Old 06-25-2008, 08:45 PM   #1 (permalink)
Member Number: 51755
Default 60 trim 1.15 a/r
what are u guys opnion on this turbo, with nitrous, what rpm im looking at for full spool
i got a big race on the 19th,i need all the help i can get.......so got this two days ago,waiting for it to get here...but will it make a big diffence.....i have a built engine and head with the 2.0 cams.....
or should i just keep my 50 trim .48 a/r in and boost it on 28 with c16 ,i need to get into the low 11s on the track, thanks
agp 50 trim,agp returnline,agp hard pipes,meth injection,cai,teail bov,agp motor@tranny mounts,3inch full exhust,no cat,wideband,thu boost,udp,bfmic,255 fuel pump,grounding kit,,msd wires-coil-tech ad,afc neo,stage 3 c/m clutch
corvette303 is offline   Reply With Quote
Old 06-25-2008, 08:48 PM   #2 (permalink)
bene's Avatar
Member Number: 53801
Trader Rating: (24)
thats huge, you would definately need nitrous to spool that thing in decent time.
"you know its fast when it has a oh-shit handle for the driver"
bene is offline   Reply With Quote
Old 06-25-2008, 08:48 PM   #3 (permalink)
Buy/Sell Moderator
uncommonŠ's Avatar
Member Number: 39843
Trader Rating: (131)
I honestly don't think that is a 60 trim ... that has 8 blades, my garrett 60 trim has 6 blades
that is a .60 a/r compressor housing ... totally different than a 60 trim
with a 1.15 a/r turbine housing, that will spool late regardless of what turbo it is ... the complete total opposite of your 50 trim .48 a/r
IMO, I'd stick with the 50 .48
11.9 @ 126
uncommonŠ is offline   Reply With Quote
Old 06-25-2008, 08:58 PM   #4 (permalink)
listen i got a guy in a stang talking shit, and called me out for a race in s.a. track on the 19th, i know hes 11.8 with slicks, i love my 50 trim ,but i never took it to the track with the 50 trim, so far....well i got money on this race and need my car to hit the low 11s..... i know my car is quick right now... but i want to make sure this will work,if it dont i will be laghed at by all the corpus racers....this is a big race.... i got the window swicth, wet kit, turbo,heater ,presser gauge,...........
will i see a difference in power??????with the right tune
Old 06-25-2008, 09:00 PM   #5 (permalink)
Buy/Sell Moderator
uncommonŠ's Avatar
if you have a wet kit then hook it up & spray in 4th ...
slicks + 50 .48 + 75ish shot in 4th = some impressive timeslips ... you could easily trap 130 with a good tune and with a good 60' (1.7-1.8) you could easily run a low 11 ... assuming that you have the driver mod
Old 06-25-2008, 09:01 PM   #6 (permalink)
addictedtosin's Avatar
Member Number: 30537
Trader Rating: (114)
with a 1.15 AR it should spool sometime early next year.
12.0@120 on DRs and 93oct.
addictedtosin is offline   Reply With Quote
Old 06-25-2008, 09:08 PM   #7 (permalink)
Member Number: 64760
Trader Rating: (17)
this thread is hilarious!
91PumpKing. is offline   Reply With Quote
Old 06-25-2008, 09:12 PM   #8 (permalink)
really,so if i put my boost at say 26psi with c-16 with my drs,and 75 shot in forth,i have a good chance at low 11s,im a good driver.
Old 06-25-2008, 09:16 PM   #9 (permalink)
well i know a srt with a .83 halfback 60 trim thats doing 11.6s out of kingsville,with a 65 shot. thats why im going this way ,but hell if i can get the same times with my current turbo, and a little gas in forth...im all for it
Old 06-25-2008, 09:20 PM   #10 (permalink)
Trader Rating: (17)
just stray from mid 3rd thru 4th...
low 11s would be EASY w/ the 50t/.48ar on 26psi/c16 and n20...
Old 06-25-2008, 09:35 PM   #11 (permalink)
so i spray all of forth gear or set the window swich for 5k???
Old 06-25-2008, 09:39 PM   #12 (permalink)
Buy/Sell Moderator
uncommonŠ's Avatar
if it were me, I'd start off with the window switch set up for 3500-5200 ... then if you want more, raise it to 5500
hopefully you have strong arms, the car will more than likely have some crazy torque steer
Old 06-25-2008, 09:44 PM   #13 (permalink)
Member Number: 19821
Dude I've seen a lot of those turbos.
It is a 1.15 A/R housing, P trim wheel
V-trim T04B compressor wheel in a .60 A/R T04B housing
It is commonly sourced from Case Loaders
It was a common heavy equipment turbo from the 70's and 80's
Dohc Rocks is offline   Reply With Quote
Old 06-26-2008, 01:45 AM   #14 (permalink)
soooo ,is that good or bad???
Old 06-26-2008, 01:50 AM   #15 (permalink)
lilmike0450's Avatar
Member Number: 56278
spray with the fiddy and you should be fine...Y make a bet with someone you know that is gonna spank your ass.
05 White ACR
lilmike0450 is offline   Reply With Quote
ť Wheel & Tire Center
Page generated in 0.19476 seconds with 11 queries
