Old 05-22-2006, 12:52 PM   #76 (permalink)
Member Number: 13142
Quote: Originally Posted by Kustomatix
Quote: Originally Posted by 96TSi
no shit heh. i never thought the 577cc injectors could safely support 20psi. good tuner i guess
a good tuner indeed
seltech is offline   Reply With Quote
Old 05-23-2006, 05:23 PM   #77 (permalink)
RyeLou's Avatar
Member Number: 27885
Got my car back last night.
Garrett 50 trim turbo with Borg Warner compressor wheel
API exhaust housing/O2/downpipe with cut-out
CTI FMIC
JMB intake
P-Werks return line
S2 injectors
Dtec
ACT clutch
Quaife LSD
No #'s on it yet. It's tuned at 18psi and we have more room to go. We left it at 18psi to break the clutch in, and when it goes back for the LSD install they'll tweak it a bit more to 19/20psi. Right now I'm hitting a peak of like 11.2 AFR in 3rd, so it's still plenty safe enough.
Even at 11.2 AFR and 18psi, it pulls so F'ing hard.
'03 SRT-4
'05 Evo
RyeLou is offline   Reply With Quote
Old 05-25-2006, 04:28 PM   #78 (permalink)
mil
mil's Avatar
Member Number: 34034
Trader Rating: (18)
finally got in pump,injectors,afc, and return line!....................399hp/393tq@22psi/pump gas
smaller run was stock turbo......
EVERYTHING i read on SRTforums is true
mil is offline   Reply With Quote
Old 05-25-2006, 05:12 PM   #79 (permalink)
Member Number: 10209
Nice numbers, upgraded FMIC? 22psi on 91 or 93 octane?
-AGP-Blitz-ClutchMasters-Engine Run up-E.D.-JLM-HKS-Hotchkis-MSD-Turbo XS-Walbro-
mark2685 is offline   Reply With Quote
Old 05-25-2006, 06:25 PM   #80 (permalink)
mil
mil's Avatar
Trader Rating: (18)
cca front mount on 93 octane..........
Old 05-29-2006, 09:27 AM   #81 (permalink)
j2talc's Avatar
Member Number: 10319
Trader Rating: (36)
Well I just put in my 750s, walbro 255, and changed the wastegate spring. Now Im boosting 23psi and its a huuugee difference. I hope to get some new numbers up soon.
j2talc is offline   Reply With Quote
Old 05-29-2006, 09:50 AM   #82 (permalink)
do you got a wideband? a lot of boost on pump w/out a wideband.
Old 05-29-2006, 08:19 PM   #83 (permalink)
j2talc's Avatar
Trader Rating: (36)
I dont personally have one yet but I have been using two of my friends..my afr's are in the 11's
Old 05-29-2006, 09:37 PM   #84 (permalink)
RyeLou's Avatar
Thats pretty bad ass then. I'm thinking of taking a slight bump up to the RC 650's or those new drop in ones from Deschtek or something like that in their 750's (750 rated at 58psi)
Old 06-07-2006, 01:12 AM   #85 (permalink)
Member Number: 25709
Trader Rating: (82)
Quote: Originally Posted by wannasupra
i'm going for 400 whp on stage 2 injectors.
i did it and had plenty of fuel to spare with the 85 psi fpr mod was pullin +20% for 12.2 a/f's...Ptp mod=gone now RC750's,bigger Tb, boomba Im gasket,and an AGP race FMIC instead of the CCA new #'s soon...well after i fix this dam tranny
50 trimmed srt4 to evo9 to 04 GT Cruiser?
slow04srt4 is offline   Reply With Quote
Old 06-07-2006, 07:07 AM   #86 (permalink)
SRT Videos Moderator
Lagzilla's Avatar
Member Number: 4098
Trader Rating: (26)
just so some people know 85 psi of fuel pressure is allot.
06 Honda S2000 Rio Yellow Pearl - K&N FIPK II
SOLD - 04 AEM EMS'd SRT
XBOX LIVE - "LawStudentLaggy"
Lagzilla is offline   Reply With Quote
Old 06-07-2006, 07:21 AM   #87 (permalink)
Trader Rating: (82)
85= alot and the car didint really drive that great w/it but it got the job... car drives 100% better with 750's on the stock fpr
Old 06-07-2006, 10:09 PM   #88 (permalink)
RyeLou's Avatar
I'm at 43psi rising rate right now I think on the return line on S2 injectors. We're going to bump it up a bit to about 50/55 I think and tune for more boost. I'll see how daily driving is with that and we'll see if I leave it there.
Has anyone gone with that high of PSI on a return line? Did it work out okay when you weren't WOT?
Old 06-07-2006, 10:27 PM   #89 (permalink)
Lagzilla's Avatar
Member Number: 4098
Trader Rating: (26)
yes
How Much Are You Pulling? SAFCII
running 750s pump return line 20 psi GT40
running 55 static fp no vac source pulling -15% - -19% on hi vs my old setup pulilng -30%+! less out of the map is better
Old 06-07-2006, 10:44 PM   #90 (permalink)
RyeLou's Avatar
I'm talking about running 50/55 rising rate though, not static.
Either way, I'll have to experiment with mine. I have a safe AFR of 11.2 in 3rd gear, and I'm only at 43psi with the vac. source hooked up, so I have room for more power. I'm running 19psi on the turbo now, and I'd like to get 21 out o fit. I'd like to get close to 400whp with the return line and S2 injectors.
Oh, and I'm 50 trim too, not GT40
