Big turbo. dead stock heads and block? - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 12-10-2012, 11:15 AM   #1 (permalink)
Spoolin04's Avatar
Member Number: 85728
Default Big turbo. dead stock heads and block?
what would be the best turbo setup to run on stock heads and block? i have supporting mods. but i wanna leave the motor the way it is and because im on a budget. maybe a 50 trim or a steage 3 mopar? i would like it to be a direct replacement if its possible.
04 flame red.
Aem cai, mpx 3" side exit, 3" catless DP, 3" o2 housing,
Godspeed Fmic, Agp solid motor & trans mount, Diablo
tuned peaking 22 psi, agp hardpipe with hks bov,
granatelli coilpack and wires, maddogg sts, dropped on
tein h- techs.
Spoolin04 is offline   Reply With Quote
Old 12-10-2012, 12:20 PM   #2 (permalink)
Fresh Meat Moderator
tunerlover3's Avatar
Member Number: 76568
HEAD. Not HEADS. We have one not two....
Anyway. A 50 trim with a .63ar is a common big turbo setup on a stock motor.
Stage 3 would be as close to direct replacement as possible.
Diablo CMR tuner ~Dan~
310HP 436TQ
2004 Eblue Neon SRT4: E85 5558 Built motor
XXXHP XXXTQ
Old 12-10-2012, 12:33 PM   #3 (permalink)
Spoolin04's Avatar
myy bad lol my phone was on autocorrect.
what would be needed to install a stage 3 turbo? how hard is the install
04 flame red.
tein h- techs.
Old 12-10-2012, 12:46 PM   #4 (permalink)
You would need the stage 3 turbo, manifold, o2 housing, and wga.
All the stock lines fit. the only thing you have to do is cut the oil drain hose.
310HP 436TQ
XXXHP XXXTQ
Old 12-10-2012, 12:49 PM   #5 (permalink)
Spoolin04's Avatar
cut it to fit the turbo? couldnt i buy one made for the stage 3
04 flame red.
tein h- techs.
Old 12-10-2012, 12:51 PM   #6 (permalink)
There isnt one made for the stage 3. It uses the stock hose.
Original stage 3 instructions say you have to cut a certain amount of the rubber hose for the drain tube.
310HP 436TQ
XXXHP XXXTQ
Old 12-10-2012, 05:54 PM   #7 (permalink)
meadors44's Avatar
Member Number: 83833
i have a 50 trim on my car its a great turbo i drive my car every day
meadors44 is offline   Reply With Quote
Old 12-10-2012, 05:55 PM   #8 (permalink)
D-SRT's Avatar
Member Number: 80561
If you want as close to stock looks and characteristics... s3
for aftermarket...there is no turbo I've seen that better matches with the stock head/bottom end than a 50t/.63
Pumpking.
10.31@147. 1st SRT in TENS in CA.
QUICKEST & FASTEST IN CA.
Thanks to:
TUNED BY MINDMELT101@DRAG-ON Tuning. - http://drag-ontuning.com/blog/
GOKEY RACING for anything fabrication related
Instagram: m_santiago37
D-SRT is offline   Reply With Quote
Old 12-11-2012, 06:16 AM   #9 (permalink)
SRT4Delta46's Avatar
Member Number: 88656
the 50trim or stage 3 you cant go wrong with either one its all on what kind of power you want and what fuel you will be using. stage 3 on pump will not make as much as 50trim on pump. put some E85 with the stage 3 and you sir will have a torque MONSTER!!! there are some guys on here with a basetune from duster360 with a stock stage 3 setup hit 400hp.. good luck with your decision
SRT4Delta46 is offline   Reply With Quote
Old 12-11-2012, 11:14 AM   #10 (permalink)
Spoolin04's Avatar
50 trim it is. now i gotta find a well priced one. what will need to be done to install it?
04 flame red.
tein h- techs.
Old 12-11-2012, 11:34 AM   #11 (permalink)
*ALEX*'s Avatar
Member Number: 79647
Out with the old in with the new
Quote: Originally Posted by lVlemphizStylez View Post
When I open my hood people think the car is on all kinds of steroids
*ALEX* is offline   Reply With Quote
Old 12-11-2012, 11:55 AM   #12 (permalink)
Turbo, manifold, o2 housing, wastegate, dump tube, oil and/or water lines, coupler for intake, modify stock charge pipe or buy aftermarket, injectors, 3 bars, intercooler, blow off valve, cold side pipe, fuel pump, tuning device, custom tune, etc etc
310HP 436TQ
XXXHP XXXTQ
Old 12-11-2012, 11:56 AM   #13 (permalink)
Flame Red's Avatar
Member Number: 89207
There is a 50 trim turbo for sale in the for sale section for cheap right now. Very tempting but I am still stuck on the stage 3 route.
Full Stage 2 w/toys
3in Exhaust
DSP
AEM Wideband
Flame Red is offline   Reply With Quote
Old 12-11-2012, 06:03 PM   #14 (permalink)
meadors44's Avatar
you wont be disapointed and later down the road you can switch turbos when you want more hp
50 trim best 1/4 12.1@121
Old 12-12-2012, 07:37 AM   #15 (permalink)
Spoolin04's Avatar
first i need to get my trans rebuilt and 6 puck clutch and shift fork. anyone have any idea where a good place to get a stage 2 trans rebuild done? for around 1500-2000.
04 flame red.
tein h- techs.
