Old 10-19-2009, 10:04 AM   #1 (permalink)
Member Number: 40271
Default 50 trim question
Anyone running the Garrett 50 trim? Looking to pick one up
T3/T4 57trim turbo w/.48 A/R, 750cc Deatchworks inj, MPX intercooler, JMB 4'' itake, Diablo Tune, JMB 3'' w/B&B 3'' catback, JMB engine powdercoat, S style headlights, Mopar coilovers, MPX 62mm TB with matched intake, Motegi 17'' wheels
brandonaddis is online now   Reply With Quote
Old 10-21-2009, 10:53 PM   #2 (permalink)
anyone?
Old 10-23-2009, 12:40 PM   #3 (permalink)
silver_ek's Avatar
Member Number: 60962
search
Commerative Edition #118/200
Stage 1 pcm/3'' MAXXFAB SEE (no cat)/AEM cai modded to sri w/ AEM dry-flow filter/AGP WGA/AGP UHP/AGP screw in sensor/HKS SQQV/Granetelli performance wires/Motor Mount Inserts/Dual Bwoody Catch Can Set up/JMB Coil heat shield/JMB tranny cover/Rolled rear bumper mod/10kHID/8k HID fogs/Clarion 7-inch touch screen cd/dvd/mp3/ipod/sirus in dash single din
blue=fs
silver_ek is offline   Reply With Quote
Old 10-30-2009, 07:09 PM   #4 (permalink)
Member Number: 57123
I had the same question LOL...
Ive tried searching and no good info... You cant compare it to the AGP 50 trim because the AGP flows 50LBS per minute when the GARRETT flows 46lbs per minute so there different. i too am interested in this......
BUMP
HP61(Blown),Porfueler, Mapclamp,Greddy Profec II EBC, AGP Hard Pipes, Synchronic BOV, MPX BFMIC, Race motor mount inserts, MSD Cap and Wires, Needswings Downpipe w/cut out, AEM Wideband, AGP CAI.
Best time on Garrett 50 trim 12.3 at 113MPH.Elevation 4,XXX.
on 26PSI. Boost leak maybe?
Garrett 50 trim SOLD
20g turbo kit SOLD.........
up_in_boost is offline   Reply With Quote
Old 10-31-2009, 06:54 PM   #5 (permalink)
Rhunter's Avatar
Member Number: 36794
BUMP
I'm in the same boat as you gents. I purchased a gently used kit that has a rebuild Garrett 50 trim.
If you guys find anything post it up
Old 10-31-2009, 06:56 PM   #6 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (92)
agp 50 trim is not 50lbs per min
AGP S256 FS
Old 11-02-2009, 09:38 AM   #7 (permalink)
OK my bad its 49LBS per min...
Old 11-02-2009, 12:58 PM   #8 (permalink)
AGP Turbochargers, Inc. :: AGP Turbos :: AGP 50 Trim
It says 50lbs/min
Old 11-02-2009, 01:17 PM   #9 (permalink)
Rhunter's Avatar
I've heard that the Garrett 50 trim are 47lb wheel?
Old 11-02-2009, 04:04 PM   #10 (permalink)
Kason23's Avatar
Member Number: 34502
Trader Rating: (20)
Get a AGP 50T. Its newer technology. Spools faster and makes more power. I mean its
a faster spooling 50/lb wheel vs. a slower spooling 46lb wheel. Ill take the AGP thanks.
Tuned By TDSAaron!!
My Goal: 100+Mph in the 1/8
Kason23 is online now   Reply With Quote
Old 11-03-2009, 01:11 AM   #11 (permalink)
Member Number: 65436
Trader Rating: (31)
I agree with kason, go with a agp 50 trim .63 back half journal bearing and you'll still be full boost by mid 3k rpms, or go with the .48 backhalf for even faster spool but a little less power in the top end.
cody187x is online now   Reply With Quote
Old 11-03-2009, 04:16 AM   #12 (permalink)
Rhunter's Avatar
Are you sure about wheel size?
AGP Turbochargers, Inc. :: Garrett Turbos :: Standard Bearing :: Custom Assembled T3/T04E
Old 11-03-2009, 04:24 AM   #13 (permalink)
lyncoo's Avatar
Trader Rating: (92)
i was thinking it was a 47lb wheel but agp site says 49lb hmm
Old 11-03-2009, 05:01 AM   #14 (permalink)
Kason23's Avatar
Trader Rating: (20)
I believe it was brought up to agp. And they replied that's what it's rated at but It does not flow that much. I will let them chime in of course. I do know they spool slower most def tho.
Old 11-03-2009, 11:15 AM   #15 (permalink)
its 46 vs 49....
Page generated in 0.17052 seconds with 13 queries
