Old 12-03-2007, 12:20 PM   #1 (permalink)
Member Number: 48008
Default Big Turbo Prolem
I have a built 2.4 8:8:1cr with a ported and polished head. The problem I am having is I have a holset hx40. There are two housings now available for it a 55a/r and a 70 a/r Im trying to figure spool times on the two of them. I can also rev my engine to 7500 rpm because its in my Avenger. So who can help me figure it out?
babeboy is offline   Reply With Quote
Old 12-03-2007, 12:40 PM   #2 (permalink)
Turbocruiser13's Avatar
Member Number: 42620
55a/r will spool around 3k the 70a/r should be around 3700
O4 PT Cruiser non GT
Stock b****es, come get me
SoCal's fastest PT Cruiser
Turbocruiser13 is offline   Reply With Quote
Old 12-03-2007, 10:25 PM   #3 (permalink)
Will the 55 keep pushing up to my 7500 redline.
Old 12-03-2007, 10:56 PM   #4 (permalink)
I think it may run out of steam just short of that...most likely around 6800
Old 12-04-2007, 01:46 AM   #5 (permalink)
I could also clip the turbo a few degrees right?
Old 12-04-2007, 02:05 PM   #6 (permalink)
Yeah you can clip it...TYPICALLY clipping will usually help spool times, so it might be worth it to get the larger a/r and have that clipped so you can have the best of both worlds
Old 12-04-2007, 06:01 PM   #7 (permalink)
How does it help? I thought it created bigger gap so more gas can get through.
Old 12-27-2007, 08:55 PM   #8 (permalink)
Member Number: 59599
Clipping a turbo does not spool a turbo up faster, It is helped to achieve more top-end.
thesrt4guy is offline   Reply With Quote
Old 12-27-2007, 11:56 PM   #9 (permalink)
I know that. Thats why I didnt understand what ptcruiser wrote. He said it helps spool time, wihich made me think it helpd the turbo spool quicker. From my understanding the clipped part of the turbo lets more air/back pressure escape to help build more top end power at cost of low hp. a cliped turbo is more of a band-aid fix when you have a t3/t4 turbo with the amount of housings that are available. With the holset it seem the only possible way with only 2 available ar housing it seems like the only way to get me close to a verry friendly 63ar housing I would have to port and clip the 55ar housing.
Old 01-02-2008, 03:12 PM   #10 (permalink)
ipt
Member Number: 9025
Just get the .70 a/r housing. It will spool mid to late 3K rpms and it will not restrict the top end power at all.
There are alot of DSMs that run the .55 and rev to 7500 rpms, but with on 2.0L they can get away with that.
ipt is offline   Reply With Quote
Old 01-10-2008, 12:03 AM   #11 (permalink)
bump for more info
Page generated in 0.18578 seconds with 13 queries
