Old 02-21-2008, 05:57 PM   #1 (permalink)
redteaser4's Avatar
Member Number: 48736
Default E2
I just purchased an E2 and i am just looking at what kind of power im looking at. i am getting a return line and fuel pump also. just looking to get some input thanks. and let me know if there is anything else i might need. thanks a lot.
Stage2 w/out toys, E2 turbo, ported exhaust manifold, Dtec FC, AEM CAI, BFMI, AGP hot & coldside pipes, Raptor BOV, MSD coil pack & wires, NGK stage 2 colder plugs gaped at .35, BWoody catch can, AEM wideband, Das mopar map clamp, Mopar sts, Weapon R 3 In. O2 housing and DP with HKS Carbon TI muffler, AGP mm.
Mods to come: return line, walboro 255 fuel pump, and a nice tune
redteaser4 is offline   Reply With Quote
Old 02-21-2008, 06:12 PM   #2 (permalink)
Member Number: 9221
with the S2 injectors you have and the returnline you could be looking at 330whp depending on boost levels. I would suggest getting a ported manifold aswell as a fuel controller
GO FAST PARTS
Stage 1
FM E1 turbo
FM WGA
Dtec FC
AGP returnline
PTP 55mm TB
PTP check valve
ED hardpipes w/ HKS BOV
Maddog STS 72%
AGP motor mounts
Zeitronix ZT2 wideband
NGK v power plugs .040
8.5 MSD wires
Needswings DP (no cat)
Quickwhips direct fit FMIC
180 thermostat
Bwoody H-brace combo
Bwoody Trans mount
AnotherNeon is offline   Reply With Quote
Old 02-21-2008, 06:17 PM   #3 (permalink)
Member Number: 9221
All E1/E2 dynos post here
Old 02-21-2008, 06:28 PM   #4 (permalink)
TurboMoparGod's Avatar
Member Number: 33697
Trader Rating: (29)
Pm Scottw03 he has similar mods to you and runs 12.30@112. He will be more then happy to help you out. BTW tell him I sent you.
www.ForwardMotioninc.com
Sales@ForwardMotioninc.com
Stock turbo 12.82@107mph DR's
E1 Turbo 12.48@115mph DR's slipping stock clutch
E3 Turbo and new FM clutch XX@XXX
TurboMoparGod is offline   Reply With Quote
Old 03-18-2008, 03:23 PM   #5 (permalink)
redteaser4's Avatar
update. i got a dtec with gameboy 255 fuel pump ported exhaust manifold. just dropped the E2 off to get inspected and am waiting to here back from them about when it'll be done. the only thing i think i need is the agp return line. if anyone has one decently cheap. Let me know. i do believe it is the last thing i will need although i am looking for a ebc such as an Eboost or the profec B. Hoping for close to 375. let me know what you guys think thanks.
Old 03-18-2008, 04:01 PM   #6 (permalink)
scottw03's Avatar
Member Number: 23435
Trader Rating: (31)
LOL, too late already saw the thread.
scottw03 is offline   Reply With Quote
Old 03-18-2008, 04:11 PM   #7 (permalink)
scottw03's Avatar
Trader Rating: (31)
Ok, not to bust your bubble but I highly doubt you will get to 375 whp. Sorry man. I don't think you will get that with your mods. I am guestimated my whp output at about 330 with very similar mods. Like Turbomopargod said I run about a 12.3 @ 112 mph in the 1/4 mile. Now I am not the best driver and I do not even really have a tune on the car other than leaning the car out at WOT. Meth injection wasn't working either at the time. Those times are on Slicks too.
Honestly I would say with the E2 and somewhere around a 24 psi on the turbo (make sure you have either an adjustable wga that holds boost well like the FM wga) you could see around 340-350 whp with a good tune. Anything more than that I would say is wishful thinking at the moment. The nice part about it though is you have a great power curve if you can get that wga to hold your boost through the power range.
With my E1 and FM wga I was able to run 24 psi falling to 20-21 psi at redline. That is a huge difference compared to when I ran the same E1 turbo with the AGP wga which fell to 16 psi at redline. That drop in pressure will kill your power curve.
Oh and a ported exhaust manifold is definately a great idea. It will help free up power you have but is being restricted along with drop your exhaust temps a bit so you don't melt a valve or piston.
Either way I wish you alot of luck and if you can get 375 definately let us know.
Old 03-18-2008, 04:19 PM   #8 (permalink)
redteaser4's Avatar
lol thanks for the info and yes it is wishful thinking but oh well gotta think posative maybe itwas a littel to posative. Is there anything else you think i should invest in or no? and should i go with the FM front mount or is my bfmic ok? thanks a lot for the help.
Old 05-08-2008, 08:28 AM   #9 (permalink)
redteaser4's Avatar
Ok E2 and exhaust manifold installed. haven't got around to the fuel pump install. And i am having a someone install my dtec cause i don't feel safe doing it myself. She seems to be running pretty good for now but im sure she will be a lot better with a tune on her. i'll let ya know updates. thanks for everyones help again.
Old 05-09-2008, 09:28 PM   #10 (permalink)
Trader Rating: (29)
Start a new thread in the Forward Motion section so we can keep track of your progress.
Old 05-10-2008, 02:23 PM   #11 (permalink)
redteaser4's Avatar
Ok sounds good. i wwill do that. im looking to find someone who can install my dtec thats pretty close to me.
Page generated in 0.35937 seconds with 11 queries
