a 60trim with a stage 3 turbine and .48ar at what kind of rpm he will spool
thanks
dont do it, the .48 a/r negates the whole big turbo, 60 trim is better for flow not pressure (lower psi with more cfm), so you will get more back pressure and hotter temps with a 48 turbine that has a compressor designed for low psi and cooler temps sounds like surge city to me
w/ a .48ar and 3800? or are ya talkin about normal?
my 50t/.48ar hits 20psi by 31-3200. a 50t/.63 does so at 34-3600 on avg.
so basically take w/e youre spoolin now, and cut it down by ~400rpms. the problem you will probably run into is the issue that the 60t will probably surge to no end on a .48ar..
i thinl i will go with a 50trim with .48 ar must be better as a daily driver
for a daily driver i would strongly recomend a stage 3 kit, it may look expensive but after all costs are accounted for it will be much cheaper than a big turbo kit, without the hastle of tweaking it all the time
Yeah i didnt take that into effect....witha .63 full spool is aorund 3800....
You think surge happens with a smaller AR? Couldnt it still surge with a .63? or less often?
I was just going to say something similar...my 3147 w/ .63 hits 22 psi around 3100-3200 thats only a 47lb wheel...but I haven't tried it on the new mani yet
