Old 11-28-2008, 01:19 AM   #1 (permalink)
zooyork182's Avatar
Member Number: 53912
Default brian crower vs crower rods
is there a huge differance between the two like there is with cams? i know modernperformance sells crower rods for 700 something and tk motor sells brian crower rods for 400 something.
zooyork182 is offline   Reply With Quote
Old 11-28-2008, 10:20 AM   #2 (permalink)
Member Number: 58399
Trader Rating: (36)
there are two different kinds of BC's which ones are you looking at??
DCR Powered
tcglass1 is offline   Reply With Quote
Old 11-28-2008, 10:41 AM   #3 (permalink)
DDogsrt461BLK 3.0's Avatar
Member Number: 32500
Smile Connecting Rods?
These are nice!!!
These are better
probably better still
& the standard shit.............
the 2nd or 3rd will be my next set of rods, if I can find them...........
DDogsrt461BLK 3.0 is offline   Reply With Quote
Old 11-28-2008, 10:45 AM   #4 (permalink)
Trader Rating: (36)
most if not all of it is going to come down to your goals and what you wanna spend... I ran Eagles in my Evo and made 540 awhp thats around 700 crank with 25% drivetrain loss and I've been told it's more than that, ran the car for about 12k miles... Never had one issue until I sold it and as far as I know its still running... I have BC's now for the SRT, so its all what you want to spend or what brand you like
Old 11-28-2008, 11:08 AM   #5 (permalink)
I plan to drop Science on people's faces!!!!
Old 11-28-2008, 11:21 AM   #6 (permalink)
Member Number: 39550
Trader Rating: (30)
you'll be fine with the brian crowers on the stage 3 man, my crowers are rated at 1500hp
Realtune built 2.6 DCR stroker
DCR Pro-series Head, Intake, PT76 Turbo kit
DCR full race auto trans
Realtune full race custom fuel system
Realtune race ignition
AEM EMS
Built and tuned by Realtune
9.98@144mph Canada's FIRST 10 and 9 second srt4
squishy332000 is offline   Reply With Quote
Old 11-28-2008, 11:36 AM   #7 (permalink)
I plan to hose mine with a 150 -200 shot.
Pauter or the Crower's from Modern are what will do the job for what I'm planning.
I have Eagles in my engine now, and something went wrong with them. I can't speculate as to whats wrong with it til I take it apart. But there's a noticeable knock in the engine at 2500-3500rpms under the HG. #1-2 area.
Old 11-28-2008, 12:24 PM   #8 (permalink)
zooyork182's Avatar
haha good to see your still alive after lastnight
but...
i want my bottom end to handle 500hp+ iv only seen modernperformance sell the crower and they go for $700. every where else sells the brian crowers for about $400-$500. what are the bc rated for? i wont go with eagls so i dont care about them. i dont wanna spend $700 on crower rods when i can get bc rods that could be just as good for $400, i just dont wanna make the mistake and have to redo it later on.
also what bearing would be good to use stock mopars?
Old 11-28-2008, 05:24 PM   #9 (permalink)
Trader Rating: (30)
brian crowers i think are good for 500whp, and dcr has bearings if you want some upgraded ones. i think there just coated or somehting, but there better then stock.
Old 11-28-2008, 06:18 PM   #10 (permalink)
Trader Rating: (36)
I think the upper BC's are 650ish, maybe not
Old 11-29-2008, 06:40 PM   #11 (permalink)
tgspeedracer's Avatar
Member Number: 25328
two diff ones. depends on what bolts they use
Best ET 11.41
Best MPH 131
@5860ft elevation
Peak whp 567
Peak tq 607
DSP Tunned by Nick Chestnut with "Unique Solutions Tuning"
tgspeedracer is online now   Reply With Quote
Old 11-29-2008, 07:43 PM   #12 (permalink)
supermech21's Avatar
Member Number: 42969
Trader Rating: (72)
They (bc) both use a 3/8's Rod Bolt. Period. BC does not make a 7/16's rod bolt, and they wont custom make one (i have called) ....Crower runs a 7/16's rod bolt size. Thats BIG! They are the best, hands down. Theres a reason there nearly double.
Any way you slice it even the upgraded BC's still use a 3/8's....to me it doesnt matter how much stronger it is, its still a 3/8's....But then again im not a engine builder.
Good luck, if you can spare it i would go with the Crowers, TKMS has them for 744 or 830 shipped, i think. You can pm him, I guarentee his price is as LOW as they can be sold. GL.
Old 11-30-2008, 06:51 AM   #13 (permalink)
c2k
c2k's Avatar
Member Number: 2639
Trader Rating: (65)
ryan - if you are going to get the bottom end rebuild, i'd get an engine rebuilder at least balance the rotating crank and assemble it. that way you d know it's balanced fromt he get go.
http://www.SRTCanada.com <----- alternate site for canadians.
DiabloSport Trinity Beta Tester
Quote: Originally Posted by DODGETWEAKER
Boost is like crack and I am your dealer. Come here lil' junkie and take your medicine.
Dodgetweaker is a part of the SRT Engineering team
c2k is offline   Reply With Quote
Old 11-30-2008, 12:21 PM   #14 (permalink)
zooyork182's Avatar
yeah the block is going out to get balanced and machine work done all that good stuff.
Old 11-30-2008, 07:47 PM   #15 (permalink)
c2k
c2k's Avatar
Member Number: 2639
Trader Rating: (65)
atta boy ryan!
Page generated in 0.19186 seconds with 13 queries
