
Racerxvsspeedracer is offline   Reply With Quote
Old 01-05-2013, 12:00 AM   #34 (permalink)
D-SRT's Avatar
Member Number: 80561
Specifications:
Thanks for the welcome back.
I'll have to look around and see what people are doing number wise with billet 76's..
3576 would be a 35r turbine wheel with a 3076's compressor wheel in traditional terms.
FP rates their HTA3076 at 59lb/min. Now that I look at it, their inducer is 54.8mm. The GTX3076 is a 57mm...so rating is probably in the neighborhood of mid 61-63lb.
With the larger 35r turbine, might be able to eek out an extra few hp to boost that # up.
You may be right, and maybe it'll do 750...but my guess is the stars would have to align, run bookoo boost, and have perfect conditions, lol.
Either way, I'm sure it'd be a bad ass turbo.
Pumpking.
10.71@140. 1st SRT in TENS in CA.
Thanks to:
TUNED BY MINDMELT101@DRAG-ON Tuning. - http://drag-ontuning.com/blog/
GOKEY RACING for anything fabrication related
instagram for updates and pics: m_santiago37
D-SRT is offline   Reply With Quote
Old 01-05-2013, 10:01 AM   #35 (permalink)
myteluze's Avatar
Member Number: 82927
FUCK man I'm going to need a new clutch.
Myte Luze ACR Build Thread
My Facebook Page
findlecn@cvn69.navy.mil
Quote: Originally Posted by jay05acr View Post
No paper ass gaskets at work and trust me Home Depot bathrooms are no bueno LOL, had to go home early FUCK YOU TACO BELL
myteluze is offline   Reply With Quote
Old 01-05-2013, 10:15 AM   #36 (permalink)
myteluze's Avatar
Hey Doug, what headgasket do you use?
My Facebook Page
Old 01-05-2013, 10:50 AM   #37 (permalink)
Member Number: 91562
Quote: Originally Posted by loroku View Post
the efr 7064 spools faster than both with 560hp capacity................ and it has the best transient boost response of any turbo its size from the super light weight TiAl turbine wheel... the GTX turbo are over priced for what they are your better off with a bullseye power BWM s252 which is 520 whp capacity
if you want the best money can buy curently its made by borgwarner...
LOL!
I'd have to agree with this.
Quote: Originally Posted by 1LAPSRT View Post
Here... To make it easier to compare...
Garrett GTX3071R on a Tunergeeks tubular manifold with Vband TiAL Sport .63 A/R Housing running E90 and 27lbs of boost on a VERY SAFE tune by Nigel (Turbo666)
That's unbelievable power out of that turbo.
A GTX3076 is around a 65 lb/min turbo, flows about the same as a plane jane GT3582R. Combine it with a 68mm turbine wheel I don't think a GTX3576R will do 750 either. It is a sweet turbo however!
Vaderwrx is offline   Reply With Quote
Old 01-05-2013, 11:17 AM   #38 (permalink)
There is people taking the Gt3582-86r way past 750hp just look into it. The GTX 3576r will make 750hp with the right setup and tune, plus will hit full boost @4k. I think it would be a great match turbo for our car. Bump the rev limits to 7+k and you would have a nice powerband. The GTX3076r doesn't do so well so this 3576 is the fix others are talking about. Just going off what I have read so far.
The GTX lineup seems to be the real deal quick spool and big power!
Old 01-05-2013, 11:27 AM   #39 (permalink)
D-SRT's Avatar
I've seen lot of guys do 750 with the HTA82. The folks doing the 800+ are rocking the larger exducer'd hta86. That's just what I've seen on evom though. I don't go to many other forums these days.
You plan on going gtx3576, sean? It'd be cool to check it out in person once it'd be on and sorted out.
Pumpking.
Thanks to:
Old 01-05-2013, 11:28 AM   #40 (permalink)
I don't know about way past? I've seen a few above 700. Got any links? I'm more going off of what we've done and I've seen.
Here's my GTX3582R at 32 psi and e98. Believe me, I'm a huge Garrett GTX fan. We put a GTX3576R on a subie and it felt great but it's on a stock motor and not running much boost. But it's still a 58mm turbo, 750 out of a 58mm is a little crazy imo.
Old 01-05-2013, 11:30 AM   #41 (permalink)
D-SRT's Avatar
Powerband's looking sick Vader!
That's on a wrx?
Pumpking.
Thanks to:
Old 01-05-2013, 11:46 AM   #42 (permalink)
That's on a wrx?
Thank you sir! Yeah this is on a bugeye wrx. I have some restrictions like a small throttle body and I think a small header/uppipe and we are over a mile high in thin air so the turbo was just blowing steam after ~32 psi.
Old 01-05-2013, 03:36 PM   #43 (permalink)
This new GTX3576r is a old hta3582r and should make the same power.
I'm not ready to make the jump yet, but I am looking into this GTX3576r a lot.
Very impressed by Dougs GTX3071r with 600+hp@26psi with a .63ar.
A GTX3576r in a .82ar or bigger should hit 750hp.
Old 01-05-2013, 04:22 PM   #44 (permalink)
It flows less air than a regular GT3582R? So theoretically a regular GT3582R should make 750+ ... Sorry, not going to happen.
Old 01-05-2013, 05:00 PM   #45 (permalink)
SRT of the Month
2011 Calendar Car
1LAPSRT's Avatar
I am using a SPEC Mini-Twin. LOVE IT ! ! !
Windspeed Motorsports 5 Layer
