Because a crappy day isn't complete without a CEL - Dodge SRT Forum
post #1 of 15 (permalink) Old 11-12-2012, 08:39 AM Thread Starter
Quoted: 0 Post(s)
I haven't owned many cars with problems, so I'm taken aback whenever I get a maintenance light like this. I don't really know how to go about diagnosing it, either, I'm just trying to drive as infrequently as possible. Is there a relatively cheap device that can read our CEL's? If not, could someone help me determine what it might be for or point me in the direction of somewhere OTHER than NTB that could help? Or any way to troubleshoot why it might have turned on?
Also I've got an ABS light on, and I know that has to do with the brakes but I don't know what...
SOLD: Black 03 SRT-4 with the following mods: S1, AGP WGA, MGW Short Throw, 3" Needswings DP (manual), Tein S-Tech's, Mopar Intake, Tial BOV, FMIC (but I'm looking for a new one!)
NOW: Velocity Red MS6 GT - one fast mofo.
atx512 is offline
post #2 of 15 (permalink) Old 11-12-2012, 08:43 AM
*ALEX*'s Avatar
Quoted: 0 Post(s)
Flip the key to read the codes
Originally Posted by lVlemphizStylez View Post
When I open my hood people think the car is on all kinds of steroids
*ALEX* is offline
post #3 of 15 (permalink) Old 11-12-2012, 09:00 AM
ggferris's Avatar
Quoted: 2 Post(s)
Turn the key from the off position to on , as in the fuel pump turns on. do not start the car. Do this I believe 3 times and the cel code will appear where your mileage is displayed. Then Google the code.
ggferris is offline
post #4 of 15 (permalink) Old 11-12-2012, 09:00 AM Thread Starter
Quoted: 0 Post(s)
I'm sorry, can you be more specific? That doesn't make a whole lot of sense to me.
atx512 is offline
post #5 of 15 (permalink) Old 11-12-2012, 10:05 AM
Quoted: 0 Post(s)
With the car off, cycle the key from the off position to the run (not start, the car doesn't turn over) position 3 times, quickly, as:
off- run, off- run, off- run
After the third cycle leave the key in the run position. The code or codes will display in the odometer. If there are multiple codes they will appear one after the other, so you may have to do this a couple of times to get them all.
Dr. Gonzo is offline
post #6 of 15 (permalink) Old 11-12-2012, 10:12 AM
TRPKelly's Avatar
Quoted: 0 Post(s)
if you have an android buy the torque app, then go on ebay and buy a elm 327 obd2 bluetooth adapter, app costs 5 dollars, adapter about 20, and you can check engine codes, clear them, see live data, all kinds of stuff
SAMSUNG-SGH-I997 using AutoGuide.C
TRPKelly is offline
post #7 of 15 (permalink) Old 11-12-2012, 11:03 AM Thread Starter
Quoted: 0 Post(s)
Wow that's so convenient! I had no idea that checking codes was that easy! I'll do that as soon as it's out of NTB getting an alignment (free alignments for a year because I bought their tires woo!). That's so helpful! Will that read the ABS light too?
atx512 is offline
post #8 of 15 (permalink) Old 11-12-2012, 01:08 PM
Boostinfamily's Avatar
Quoted: 11 Post(s)
.. abs light is usually a speed sensor problem. 9 times out of 10 anyway.. when it isn't look out since that 10nth time it is the module assembly.
most places that scan OBD2 like advanced or oreilly's can access obd2 ABS codes.. please note i said MOST not ALL.
Boostinfamily is offline
post #9 of 15 (permalink) Old 11-12-2012, 01:16 PM Thread Starter
Quoted: 0 Post(s)
Actually - I got it sorted out! While I was getting an Alignment an NTB guy ran them for free. Turns out it was something to do with my ignition key, and a second code for my power steering switch? Both very weird. However, he said that the ABS was actually front left speed sensor - @boostinfamily you were right on the money!
Now how do I go about getting that fixed?
atx512 is offline
post #10 of 15 (permalink) Old 11-12-2012, 01:47 PM
Quoted: 11 Post(s)
buy a speed sensor for the front, unplug the old sensor and take out the retainer bolt install new one. very simple.
also is your power steering notchy? if not then the pressure sensor switch is likely going/is bad otherwise look into a new P/S pump if it is notchy or noisy, as the reservoir is integrated and the filter in the reservoir on chryslers likes to plug up.
post #11 of 15 (permalink) Old 11-12-2012, 02:21 PM Thread Starter
Quoted: 0 Post(s)
Well that doesn't sound bad at all! Where is it roughly located on the car?
It hasn't felt so bad! I mean maybe in reverse a tiny bit but I've barely noticed.
I'll look into it though, thanks for all your help!
atx512 is offline
post #12 of 15 (permalink) Old 11-12-2012, 02:32 PM
Quoted: 11 Post(s)
look at the spindle/steering knuckle, it should be a little black plastic peice with a black line/wire coming off of it.
you will have to remove the tire/wheel from the hub to make it easy.
post #13 of 15 (permalink) Old 11-12-2012, 02:37 PM Thread Starter
Quoted: 0 Post(s)
Is it possible to do without removing the wheel? I currently have no access to a jack... But by that same token, a speed sensor is not an incredibly pressing thing to replace, except to remove a pesky cluster light, right? Like what's the worst that could happen?
atx512 is offline
post #14 of 15 (permalink) Old 11-12-2012, 04:50 PM
Quoted: 11 Post(s)
if you drive i winter or slippery conditions, the ABS will not prevent the wheels from lockingg up, thereby reducing your stopping potential, and possibly sending you into a spin out condition.
also the car should have a jack in the trunk, use that to lift up the vehicle, and brace it with an old steel rim or a bunch of wood blocks.
post #15 of 15 (permalink) Old 11-12-2012, 09:19 PM Thread Starter
Quoted: 0 Post(s)
No, I understand that it's important - but I live in Texas and it almost never rains. Worst comes to worst my brakes are alright, but I sure wouldn't like spinning out.
That jack's a little rusty for whatever reason and I'm not really comfortable using it ): I just need to borrow a buddy's, I'll take care of it in the next week or two. Thanks for the input!
atx512 is offline
User Tag List
Linear Mode Linear Mode
