60-1 owners? post setups & dynos here - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 09-28-2008, 10:59 PM   #1 (permalink)
SRTforums Admin
Flame's Avatar
Member Number: 37340
Default 60-1 owners? post setups & dynos here
Sticky.
Quote: Originally Posted by fl00ples View Post
7" is perfect!
Flame is offline   Reply With Quote
Old 10-17-2008, 05:06 PM   #2 (permalink)
HCCAFan's Avatar
Member Number: 35768
No one has one?
HCCAFan is offline   Reply With Quote
Old 10-19-2008, 10:31 AM   #3 (permalink)
SRT of the Month
bitts's Avatar
Member Number: 29842
no. no one does
bitts is online now   Reply With Quote
Old 10-19-2008, 02:08 PM   #4 (permalink)
Member Number: 64760
TKMS did a while ago.
91PumpKing. is offline   Reply With Quote
Old 10-19-2008, 02:35 PM   #5 (permalink)
supermech21's Avatar
Member Number: 42969
HCCAfan, them dogs are beautiful in your avatar...
I have some questions about this turbo, from what i can collect they shine at 27-28lbs, not good on low boost. Now its easy to say, the turbo doesnt pull on low boost blah blah blah, why??? Does it just feel sluggish? Or will a 50 trim on 20lbs vs a 60-1 on 20lbs the 50 trim will win? I would assume for simple spool issues the 50 trim will pull harder but the 60-1 can make and hold power longer into the powerband correct? If price were no issue a BWs256 would be the best of both worlds from a 50 trim and 60-1, correct? fast spool and the ability to hold power long into the power band, correct?
the 60-1 has always intrigued me but i see little no info on them, a lot like this thread.
Are they any other numbers out there other than erabbits old set up, 490ish on stock cyl head/cams, built bottem end, smim, ems...touch of god tuning...
Sold.
2011 Ford F150, FX4, Eco Boost...
Old 10-19-2008, 02:37 PM   #6 (permalink)
erabbits car was a 60t...fairly different from a 60-1 fwiw.
Old 10-19-2008, 03:01 PM   #7 (permalink)
Member Number: 15237
Yeah eric's car was 60 trim NOT 60-1 definitely different turbos.
I had a 60-1 couple years ago hp mani etc etc never got it running right poped the HG.
Check this link out some info on a 60-1 setup with numbers. I don't know if i'm buying 520 whp on an SAFC 2 and a stock motor but I guess you never know.
Click me some info
2004 SVT Cobra
SRT'dOff is offline   Reply With Quote
Old 10-19-2008, 08:12 PM   #8 (permalink)
I didnt know what eric had on his car, mah bad. What si the difference, i was explained this once but didnt really care at the time. Is one an actually 60lb comp wheel and the other is a 55 i think? What are the difference in them?
Sold.
Old 10-19-2008, 08:17 PM   #9 (permalink)
60lb is a 60-1.
53lb is 60t.
both typically use a "stage 3" turbine wheel.
Old 10-19-2008, 08:37 PM   #10 (permalink)
So a 60 trim is barely any bigger than a 50 trim...correct?
So comprably the the 60-1 DBB has near the same spool and power out put as a BW s258...60lb wheel/DBB v.s. 58lb wheel/ET .....and both near the same price, 1200 for 60-1 and 1100 or so for the BW...
Just out of curiosity(i havent seen many BW in person) but the BW runs a journal bearing(non DBB) but with a extended tip to help with spool. If thats correct what if a DBB chra was used with the ET technology and a 60lb wheel...kind of a hybrid of a hybrid...anything like that out there? Im sure the price tag would be near 1600 and IF it all lined up the spool would destroy a car on the street but still would be fun...
Sold.
Old 10-19-2008, 08:47 PM   #11 (permalink)
50t - t-netics: 49lb, garrett: 46lb, agp: 50lb
so depending on the model, its pretty similar.
borg warner doesnt offer a dbb chra. a few shops have done a dbb for their shop cars tho. im sure it was all custom work, and cost a pretty penny.
considering a s256 spools at 36-3800, i can only imagine the s258 would be at 3800-3900. at that point, better off goin 3082 or 35r/.63 and get alot more power potential.
Old 10-19-2008, 09:00 PM   #12 (permalink)
and those turbos run? CHRA? Compressor wheel?
Sold.
Old 10-19-2008, 09:07 PM   #13 (permalink)
no specs. all i know is an independent shop (non-vendor) sent it out and got it converted. dont know to where. it was a s256.
Old 10-19-2008, 09:38 PM   #14 (permalink)
no no no...specs on the 3082 and 35r? as far as chra and wheel size
Sold.
Old 10-19-2008, 09:42 PM   #15 (permalink)
ooo. my mistake.
3082 = 35r compressor/30r turbine. 580-600 capable. ~3700-3800 spool verified by 3 others w/ em on here. use the .82ar w/ this to alleviate pressure since there will be a larger amount of back pressure due to the 30r turbine
