08-12-2007, 06:17 PM
#1 (permalink)
Member Number: 54465
Big turbo car not full boosting??
I have a srt, all mods are in the sig. My problem is the car is ot boostig to what it should be. The E-manage is set at 25.9 psi but it will only boost up to around 12-13psi. I pressure tested everythig for leaks and such, but didn't find anything. I looked through the boost controller and everything is set ok. So what s the problem. I don't get it. I Even took off all the vacume lines that go to the wastegate, and to the boost controller to check if they had something in them. Everything checked out ok. So whats the deal/
Black 05 srt-4
Mods: Stage 1, AGP 60 trim DBB turbo, Boomba Fuel rail and motor mounts, RC 750cc injectors, MSD Coil and wires, Walbro 255 pump, RPM Throttle body, AGP Race frontmount, Full Maxxfab sidepipe, AGP overflow, KOYO rad, Mopar STS, Solid lower control arm bushings, Apexi SAFCII, Greddy EO-1, Inivative Wideband, Greddy Water temp, oil pressure, boost, Mopar stage 3 coilovers
485hp (C16 leaded race gas)
11.65 1/4 (slicks)
