Old 10-11-2008, 02:12 PM   #16 (permalink)
turbojack's Avatar
Member Number: 11814
Trader Rating: (123)
Yeah but TK & BC should add more info for dummies like me who search the web for info. I'm sure more then just me would see 700+ in the one link as meaning these were good for the build up like the OP was after.
Anyone reading this: Thumbs up for TK I have used them and have nothing but respect for them and will use them again for sure............please do not look at the linked page as a place to buy cheaper then TK, it was posted just to show how the info on the web is not really 100% on the money with regards to the proper application of the part being sold.
BC should be told about the way that page is billing/promoting the BC part and BC should have them reword it to reflect that BC has another rod for those needing more.
Old 10-11-2008, 02:13 PM   #17 (permalink)
chuck's_srt-4's Avatar
Member Number: 12569
I don't know where we are getting such a HUGE difference in price from the standard BC Pro Series rods to the BC625+ Pro Series rods!
The only difference is that the standard BC Pro Seires rods have the ARP 2000 rod bolts, where as the BC625+ rods use the "Custom Age 625+" rod bolts!
MY FAVORITE EQUATIONS:
Fuel Volume = (HP * BSFC) / (# of injectors * IDC)
CFM = C.I.D. * RPM * V.E. *.5 / 1728
P.R. = (PSI Boost + 14.7) / 14.7
HP = TQ * RPM / 5252
Old 10-11-2008, 02:33 PM   #18 (permalink)
supermech21's Avatar
Member Number: 42969
Trader Rating: (82)
Neither of these rods run a 7/16th rod bolt, per conversation with Dustin Spencer(tech at BC)...Its a stronger bolt, not a bigger bolt. CROWER's run a BIGGER bolt.
Call em up and get info from the horses mouth, 619-825-8719.
WANT TO BUY: Rota Subzero's...Any color is fine...Any size is fine. PM me.
supermech21 is online now   Reply With Quote
Old 10-11-2008, 02:45 PM   #19 (permalink)
DDogsrt461BLK 3.0's Avatar
Member Number: 32500
it's rpm's that kill rod bolts.
I forget the magic number but it's around 75-80Ft per second. After that no man made engine will survive period. This was something I learned by watching F1. Trust me. Do your research.
DDogsrt461BLK 3.0 is offline   Reply With Quote
Old 10-11-2008, 03:00 PM   #20 (permalink)
Trader Rating: (82)
There is no magic "one thing" that will cause them to break. If that were the case a company would step forward, fix it, and that would be the new standard....but people are still blowing eagles(mez from the realtune camp). I dont know the RPM he was at, but my guess would be arron had the car dialed in and they just couldnt take it. And seeing as how he was running a stage 3 I HIGHLY DOUBT he went over 7000rpms.
My vote is for Crower.
Old 10-11-2008, 03:05 PM   #21 (permalink)
Ghowie's Avatar
Member Number: 33090
Trader Rating: (55)
Quote: Originally Posted by turbojack View Post
From what I've seen posted the Eagles should be fine for 95% of everyone hitting this forum with a decent engine build.
there no better than stock rods and are a waste of $
Originally Posted by dansrt4
For a shop thats so behind maybe you should catch up on orders before you catch up to me.
Ghowie is offline   Reply With Quote
Old 10-11-2008, 03:07 PM   #22 (permalink)
Crower are the rods that 1st gen neon used to go over 9.55 at 140mph with so I agree with you on that.
But I'm using eagle rods, and what's to say that something else caused his engine to fail. I know the guy that micD and assembled my shortblock is point on. I'm quite certain that there's more the story then whats being told. 4340 steel isn't no hoe, and is the industry standard for making power before you or I was born.
Trust me, show me one engine that exceeds 80ft\second piston speeds, and I'll kiss your ass. It's a fact of physics, trust me!!!
Old 10-11-2008, 03:08 PM   #23 (permalink)
Member Number: 30867
really is there a link to the story about how and why the rods gave up?
Caric is offline   Reply With Quote
Old 10-11-2008, 03:25 PM   #24 (permalink)
turbojack's Avatar
Hows that? You're saying that you would do a build up with the stock rods. You would buy new ARP bolts for the stock rods, have the old bolts pressed out and then have the new ARP's pressed in and then you would have the rod journals honed out afterwords......all to save a few bucks????
There's costs associated with reusing the stock rods in a build up. For most rebuilds the issue is the pistons. So you are going to spend money on aftermarket pistons with stock rods............and probably not do anything with the clearancing the pins as well.
EDIT: I misread you're post = you think the Eagles are junk and you did not mean to say to re-use the stock rods
Old 10-11-2008, 03:30 PM   #25 (permalink)
Member Number: 15237
Trader Rating: (15)
Mez's car was making I think ~500 wtq and that's basically instant tq w/a stage 3 setup. I am pretty sure that they think the reason is insufficient bolt diameter but dont quote me.
It is mechanics of materials stuff. Figure out the material used for the bolt, its diameter, and the stress/strain allowable pertaining to the torque tht is gonna to be applied as well as the thread type and rod material. You can figure out either (a) what material must be used for that bolt diameter or (b) what the cross sectional area of a different material must be to be able to handle the shearing stress and the elongation of the bolt etc.
SRT'dOff is offline   Reply With Quote
Old 10-11-2008, 05:04 PM   #26 (permalink)
Trader Rating: (82)
Two words THANK YOU
post 14...then read on.
Old 10-11-2008, 05:23 PM   #27 (permalink)
mezturbo4's Avatar
Member Number: 17263
I agree /\/\/\
its called torque my car has a mopar pcm and a dtec no high revs here the car mad lots of torque and spooled fast no knock and held home those eagle rod bolts are the week point i have eagles in my small block they look the same but rod bolts are bigger
??????Realtune
mezturbo4 is offline   Reply With Quote
Old 10-11-2008, 10:06 PM   #28 (permalink)
tgspeedracer's Avatar
Member Number: 25328
I have been told that the crowers are pretty good however I found out that the eagle rods have an upgraded rod bolts version as well, so would that make them alot better?
Best ET 11.41
Best MPH 131
@5860ft elevation
Peak whp 567
Peak tq 607
DSP Tunned by Nick Chestnut with "Unique Solutions Tuning"
tgspeedracer is offline   Reply With Quote
Old 10-12-2008, 06:46 AM   #29 (permalink)
mezturbo4's Avatar
Save your self the worries dude have u seen the damage that happens when a rod bolt snaps. Say bye to the crank,block,pistons,valves etc pay a little more now for rods with good bolts or spend a couple grand after the rod bolts fail
just my 2cents
Old 10-12-2008, 08:08 PM   #30 (permalink)
boots's Avatar
Member Number: 67116
I'm going with a set of manley turbo tuff's for my winter build. Here's the link Manley Performance - Sport Compact
pauter, manley, and crower are top of the line. I don't think you can go wrong with either one of them in my opinion. So save up
2004 stage 2-AEM ems-DCR intake manifold-crane 16's(stock valve train)-Rage Twin disc-dss axles-boomba fuel rail-boomba mounts-boomba throtle body-3in side exit exhaust- maddog 58 STS-built trans( Rage accelerator, Rage 3/4 fork, and p-werks selector)- GT3076R
Soon to come, my high compression build New turbo setup and transmission setup
boots is offline   Reply With Quote
