Old 03-20-2008, 02:03 PM   #1 (permalink)
AUTOSSEY's Avatar
Member Number: 60657
Default Borg Warner S362???
anybody running the borg warner s362 from ragetek?
AUTOSSEY is offline   Reply With Quote
Old 03-20-2008, 03:59 PM   #2 (permalink)
Member Number: 58932
Trader Rating: (23)
im running the s362 compressor side on a turbonetics turbine side.
its a lil laggy to say the least...
what exactly are you looking for?
Old 03-20-2008, 04:40 PM   #3 (permalink)
AUTOSSEY's Avatar
Im looking for dynocharts, videos, and some info on it. i have a fully built motor now and i talked to nemo ragetek and they said that was the best turbo for the goals i had (600+hp). so i ordered it yesterday. he said its was almost the same as a gt35r. a 35r is a 61lb/min turbo and the s362 is a 62lb/min turbo.
wats the spool like on ur car? have u got it dynoed?
Old 03-20-2008, 04:45 PM   #4 (permalink)
Trader Rating: (23)
built motor.
s2 crower cams.
full bolt ons.
still breaking in the motor. got 100mi. left.
its a lil laggier than i anticipated...but ill give it a chance when i rev it out to 7300.
i havent taken it to redline yet going WOT, nor even to 3800 at WOT...but i can tell ya from what i experienced, full spool (20+) will be right around 3800 give or take 100rpms...
not many people have this turbo, if any...so responses will be slim.
if you wana keep in contact, ill be able to give ya a response in a weekish or so.
Old 03-20-2008, 05:09 PM   #5 (permalink)
NemoFoss's Avatar
Member Number: 4163
Trader Rating: (71)
s362 is a 62mm and 66lb/min.
Dyno chart..
If you want to check out more dynos and pricing and such go here...
Rage 650whp Turbo Kit info + Pricing
NemoFoss is offline   Reply With Quote
Old 03-20-2008, 05:28 PM   #6 (permalink)
AUTOSSEY's Avatar
Dyno chart..
LOL my bad i must have heard you wrong when we talked on the phone sorry.
and nemo i already bought it from you
Old 03-20-2008, 05:29 PM   #7 (permalink)
NemoFoss's Avatar
Member Number: 4163
Trader Rating: (71)
If you want a fast spooling turbo that will just hit 590-600 that would be the s258.. 60lb/mn we have this as a bolt in swap for 4bolt 50trims..
Old 03-20-2008, 05:30 PM   #8 (permalink)
AUTOSSEY's Avatar
nemo im running the agp manifold. is the agp manifold blue or red? also at wat psi were those numbers made at?
Old 03-20-2008, 05:31 PM   #9 (permalink)
AUTOSSEY's Avatar
built motor.
s2 crower cams.
full bolt ons.
i have pretty much the exact same setup as you. are you using the tubular manifold?
Old 03-20-2008, 05:36 PM   #10 (permalink)
NemoFoss's Avatar
Member Number: 4163
Trader Rating: (71)
AGP manifold was blue at about 36-38 psi.. But thats with the .85a/r split entry turbo.. the .70a/r will spool sooner than that..
Drastic is running a hybrid garret/BW turbo... I am not sure the size of his turbine wheel or A/r of the turbine housing..
If you are looking for 50trim spool up and 600whp capacity then the s258 is the ticket..
Old 03-20-2008, 05:43 PM   #11 (permalink)
AUTOSSEY's Avatar
im looking to take mine to like 7200rpm-7400rpm at about 33-35 psi aslong as theres no knock ill take it to the moon. i bought the kit with the .70a/r so hopefully it will spool alot sooner than that but i think ill stick with the s362 ftmfw!!
Old 03-20-2008, 05:45 PM   #12 (permalink)
AUTOSSEY's Avatar
wat kind of numbers do you think i should be making with that setup?? on c16 and 91 octane? i was planning on pushing like 21-23 psi on pump gas. you think ill be ok?
Old 03-21-2008, 05:52 PM   #13 (permalink)
Member Number: 30158
Trader Rating: (12)
are you using meth with pump gas
OrangeKyle is offline   Reply With Quote
Old 03-21-2008, 09:40 PM   #14 (permalink)
Member Number: 41218
Trader Rating: (15)
Default s362
i bought the s362 kit from ragetech, with the dnp maanifold. i am still working with jay at n2mb on tuning, but it definiteley rips. i hit full boost at23lbs. around 4300,but we are still fine tuning. my charge pipe kept falling off. it may be alittle laggy, but once it comes on, i hold on realtight. i have even gotten off during wotwhen jay told me to hit it( i guess i got nervous). i am only waiting for my intake(nemo)to come in.hope this helps
reysrt4 is offline   Reply With Quote
Old 03-22-2008, 05:00 AM   #15 (permalink)
SpeedEuphoria's Avatar
Member Number: 30870
100mi left, Its broke in before the 1st 100mi, silly. I went through ~5mi basic tuning and checking things then let it rip
Project log pics
Page generated in 0.23401 seconds with 13 queries
