Old 10-19-2009, 04:21 PM   #1 (permalink)
grablife's Avatar
Member Number: 73319
Default e3 spark plug
has anyone ever used e3 plugs on their nsrt4? i just picked up a set yesterday and so far no complaints just wanted to see if anyone had any reviews good or bad?
grablife is offline   Reply With Quote
Old 10-19-2009, 04:22 PM   #2 (permalink)
Philth's Avatar
Member Number: 46647
Trader Rating: (29)
Who makes it?
Old 10-19-2009, 05:35 PM   #3 (permalink)
grablife's Avatar
Quote: Originally Posted by Philth View Post
Who makes it?
e3
Spark Plugs | Automotive Spark Plug | Motorcycle Spark Plugs | E3 Spark Plugs
Old 10-22-2009, 11:20 AM   #4 (permalink)
hussler's Avatar
Member Number: 59838
Trader Rating: (49)
i had some but they go bad pretty fast i had one set for about 2k then one day i was only running on 2 cyls so i took them back and got another set and 100 mile later same thing. so i went home put a diff coil on the car and wires but same thing but when i put my 4306's back no problem after that.
S2 w/o toys,AGP 50 trim kit with .48 a/r,24 psi,AGP upper and lower hard pipe,TiAL 50mm bov,AGP race intercooler,AGP 3" cold air intake,Full 3" greddy evo 2
catback,needswings,Boomba rail,Fuel pump rewire,255 pump,PTP 650cc injectors,DCR oil mod,return line at 48psi w/boost source,BC S2cams,Adjustable gears,AEM wideband,180 T-mat,30/30 boost gauge,JMB cc,P&P TB,pulstar spark plugs,DSP tuned by Turbo666.
hussler is offline   Reply With Quote
Old 10-22-2009, 11:23 AM   #5 (permalink)
7angofragger's Avatar
Member Number: 73392
I know E3's tend to run better in like BMW/Volvo/VW... But im wanting to say either bosch or E3's come factory in the turbo volvos.. never used em tho
2003 Dodge SRT-4
Tein Superstreet Coilovers
Hotchkis Front and Rear Sway Bars
PWerks TriPoint Front and Rear Strut Bars
3" CAI
TurboXS RFL BOV
Solid MM
7angofragger is offline   Reply With Quote
Old 10-22-2009, 11:39 AM   #6 (permalink)
Member Number: 62234
In for feedback
gofastsrt is offline   Reply With Quote
Old 10-22-2009, 01:17 PM   #7 (permalink)
grablife's Avatar
so far so good but i believe you. one of the 4 plugs i bought orginally was bad when i put it in (never had a spark).
so far no complaints about the plugs, the car pulls just fine. i was a little worried since you cant gap them (preset gap is .05) but it hasnt been an issue yet. i guess ill just keep this thread updated as time goes on since not many people seem to have tried them yet.
Old 10-22-2009, 03:50 PM   #8 (permalink)
hussler's Avatar
Trader Rating: (49)
how much boost u running? cus i would get spark blow out at 22psi on a 50t but now im running the pulstar spark plugs and 25psi with no problems
Old 10-22-2009, 03:55 PM   #9 (permalink)
Member Number: 67038
nooooooooooooo dont get them!!!!!!!! i had blow out at 18psi on stock turbo. you CANNOT adjust the gap. they come out of the box at .66 thou and thats wayy to wide for a srt. i have a set sitting in my garage that are next to useless for me. also daily driving they didnt like at all. sputtering and rough idle till i went back to ngks.
Delta 55 Turbo kit, agp catch can, agp solid motor mounts,scangauge and wideband, 3 bar map and tip, Injen Sri, Jmb with hks, stage 1, exhaust depot custom undercar dump, grantelli wires,DW 750's, walbro. rescale by turbo 666
AllBoost is offline   Reply With Quote
Old 10-22-2009, 04:33 PM   #10 (permalink)
grablife's Avatar
they actually come gapped at .05 (at least mine did) and that was my biggest worry. but on stock turbo spiking 18-19 and holding 17 to redline i havnt had any blow out.
if i was on a big turbo i wouldnt have even picked these up (i see both of the people complaining about blow out are). when i make the switch at the beginning of the year ill drop them. i just grabbed these after i went to 3 part stores and couldnt find anything but autolites. figured it was time to try somthing new
Old 10-22-2009, 04:34 PM   #11 (permalink)
grablife's Avatar
those are good plugs from what ive seen/heard but waaay overpriced. i refuse to support them
Old 10-22-2009, 05:09 PM   #12 (permalink)
hussler's Avatar
Trader Rating: (49)
they arent that bad when u no people that work at the part store! lol
Page generated in 0.18806 seconds with 13 queries
