Old 04-12-2008, 12:29 AM   #1201 (permalink)
NoisufnoC's Avatar
Member Number: 136
Quote: Originally Posted by foxracing12002 View Post
done got mine already
good shit! sat there and b.s.'d with josh while he was doin my itm, tb, and spacer. he's a good guy and does killer portwork.
when were you in vegas?
omgz!! i haz mods!!
NoisufnoC is online now   Reply With Quote
Old 04-12-2008, 07:07 AM   #1202 (permalink)
bigwoofers.net's Avatar
Member Number: 31703
I've been considering a ported intake mani and TB.. Let me know what kind of results you guys get.
bigwoofers.net is offline   Reply With Quote
Old 04-16-2008, 07:18 PM   #1203 (permalink)
Jagok1's Avatar
Member Number: 14366
Quote: Originally Posted by NoisufnoC View Post
how would meth injection help with spool?
I think he meant as in "turn the boost up"
AGP GT40 ~ 460HP/430TQ by DSMLights
WTT: GT40 for S3Delta 47lb
Jagok1 is offline   Reply With Quote
Old 04-19-2008, 06:52 PM   #1204 (permalink)
CrEaTrE's Avatar
Member Number: 28234
Finally got the car tuned today to 21 psi. Pulls like a freight train. Should have dyno soon.
Old 04-20-2008, 09:48 AM   #1205 (permalink)
Member Number: 34014
Hey guys got a quick question my car has this hesitation @ almost exactly @ 2k rpm...my tuner say that's how all 750cc injectors equipped SRTs act...I kinda believe him cuz he built a 700+ horse power Srt4...but dam its annoying..anyone elses car does this??
Another BIG Turbo SrT-4 by DsM-LiGhTs
PrOjEcT "PaStElAsO" underway...
NvDiSRedSrT is offline   Reply With Quote
Old 04-20-2008, 10:03 AM   #1206 (permalink)
95neonman's Avatar
Member Number: 37749
What are you tuned with? If you have a piggyback (safc, dtec) then yes it is common.
Agp DBB 50trim
Old setup- K&N cai, agp wastegate, MPx 3" tbe, MPx FMIC, JMB upp w/turbo xs rfl, Maddog sts, bfg dr's on kosei k1's- 13.1@108 2.0 60'
95neonman is offline   Reply With Quote
Old 04-20-2008, 12:08 PM   #1207 (permalink)
05commemorative88's Avatar
Member Number: 52296
Trader Rating: (25)
Well I just got my car back from a local guy that ports and polishes. Had my intake port matched to the head and matched to the TB. All I have got to say is night and day difference. It helped spool, pulls all the way through the rpm band hard as hell. Well worth the money. I will post some pictures of this guys porting when he sends me them.
05commemorative88 is offline   Reply With Quote
Old 04-20-2008, 12:11 PM   #1208 (permalink)
NoisufnoC's Avatar
Member Number: 136
i've got a FBM race intake combo sitting on my spare room floor since my car is down waiting for parts.
in short, my friend and i broke my intermediate shaft backet (the one that is attached to the shaft), and the cooler for the oil filter.
i'm waiting on my PTP big filter kit and the new intermediate shaft from S&P
on a lighter note, i'll be installing a NDE TCS when the new harness arrives
Old 04-20-2008, 01:49 PM   #1209 (permalink)
str5010's Avatar
Member Number: 34460
I installed my ported intake manifold, tb, and spacer this weekend but had nothing but problems. My car first had issues witht he RPMs hanging when coming to a stop. Then while crusing it would just start bucking and backfiring. Sometimes it would almost stall at idle. The gas pedal had a dead spot in the beginning of its travel and it was noticeably stiffer to depress. After checking that the TPS was fine and boost leak testing to make sure there were no leaks I put my stock TB on and all the problems went away. So there is something wrong with the ported TB that I need to get fixed this week.
Having the NDE TCS is nice. I still get wheelspin, but it's so much better before. Hopefully I can get this TB problem figured out so I can take the car to the track on May 2nd to see how it runs with the TCS and AGP flash.
str5010 is online now   Reply With Quote
Old 04-20-2008, 08:05 PM   #1210 (permalink)
Trader Rating: (25)
Call and talk to Kevin at AGP. I noticed the hanging up at like 1700 rpm when coming to a stop and then it would settle back down. I will be calling him on Monday to see what I need to change the ported intake. I reach full spool (cruising in 3rd at 3000 rpm and stomping it) at just under 3600 rpm (21psi). Car runs real strong.
Old 04-21-2008, 04:48 AM   #1211 (permalink)
str5010's Avatar
Well I only had the hanging RPM happen when I had the ported TB on the car and now that it is off again the car runs fine. I never had a problem with the AGP flash. I only got to make one pull with the car when having all the ported stuff on and I noticed that I hit full boost(24 psi) @ 3200 rpm in 4th. I hope it will shorten the spool time a little in 3rd because before I wasnt seeing full boost until 3600-3800 rpm before. I wont have a chance to work on the car until this Friday at the earliest.
Old 04-21-2008, 05:57 AM   #1212 (permalink)
SRTie4k's Avatar
Member Number: 45499
Trader Rating: (31)
What TB did you get? Sounds like the plate leaks.
Old 04-21-2008, 07:07 AM   #1213 (permalink)
str5010's Avatar
It's from DCR. Ive talked to Darrell and as usual DCR is providing awesome customer service and is sending me another ported TB today. Ill be back home again on Friday to put it on the car and try again.
Old 04-21-2008, 01:25 PM   #1214 (permalink)
Member Number: 41700
I am not positive about this but I believe the previous owner of his car went 11.69 @ 128 or 129 at Island Dragway. That was before the addition of a ported race head. I am not positive on those numbers though.
I CRUSH DREAMS FOR A LIVING
Old 04-21-2008, 01:26 PM   #1215 (permalink)
str5010's Avatar
Quote: Originally Posted by nutz View Post
What is that all about. There is video of this run on his MySpace page. 28 psi boost and slicks.
We operate more than 100
