balance shaft ?'s - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 12-01-2012, 06:25 PM   #1 (permalink)
2fast4u450's Avatar
Member Number: 91464
Default balance shaft ?'s
just picked up a 04 srt4 today and was getting alot of dash shaking. if i pushed the clutch in while at a roll it would go away and all was good, no shaking at idle unless i revved it up. so im starting to think the balance shafts r out of time, could this be it? the guy i got it from told me he had dodge put a clutch kit in it, no slipping and pulls really hard at 21psi. thanks for any help
2fast4u450 is offline   Reply With Quote
Old 12-01-2012, 06:27 PM   #2 (permalink)
Fresh Meat Moderator
tunerlover3's Avatar
Member Number: 76568
Is this your first neon?
It probably has solid motor mounts which will cause a vibration that you will eventually get used too.
Diablo CMR tuner ~Dan~
310HP 436TQ
2004 Eblue Neon SRT4: E85 5558 Built motor
XXXHP XXXTQ
Old 12-01-2012, 07:58 PM   #3 (permalink)
2fast4u450's Avatar
yeah its my first, iv never been in a car that vibrated this much, i didnt know if it was something i should worry about. thanks for the reply
Old 12-02-2012, 03:55 AM   #4 (permalink)
badboydneon's Avatar
Member Number: 63272
Like mentioned its most likely solid mounts. Open the hood and check or take a pic if your unsure and we'll let u know.
2004 Black SRT-4-
Mopar Stage 3 with the works
2003 Silver SRT-4-
BW s200sx-rs-56 .63ar
1997 Black 1G, 2.4 built and turboed-project
Any1 local in need of PCM flash...hit me up
badboydneon is online now   Reply With Quote
Old 12-02-2012, 06:42 AM   #5 (permalink)
2fast4u450's Avatar
ill take a pic of the upper and lower mount, how can i tell if the turbo is stock? and for the 93 octane tune is 21psi right on stock turbo? i got a diablo tuner with it but have no clue how to use it.
Old 12-02-2012, 06:58 AM   #6 (permalink)
silver_ek's Avatar
Member Number: 60962
the 93tune would put u in the 20+psi spike range depending on weather. Does the car have a wideband gauge? If not, get one asap.
"Duster360 knows his $hit"
silver_ek is online now   Reply With Quote
Old 12-02-2012, 07:09 AM   #7 (permalink)
2fast4u450's Avatar
yeah, it stays around 14.7 to 14.8
Old 12-02-2012, 07:34 AM   #8 (permalink)
What does it read at wide open throttle?
2004 Black SRT-4-
2003 Silver SRT-4-
Old 12-02-2012, 08:41 AM   #9 (permalink)
2fast4u450's Avatar
I'm not sure but ill find out right quick.
Old 12-02-2012, 10:06 AM   #10 (permalink)
2fast4u450's Avatar
ok, it was all over the place from 13.5, 14.2, 14.8, 14.9 and at one point it penned and had no reading just dashes ----
I do have a greddy boost controller but dont know how to work it. i really just need to find a tune shop in the nky/cincinnati area. i dont think the guy i got it from knew what he was doing at all. i wish people woudnt mess with stuff they dont know nothing about.
Old 12-02-2012, 10:20 AM   #11 (permalink)
n00b-SRT's Avatar
Member Number: 90935
Its's reading that high at WOT?
Wide Open Throttle (while u floor it).
The "--" should be when you're decelerating i believe, or when you kick it to Neutral.
n00b-SRT is offline   Reply With Quote
Old 12-02-2012, 11:38 AM   #12 (permalink)
Stop going wot.
You need to check out what is causing the wideband to read that high. What kind of wideband is it?
If the AFR was actually that lean though, you would have blown the motor already.
Take some pics of the exhaust to see where the wideband sensor is in the exhaust.
310HP 436TQ
XXXHP XXXTQ
Old 12-02-2012, 11:43 AM   #13 (permalink)
khaoSrt4's Avatar
Member Number: 62825
Damn that's lean just stop flooring it the love love of god. Turn down the boost till you get your afrs right
khaoSrt4 is offline   Reply With Quote
Old 12-02-2012, 12:02 PM   #14 (permalink)
93stang434's Avatar
Member Number: 49690
You've never been in a car that vibrated this much and you still bought it.Now after buying the car your doing research
Built short block,cncport.com head,BW s256
and and some other stuff=Aiming for the 10's on E85
BC co's,Hotchkiss sways,Prothane bushings,Pwerks strut bars,Mopar tension struts
93stang434 is offline   Reply With Quote
Old 12-02-2012, 04:14 PM   #15 (permalink)
2fast4u450's Avatar
yeah i couldnt pass it up, iv been looking for one for about a month and had to drive 2 1/2 hours to get this one. but after doing some research i found out it has solid motor mounts. there is zero play with the motor.
