Old 07-12-2008, 05:14 PM   #631 (permalink)
mad1's Avatar
Member Number: 26914
Trader Rating: (10)
Bump it up if you can. I know timing can create knock if you can't control it. 388 hp and 420 lbs tq at 24 psi on 94 octane with ems controlling boost also.
Ems reduced timing on top end.
Runs great. And is very quick for a pump gas street driver.
Been up to 400hp on Dtec ( which took a shit) but have better dyno graph and increased rev limit ( to 6,700 rpm now) so was reduced a bit to get the best overall map.
3147, AEM EMS, 750's, DCR oil kt, Oil mod, DCR TB, SBC 5x , MD 72%, MAXF 3" See /res, AGP w/HKS, LC-1 WB, Raptor Shft Lt, Agp RTL w/pump. SBeast ic , AGP solids , Injen SRI. 30lb gg , billet sel, F&F P&P intake,WOT box. Stage 1 springs. 20% tint. KTP Sport alloys
Aaron tuned. Rick built.
388 hp and 420 tq at 24 lbs @ 94 w/6700 redline
11.95 @ 119.7.. 1.88 60'= pump gas & slicks
mad1 is offline   Reply With Quote
Old 07-14-2008, 09:29 PM   #632 (permalink)
DrRafy's Avatar
Member Number: 14422
Does anybody have Dyno #s with the SCT. Im looking between this kit and the AGP S3D 48lbs, my mods in sign. my goals 400-450whp; Any recomendations? Thanks.
Mopar S2 w/o Toys, Mopar Short Shift, Mopar Catback, Mopar Tail lights, Ingen Short Ram Intake, Greddy Turbo Timer, JMB Oil Catchcan,MSD Ignition, MSD Wires, NGK Plugs, JMB Powder coated Upper & Lower Pipe with HKS SSQV BOV, Megans Coilovers, ACT Xtreme Clutch with a billet flywheel, Optima Battery, Full Leather Interior, Pioneer 6*9 330w, Pionner 12CD Changer, SoundStorm 2 10" 600w, JVC AMP.
www.myspace.com/rafysoto
DrRafy is offline   Reply With Quote
Old 07-15-2008, 09:01 PM   #633 (permalink)
SayTown SRT's Avatar
Member Number: 7544
3147 .68ar
650's
stock fuel pump no return line
cca intercooler
agp intake
ndw downpipe open
msd wires
denso iridiums @32-35
10 afr across the board the sniffer was in the tail pipe downpipe was open i know i can pull some more fuel and make alot more
50/50 mix 93/109
20 psi
hopefully bitts will post up he dynoed the same day 400hp+ on 22 psi
SayTown SRT is offline   Reply With Quote
Old 07-16-2008, 03:32 PM   #634 (permalink)
bitts's Avatar
Member Number: 29842
Trader Rating: (58)
Thanks Greg.
AGP3147 Powered 414hp/489tq tuned by bitts
bitts is offline   Reply With Quote
Old 07-17-2008, 01:11 AM   #635 (permalink)
vcious's Avatar
Member Number: 50913
DAMN! how much boost? very nice! type of fuel?
stage2,Hahn s20g kit, QTP 3" dp w/dump, 3" sri, ED "beast" fmic,agp/turbonetics hp's, whalbro255, agp rL kit, RC 750's, CM w/m injection, 180 therm., catch cans, msd wires/coil, ngk plugs, agp wga,Hallman mbc, "raptor" bov, mm inserts, weapon-r torque damper(stiffy), spec stage3clutch/flyweel, b/s chain cut, s-afc II, PLX wideband,T-XS knock light, autometer(boost30psi,water,volts)A.F.scanguage pro, NDE TSC box
406whp, 425wtq
vcious is online now   Reply With Quote
Old 07-17-2008, 05:18 PM   #636 (permalink)
DrRafy's Avatar
Nice numbers. What mods do you have?, this was in race gas or 50/50 like SayTown_SRT?; are you running 750cc Injectors?
Old 07-19-2008, 03:01 PM   #637 (permalink)
bitts's Avatar
Trader Rating: (58)
~22lbs A/F 10.3/11.2
AGP3147 .48AR
93oct/C12
S2 Inj.
3bar MAP/TIP sensors
Accufab reg/returnline
Walbro 255
PTP re-wire
SAFC2
400cc water/meth inj (20/80)
2.0 cams/Findanza Gears
P/P IM
P/P TB
QW FMIC
ATP UPP/ HKS BOV
Magnaflo 3in exhaust
AEM WB/Scan gauge
S0 pcm
DIY CC
Granatelli Wires/Champion plugs/Stock coil
Turbo X/S HPBC
180* stat
Old 07-19-2008, 08:33 PM   #638 (permalink)
perfectcircle's Avatar
Member Number: 38378
Trader Rating: (18)
Damn man! Nice to see this turbo can hit those numbers..Whats your fuel pressure set at with those stage 2 injectors to be hitting 22 psi?
AGP 3147-B&B TBE-DW650s-SAFCII-AGP CAI-Tein Htechs-TKwalbro-Fp rewire-ssautochrome IC-Coldsidepipe w/HKS-Hurst STS-PTPcheckvalve-Catchcan-Scanguage-Aem wideband-MSD wires-NGK 4306's...
Best 1/4 on street tires and slipping stock clutch:
13.243...114.16 with a 2.307 60'
perfectcircle is offline   Reply With Quote
Old 07-19-2008, 10:54 PM   #639 (permalink)
bitts's Avatar
Trader Rating: (58)
I think it was set at 62psi~ rising rate though, SAFC2 was set at 0 all the way across, id like to drop the pressure a lil, she was still pretty rich till 4.5k~ then started to lean out up top 11.2~
Old 07-20-2008, 10:30 AM   #640 (permalink)
Trader Rating: (18)
yea from the looks of it you could lean it out a little more and pick up some more power. Pretty impressive none the less, I've seen 50 trims with alot lower numbers than that. Whats your fastest time with that setup?
Old 07-22-2008, 04:12 PM   #641 (permalink)
bitts's Avatar
Trader Rating: (58)
Yea a friend of mine only put down 370hp/360tq on 23lbs SCT tune and other bolt on's (.50trim)
I have yet to run it on this set-up (3rd gear crunch) but once that is fixed iam sure I can get her in the high 11's with slicks, I just hope the axles stay in one piece
Old 07-23-2008, 02:49 PM   #642 (permalink)
Trader Rating: (18)
Hmmm...I guess that 3rd gear problem is pretty common, a friend of mine has just replaced the shift selector in his plus he's having the issue where it pops in and out of 3rd. So we're guessing its the 3rd gear syncro... Really interested to see your track times when you get everything in good working order so be sure to post them!
Old 08-16-2008, 08:17 PM   #643 (permalink)
thepusher's Avatar
Member Number: 66865
Will the stock block and head support the 3147 running at 20psi with the right fuel and air mods?
thepusher is offline   Reply With Quote
Old 08-16-2008, 08:36 PM   #644 (permalink)
Member Number: 64760
Trader Rating: (17)
easily. youll max the turbo out a tad under what this block can typically hold.
91PumpKing. is offline   Reply With Quote
Old 08-16-2008, 08:48 PM   #645 (permalink)
thepusher's Avatar
Thanks, I guess that means AGP stage 4 time!
