Borg Warner S400 67mm, E98, Built long rod 2.4, and Diablo Sport - Page 3 - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 02-29-2012, 08:48 PM   #31 (permalink)
05 Srt-4 [NE]'s Avatar
Member Number: 39744
Quote: Originally Posted by turbo666 View Post
KW input shaft w/ gears, DCR notched 3/4 assembly with their blocker rings, DCR modified shifter assembly w/ AGP selector, DCR synchro springs, LSD setup different thanks to some great tips from Ed Peters, DCR fluid. All assembled by me.
how are you liken it? i have the same setup comen from dcr tomarrow
01 Neon (SRT powered)
03 Stone white SRT-4
05 Silver SRT-4 (501WHP)
05 Black SRT-10
08 Sunburnt orange cSRT-4
Those are just the SRT's
http://youtu.be/BmyAW8sZ2k0
05 Srt-4 [NE] is offline   Reply With Quote
Old 02-29-2012, 09:48 PM   #32 (permalink)
dsmbenchpress's Avatar
Member Number: 75833
On this Dyno making this kind of powe is no easy task. I was looking for the most efficient 67mm out there, and IMO this was a better choice then the pte 6768. I love Borg technology and reliability. Also this turbo is the same foot print as a 42r and s372, so I can always upgrade easy later. Besides look at the graph. It make 24psi by 4700 and holds till 8k! On that graph it hit 30psi around 5k because it was the first pull on 30psi and the boost box had to learn. Hell timing wasn't even finished so I think on that boost it'll make another 30-40hp.
Good build man. Spools nasty fast, also your torque falls adding timing should helpWhat that
Good luck breaking records!
It will spool on its own. Good things come to those who wait
dsmbenchpress is offline   Reply With Quote
Old 02-29-2012, 10:54 PM   #33 (permalink)
SRT of the Month
turbo666's Avatar
Member Number: 25206
The tune wasn't done, but my drag radial coming apart stopped the tuning. lol. It'll get finished at the track.
I really don't care about setting records (now that the stock bottom is out) within this community, or any other for that matter. My goal is to be consistent and competitive at local events that are usually dominated by Honda's. The SRT-4 is still the underdog around here so that just makes it more fun.
Thanks
04 SRT-4-10.18@150.3, and still a lot left in it...
Engine builds, dyno tuning, fabrication, and more available! PM me for pricing and details!
Contact me for great prices on your part needs!
http://www.facebook.com/BrutalSpeedAndTuning
Old 02-29-2012, 11:13 PM   #34 (permalink)
mikhailsrt-4's Avatar
Member Number: 82787
very impressive must have deep pockets lol . easily over 12k in that motor
mikhailsrt-4 is offline   Reply With Quote
Old 03-01-2012, 12:32 AM   #35 (permalink)
SRT4YA1's Avatar
Member Number: 26444
Looks good bad ass build.
SRT4YA1 is offline   Reply With Quote
Old 03-01-2012, 03:29 AM   #36 (permalink)
BoostAcr's Avatar
Member Number: 75930
Quote: Originally Posted by BoostAcr View Post
can u explain the differences between e98 and e85? i understand it has more ethanol, but any drawbacks to e98? thanks!
Yeah that just happened, quoted myself for an answer ... Lol
BoostAcr is online now   Reply With Quote
Old 03-01-2012, 09:04 AM   #37 (permalink)
Member Number: 86669
Thanks
can't wait to see this car at IFO in Rockingham. I am a NC local looking to get into a srt4. I have heard Nigel is the guy to go to, look forward to meeting you soon.
GEN2 LS is offline   Reply With Quote
Old 03-01-2012, 09:15 AM   #38 (permalink)
Gringo3825's Avatar
Member Number: 30934
How big is that intercooler? I think I want one! Going to be parting my whole setup soon for a setup to get those kind of numbers.
GT35R Fully Modded:
Old numbers
On untuned base map
381hp 336tq @ 14psi
Gringo3825 is offline   Reply With Quote
Old 03-01-2012, 09:15 AM   #39 (permalink)
SRT of the Month
turbo666's Avatar
Thanks man! I'll def be there.
The greater ethanol content helps combustion temps, detonation resistance, puts more fuel into the combustion chamber at one time thus giving you more exhaust energy to help spool the turbo faster compared to typical gas.
It is more corrosive and does require and even more robust fuel system.
This is Ignite E98 so it's consistent and doesn't have any "trash" in it to make up the other %2.
A very intelligent tuner on another forum did a test a few years back. C16 vs Q16 vs E98. Q16 made 40whp more over C16 and E98 made another 60whp over Q16, so 100whp more over C16. This was the same car and same 45psi boost level.
Old 03-01-2012, 09:49 AM   #40 (permalink)
dereku's Avatar
Member Number: 66999
I couldn't help myself.
We have the same block! Minus your straps and billit pump gears. Did you use king bearings as well?
AGP DBB 50T .63A/R, Race IC, returnline FM E2 Block, Built head, BC S2 cams, Thermal Exhaust, CMGS, FIC 900, Walbro 255, N2MB Boxes, ACT 6 puck, HKS SSQV
DSP tuned by Turbo666 382WHP on the heartbreaker
Build Thread
dereku is offline   Reply With Quote
Old 03-01-2012, 09:54 AM   #41 (permalink)
SRT of the Month
turbo666's Avatar
ROFL!
King rods and Clevite manis, reluctantly. King has all of their shit on backorder.
Old 03-01-2012, 09:59 AM   #42 (permalink)
dereku's Avatar
Hey as long as they have the "NASCAR" endorsement, you should be good to go.
Maybe I sholdn't make Nascar jokes. I just realized you guys might take that more seriously than I would.
Build Thread
Old 03-01-2012, 10:11 AM   #43 (permalink)
Turbolag87's Avatar
Member Number: 6491
F&F Stage III 47lb turbo
+1 Race head, Race ported IM
BC 2 cams
Ext WGA
Meth Injection
11.4@125mph (old times, stock head and cams) 26psi
Turbolag87 is offline   Reply With Quote
Old 03-01-2012, 10:13 AM   #44 (permalink)
kornsined's Avatar
Member Number: 34376
That motor doesn't even sound like a 4 cyl. So bad ass! Those Honda's will be crying.
kornsined is offline   Reply With Quote
Old 03-01-2012, 10:20 AM   #45 (permalink)
SRT of the Month
turbo666's Avatar
Lol. I don't think anyone else who works in the performance industry around here could care any less about NASCAR then me.
