Old 03-24-2008, 05:25 PM   #31 (permalink)
quicky4's Avatar
Member Number: 28222
Quote: Originally Posted by AUTOSSEY View Post
wow look at that sig
Thanks!!! Nemo and Eric @ Rage -Tek are the BEST!!!!!!!!!!!!!!!!!!!!!!!!
Under Construction
quicky4 is offline   Reply With Quote
Old 03-24-2008, 07:26 PM   #32 (permalink)
AUTOSSEY's Avatar
Member Number: 60657
Got any videos. is the tranny stock on yours?
AUTOSSEY is offline   Reply With Quote
Old 03-24-2008, 07:31 PM   #33 (permalink)
quicky4JR.'s Avatar
Member Number: 43042
Trader Rating: (55)
There's a vid on streetfire.net with him running 10.8 (not with the S362). Just search for Rage-tek. The 10.5 vid with the s362 has yet to be loaded.
The tranny is not stock. It had AGP shift selector, Rage-tek 3/4 shift fork, Rage-Tek Billet input shaft, Rage-tek twin disk clutch, Rage-tek clutch pedal pivot arm/bushing and Rage-tek shifter bushings.
Quote: Originally Posted by darrell cox View Post
Far better than stock but not as good as Nemos!
Leaders not followers! Paving the way and making it easy for everyone else!
(954)-915-0016
Davie,FL
Dyno tuning, installs, and custom builds
quicky4JR. is offline   Reply With Quote
Old 03-24-2008, 07:54 PM   #34 (permalink)
AUTOSSEY's Avatar
Rage-Tek's 10 second project car - Video
so that means im pretty fucked since all i got is a stage 4 clutch and an lsd
Old 03-24-2008, 08:06 PM   #35 (permalink)
quicky4JR.'s Avatar
Trader Rating: (55)
No not necessarily. The car ran with well over 600hp for the longest with just and AGP shift selector and upgraded clutch. You'll be fine unless you plan on racing the car every weekend at the track. I do highly recommend a shift selector. Its usually the first thing to go in a tranny.
Old 03-25-2008, 06:36 AM   #36 (permalink)
Member Number: 41218
Trader Rating: (17)
i have a short vid on visual section with he center rear exhausts i did. i have the s362from rage, with dnp manifold and 3"dp.no intake yet. all from rage. this was when they started putting the kits together, so i don't know if they changed anything, but the turbo is strong and sounds nice. i will put some pics today after work so you get a feel as to how it would look with the dnp.
by the way if anyone is wondering whether it hits the body,it does not touch at all. pics are alittle crappy.
reysrt4 is offline   Reply With Quote
Old 03-25-2008, 10:19 AM   #37 (permalink)
AUTOSSEY's Avatar
well actually im not gonna dd the car just maybe fridays and saturday and maybe a couple times a month at the track.
Old 03-25-2008, 10:48 AM   #38 (permalink)
AUTOSSEY's Avatar
my car is taken apart right now. no turbo kit, no intake manifold no cam gears, timing belt. could i put everything back on right now and once the turbo gets here just slap that on there. if i do put everything back together and wait for the turbo kit will it be a bitch to get the turbo kit on???
Old 03-25-2008, 11:19 AM   #39 (permalink)
tavenger5's Avatar
Member Number: 42245
Trader Rating: (29)
Wow, that's a hell of a setup.
[font="Arial Narrow"]
2004 Black SRT-4 - all set for 500hp+
2005 Interlagos Blue BMW M3
tavenger5 is offline   Reply With Quote
Old 03-25-2008, 11:36 AM   #40 (permalink)
SpeedEuphoria's Avatar
Member Number: 30870
Man do you have any leaks from the AFPR just hanging there?
Catch me at Sunoco, show me that your loco, put 110 in your 4 doe!!
Project log pics
Old 03-25-2008, 02:16 PM   #41 (permalink)
quicky4JR.'s Avatar
Trader Rating: (55)
Installing all the parts you already have isnt going to make installing the turbo kit any harder. None of that stuff will be in your way when you put the turbo kit in. Do it now less work you have to do all at once later
Old 03-25-2008, 03:09 PM   #42 (permalink)
AUTOSSEY's Avatar
COOL everything is in now
now just wait for the turbo
Old 03-25-2008, 06:29 PM   #43 (permalink)
Trader Rating: (17)
i think the hardest thing to put in was the turbo,which is big,but not that bad. the fpr doesn't leak at all.
Old 03-25-2008, 07:18 PM   #44 (permalink)
AUTOSSEY's Avatar
you guys think my car will make more than 600hp even with the .70 a/r????
Old 03-26-2008, 11:59 AM   #45 (permalink)
AUTOSSEY's Avatar
my kit was supposed to ship out today but i decided to get the .85 a/r housing instead of the .70a/r
.85 A/R FTMFW!!!!
