Old 11-02-2009, 03:35 PM   #1 (permalink)
Member Number: 61122
Default engine internals - best quality
im about to purchase new pistons and rods before i go with a bigger turbo setup.
What else is necessary to run a big turbo with less risk of breaking something?
what pistons and rods do you guys think are the best?
i appreciate any input - thanks
srt4newyork is offline   Reply With Quote
Old 11-02-2009, 08:40 PM   #2 (permalink)
supermech21's Avatar
Member Number: 42969
Trader Rating: (73)
Pistons and rods for what turbo set up? Power goals?
Old 11-04-2009, 10:29 AM   #3 (permalink)
boots's Avatar
Member Number: 67116
strap kit
2004 stage 2-AEM ems-DCR intake manifold-crane 16's(stock valve train)-act clutch-dss axles-boomba fuel rail-boomba mounts-boomba throtle body-3in side exit exhaust- maddog 58 STS-built trans( Rage accelerator, Rage 3/4 fork, and p-werks selector)- GT3076R
Soon to come, my high compression build New turbo setup and transmission setup
boots is online now   Reply With Quote
Old 11-04-2009, 10:43 AM   #4 (permalink)
porksword's Avatar
Member Number: 66925
Trader Rating: (21)
Have to match your goals with your budget first. You dont want to spend the money on the "best" if your turbo only allows you to make HP that internals at half the price could handle with ease.
Give your target HP and what turbo you considering and then we can help you out more.
porksword is offline   Reply With Quote
Old 11-04-2009, 01:09 PM   #5 (permalink)
evo77's Avatar
Member Number: 1346
Why waste money on replacing internals when they've been proven to sustain power levels in the upper 400's? And this kind of power can surely get the car into the 11's.
Instead, I'd worry more about focusing the spending on a properly matched turbo for your specific needs, a good tuning device, and a even better tune by a reputable tuner so that this power is delivered efficiently.
S2 no toys, Mopar bov, AGP bfmic, 3" turboback
Old 11-05-2009, 02:31 AM   #6 (permalink)
Member Number: 70446
Hi,
my setup is:
3071r @22PSI (in future 26 PSI)
waterintercooler
3" exhaust
3"intake
nearly 400hp
I want to switch to a racehead, powergoal is 500hp/ max rpm 6500
What internals do I need, would be stock internals also ok?
PT Christoph is offline   Reply With Quote
Old 11-05-2009, 09:22 AM   #7 (permalink)
i am most likely going to go with the AGP/Borg Warner "S" Series s251-rs which stock internals can handle i think..
what turbine housing do you think would be the best?
i decided im going to stick with stock internals until i plan on going with a bigger turbo. i was just a little nervous because i over revved once and had to replace my entire lower half.
im not too sure how the housings work exactly and what combination would work the best. i appreciate all the advice guys it helps alot!
Page generated in 0.12999 seconds with 13 queries
