Old 11-24-2008, 01:55 AM   #1 (permalink)
ST3PH3N'S SRT-4's Avatar
Member Number: 57024
Trader Rating: (41)
Default Best/Safest boost for my CR
I was wondering what would be the safest and best amount of boost for my compression ratio?
I have .20 wiseco pistons with a 8:8:1 CR and DCR 5 layer head gasket.
Most mods in sig.
thanks
stephen
JJ&b Built, Corn Fed SRT-4
Powered by GT35r
ST3PH3N'S SRT-4 is offline   Reply With Quote
Old 11-24-2008, 05:35 AM   #2 (permalink)
SpeedEuphoria's Avatar
Member Number: 30870
depends on the fuel octane
Project log pics
Old 11-24-2008, 09:11 AM   #3 (permalink)
Trader Rating: (41)
93 and also c16
Old 11-24-2008, 09:43 AM   #4 (permalink)
SRT of the Month
Darksyde's Avatar
Member Number: 37254
Trader Rating: (195)
Do you have a scan guage?
476whp/466tq
Darksyde is offline   Reply With Quote
Old 11-24-2008, 09:46 AM   #5 (permalink)
Trader Rating: (41)
sorta lol
(bitts scangauge in car right now)
Old 11-24-2008, 12:16 PM   #6 (permalink)
SRT of the Month
Darksyde's Avatar
Then there ya go! Watch your knock and timing and a/f Then you will know what is safe.
Old 11-24-2008, 02:41 PM   #7 (permalink)
BI_SRT-4's Avatar
Member Number: 45892
Are you looking for safety as far as knock or PSI???
Srt-4 04 E-Blue, R/C 750cc Injectors, Walbro 255 lph, Devils Own M/I M5 Nozzle, 3" Turbo back Side exit exhaust, AEM wideband, Apexi S-AFC NEO, CCA FMIC 12"x24"x3", AGP hard pipes. Upper and Lower W/ Greddy Type-S BOV
Turbonetics 54-Trim
Tial 38 MM Wastegate
Xtreme Boost Manifold
20 psi
???WHP/???WTQ
Bad Influence Auto Squad
BI_SRT-4 is offline   Reply With Quote
Old 11-24-2008, 06:38 PM   #8 (permalink)
Trader Rating: (41)
Both.
Old 11-25-2008, 04:36 AM   #9 (permalink)
Adionik's Avatar
Member Number: 51197
Trader Rating: (25)
Werd...hope these pistons can take a beating as i've just ordered 'em. I'm on stock turbo though...not .50 trim like Stephen
or 16 whatev
WTB: LCA bushings
Old 11-25-2008, 06:46 AM   #10 (permalink)
BOOSTINSRT04's Avatar
Member Number: 33061
Trader Rating: (30)
With that high of cr, you wont be able to run a lot of boost on pump due to kr, but on c16 youll be able to run a good amount! Just keep an eye on afr's, timing, and knock, and youll be good!
S256 non extended tip F/IC tuned by Aaronneon
11.88@116 1.74 60'
Old 11-25-2008, 01:57 PM   #11 (permalink)
Trader Rating: (41)
cool, thanks
from what i was reading higher CR pistons make more horses on lower boost then lower CR pistons?
Old 11-25-2008, 02:15 PM   #12 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (46)
18psi max on pump and 28psi+ on c16 (atleast that was the most I could run on 91octane)
20-23psi on 100octane and 24-26psi on 110octane.
JnR:
blue209 12.23@118 w/1.8 60ft 321hp and 390tq
tkilla 12.28@117.8 w/1.8 60ft new e85#'s coming soon
jrsrt 12.29@116.9 w/1.87 60ft
blackpearl 12.35@114 w/1.960ft 307hp and 363tq
Winecountry 12.32@112 w/1.7 60ft 315hp and 330tq
yellowsrt-4 12.5@112 w/2.0 60ft 307hp,355tq
jlozacr 12.7@110 w/2.0 60ft 301hp and 345tq
bayscksrt 12.9@110 w2.0 60ft 21psi, E85
srt princess 12.9@109 w/1.9 60ft
Kaz109 50 trim 458hp/460tq 11.54@121.78 W/1.79 60ft
reed32 is offline   Reply With Quote
Old 11-25-2008, 02:20 PM   #13 (permalink)
Trader Rating: (41)
ok cool, we have 93 octane and ive been running at 20 psi with water/meth injection
Old 11-25-2008, 02:39 PM   #14 (permalink)
2004NeonSRT4's Avatar
Member Number: 4577
Trader Rating: (44)
my 8.5:1 setup with the 5 laye.r @18psi w/meth was all 93 pump would do for me. got me 428 though so thats nothing to sneeze at.
2004NeonSRT4 is offline   Reply With Quote
Page generated in 0.17997 seconds with 13 queries
