Old 07-07-2008, 03:23 PM   #1 (permalink)
turbovanman's Avatar
Member Number: 44565
Question Anyone know the torque setting for Eagle rods?
I have some Eagle SRT4 EDZ rods is it? anyhow, they have the 12 point arp bolts, lost my torque numbers. Thanks.
1989 Dodge Caravan-2.5L TIII 16v DOHC 13.3@96mph @21 psi, no 3rd gear,
1991 Spirit R/T-have all the parts, no time to get it running yet,
turbovanman is offline   Reply With Quote
Old 07-07-2008, 03:28 PM   #2 (permalink)
SpeedEuphoria's Avatar
Member Number: 30870
Simon check the dia of the bolts, I think they made 2 different ones, most are 5/16" but some are 3/8" bolts.
I did some reading on a couple ARP bolts, it seems for 5/16" ~35ft/lbs w/ oil(stretch 0.0048-0.0052 in) and 3/8" ~48-50ft/lbs w/ oil(stretch 0.0055-0.0059 in). Not sure if this is correct
Heres other info
Eagle Rods;torque specs
I also found this which says what the post says: (I assume these are with moly lube)
3/8" ARP 2000 Rods Bolts - 7/16" Bolt Head - 43 ft. pounds or .0055" - .0059" Bolt Stretch
5/16"" ARP 2000 Rods Bolts - 3/8" Bolt Head - 28 ft. pounds or .0048" - .0052" Bolt Stretch
so by this you should be able to tell by the hex head what size they are.
Project log pics
Old 07-08-2008, 02:28 PM   #3 (permalink)
Thanks, I believe there 3/8, but won't know until tonight when I pull the pan.
Old 07-08-2008, 03:25 PM   #4 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (554)
Deppends on what bolts the used, if they are the 2000 series I think you have to use a gauge to measure them.
Old 07-08-2008, 03:31 PM   #5 (permalink)
Remember that most of the bolts built for Eagle are "single use only" so make sure you don't lossen them then re-tighten them it could cause a failure issue. This is directly from Eagle Rods so please don't flame the messager.
Old 07-08-2008, 04:00 PM   #6 (permalink)
California Moderator
Mana4real's Avatar
Member Number: 25021
Not flaming, but I thought you could re-use the rod bolts? I mean don't you have to plasti-gauge the rod bearings to make sure the clearances are correct? Just for my own curiosity. Thanks John
-Matt- -SCT Tuned- By Yours Truely
05 SRT-4 Stage 3 47lb FP Green
Old 07-08-2008, 05:01 PM   #7 (permalink)
I was told in an email that the rod bolts built for Eagle are a one time use. The ones for the SRT4N anyways that are marked ARP 2000. I have spares here just in case of that happening.
Old 07-08-2008, 07:55 PM   #8 (permalink)
Mana4real's Avatar
If I remember, I will call ARP on it... That's wierd... I wonder why.
Old 07-09-2008, 11:24 AM   #9 (permalink)
Mana4real's Avatar
Ok, so I just called ARP. They said that they can be reused. The only time they can't be reused is if they have been stretched more then 0.001" ... You check stretch when they are untorqued.... I hope this clear some stuff up. Didn't want to burst your bubble John, but that didn't sound right. I was very specific with exactly what I was talking about also.
Old 07-09-2008, 12:04 PM   #10 (permalink)
Thanks guys.
I also didn't think they were one time bolts.
I still haven't got it apart yet, too busy doing real work,
Old 07-09-2008, 12:33 PM   #11 (permalink)
I knew there was something to do with the "stretch" of the bolts. I made a post on that but was also told that "one time use" was common replacement.
Thanks for clearing that up for me and the others on here. No bubble bursting, we just have the proper info now.
Old 07-09-2008, 01:02 PM   #12 (permalink)
Mana4real's Avatar
Cool
Page generated in 0.23865 seconds with 13 queries
