I Have A Neo If I Would Spend That Kind Of Money Wouldnt The Avcr Be A Better Option?
Hey I Need That Ported Mani Lol I Put In The Mpx 62mm Tb...spacer Bolts Right Up 2 The Stocker Let Me Know Whats Up Ill Come Pick It Up
i really like the avcr but it can be a real pain to get sorted out unless you know what you're doing or have help from someone who knows what they are doing.
Sorry for the noob questions but i dont have time to read through 11 pages for a bit of info here and there....can someone give me some quick info on this turbo:
Power at 20lbs(safe street tune) -
Power at 25lbs (ballsy-er street tne) -
Power at 31lbs(110 tune) -
Full spool -
Max boost -
I understad all of this is depedent on your set up and everyones is different, for sake of argument, use mine ....Pertinet info:EMS with all the buttons and whistles, ported head(+1/+2), crane 12's, Rage DNP mani, strap, 8.0cr, BC rods, 750's, BNF, walbro, re wire, -6 an return line, 3" TBE....
Quicky i pm'ed you about a set up like this a week ago but got the cold shoulder....
Full spool -
Max boost -
your numbers will be ALOT higher than mine with your motor
Power at 20lbs(safe street tune) - im about 350-360
Power at 25lbs (ballsy-er street tne) - im 420+
Power at 31lbs(110 tune) - lol lets blow it up and find out
Full spool - around 36-3700 on stock head mani internals
Max boost - who knows lol
what rpm is your power droping off jaydawg? I cant tell from your dyno sheet but the actual dyno vid seems like you pull for a while
i was doing 4th gear pulls.... power wasnt dropping off that much. the a/fs were off on the dyno sheet b/c of my cutout but they were like 11-11.6 on my gauge and my meth was bogging it out and i was runnin 2 much timing...ill have some new numbers with the sct maybe sometime later in the week.
im just trying to see if its worth dropping my 3200rpm full spooling 50t for a lil laggier s256 in trade for potentially more hp on pump (all this car will ever see)...
i know im already 400+ on pump as is right now.
Mike, I havent yet seen any dyno or track evidence that the S256 is any faster or more powerful below 23-24psi. i dont think your going to find another turbo with that low of a spool that makes more power at the same boost unless someone is running a higher compression set of pistons.
thats what im thinking...
my boy just got a s256...we might install it fri at my house...but he has 0 mods. just exh.
hes building as he goes.
so i cant really compare tho itd be nice to.
i got a TON of stuff that will be going on soon to compliment the 50. as usual, im always curious to other turbos...tho i love the 50.
there arent many, if any turbos that appeal to me aside from the s256/.55ar. the .63 is jus too laggy for what i want out of my car. the .55 would atleast drop it down to 34-3500 id assume.
we need to catch up man. i know u sent me a few pm's, but honestly i havent read any of them...or anyones for that matter...i have like 30 unread messages...
412 was at 25 psi with 100% alky but it was sooo rich it was bogging down so i didnt make the power i wanted. i made the mik to 75% and it pulls better with 11s across the powerband. this turbo is AWSOME!!!! spool sounds crazy.....you just have 2 have the motor and the revs for it.......thats next
Power at 25lbs (ballsy-er street tune) -
Full spool -
Max boost -
Any one else care to throw in there guesses/knowledge? Can this turbo produce 520ish on a 110 tune? Where does power drop off, 6700? 7000? I really dont think it will be able to flow much past 7000 but i could definitly be wrong...
Whats the highest dyno to date that is turbo has produced? Fastest ET and trap?
Full spool -
Max boost -
25lbs i think you will be in the 500 with that set up. full spool is around 3800rpm max boost i dont know i dont think anyone has found it yet. if i get my car running soon i will check i plan on running 25 on pump gas with meth and on race gas 32 psi. what rpm are you running it to. i will be going to 7200 then when i get the rest of the stuff i need like input shaft then as long as the turbo will not fall off the i want to rev to 8000.
kyle
