Quote: Originally Posted by
TheFace
I recently purchased a forward motion e2 turbo but unfortunately will have to run a stock manifold for now. I will be installing it tomorrow and was curious with my list of mods what the max boost on the manifold would be to keep the egt's down. currently on the stock turbo i spike 24psi and hold 15-16psi. i pull a decent amount of fuel on the safc and im still in the 11.4-11.7 afr range so i should have enough for hopefully 20psi atleast on the e2.
my mods are:
intake
3" downpipe and downpipe back
agp billet wastegate
evo fmic w/ custom piping and tbolts
turbosmart bov
ptp 75psi fuel mod
catch can and check valve
walbro 255
stage 1 injectors
ftp top end oil mod
safc and msd tach adaptor
ngk wideband
30/30 boost gauge
turbo xs boost controller (likely will not use with the e2)
devils own meth kit M5 nozzle (have an m3 as well if 2 nozzles are needed)
mopar stage 3 clutch
pwerks trans
im sure i forgot some things. thanks for any input.
You will run out of fuel before your egts get out of control, so start at 20 and work your way up (without pulling anything on the SAFC) until you start to lean out, then back it down a notch and do your SAFC thing from there.
My guess is boosting and holding 21-22psi is gonna be it for your fuel + meth.
What mix of meth are you using?
