Old 05-04-2008, 12:52 AM   #601 (permalink)
Member Number: 11681
Trader Rating: (96)
Quote: Originally Posted by OrangeMopar View Post
I'm having the opposite problem from dansrt4. I just street tuned mine to 20 psi and still am getting a MAX of 10.4 afr. I'm only pulling out 15% with the neo, any more and I start to see a 2.0-2.5 count of knock. Pulls like a son of a bitch but I would like to get the afrs at least into the low 11's. Right now I'm running about 42 psi static on the return line, have the 1:1 hooked up, 255 walbro and DW 650's for fuel.
Talked to my one buddy today and we think some of the problem might be the direct fit QW intercooler. I definately need to replace it to help with spool also. Full boost comes on around 3400-3500.
I would stop thinking the FMIC is the problem and focus more on the fuel problems. Dont pull more then around 25% you will run into issues with knock for sure then.
Fastest stock turbo no n2o in the country.
Best 60 1.662
Best 1/8 7.55/93
Best 1/4 11.865/116
Best MPG 27.3 city/33 highway
Old 05-04-2008, 12:55 AM   #602 (permalink)
Trader Rating: (96)
Quote: Originally Posted by terboneon View Post
Dyno numbers? What injectors?
Still with the s2/s3 injectors with a return line. I pretty much figured around 19-21 would be about it and it is. No dyno till i get injectors would be a waste of money and dyno queening till i get them.
Old 05-04-2008, 08:06 PM   #603 (permalink)
Member Number: 42621
Trader Rating: (37)
Quote: Originally Posted by mad1 View Post
Stop running 1:1 and see if it will lean it out safely.
Yeah that's going to be my next move.
OrangeMopar is offline   Reply With Quote
Old 05-05-2008, 07:07 PM   #604 (permalink)
terboneon's Avatar
Member Number: 8891
Huh, that returnline must really make a big difference.
Well, here's my dilema now.....I am also running the 680s (stage 2 no toys currently) on my 3147, but no returnline, just a walbro 255. I just installed my wideband yesterday to see where my afr's are before turning up the boost. I'm only running the 10 lb spring in the wastegate for now, so I was expecting my a/f to be similar to my previous stage 2 numbers (10.5-11.0).
This is definately NOT the case, the first pull I did, I got 12.5-13.0. I quickly backed off and double checked my settings on the afc-II, all zeros, check.
Ok, I tried again and got an 11.xx for a split second but the rest of the time it was 12.0-12.7. Not cool.
The w/b reads 14.7-14.8 idling, so it seems calibrated. I'm just wondering if this is how it's supposed to run at this low of boost. Honestly, I never had the stock turbo running this low, so maybe it ran like this before, but I doubt it. All I know for certain is that at 19 psi on the stock turbo, it was 10.5-11.0 before leaning it out a bit with the afc. I'm just worried to turn the boost up now and risk running majorly lean to while trying to see what's going on.
Suggestions anyone? Do I turn the boost up to see, or do I start trouble shooting the fuel?
terboneon is offline   Reply With Quote
Old 05-05-2008, 07:50 PM   #605 (permalink)
mad1's Avatar
Member Number: 26914
Trader Rating: (10)
What is the boost at? The wastegate spring doesn't mean much on externals. I can boost 24 lbs on the big spring ( 11 lbs or ?). But 10 lbs on a 3147 is alot more air and pressure than a stock turbo.
3147, AEM EMS, 750's, DCR oil kt, Oil mod, DCR TB, SBC 5x , MD 72%, MAXF 3" See /res, AGP w/HKS, LC-1 WB, Raptor Shft Lt, Agp RTL w/pump. SBeast ic , AGP solids , Injen SRI. 30lb gg , billet sel, F&F P&P intake,WOT box. Stage 1 springs. 20% tint. KTP Sport alloys
Aaron tuned. Rick built.
388 hp and 420 tq at 24 lbs @ 94 w/6700 redline
11.95 @ 119.7.. 1.88 60'= pump gas & slicks
mad1 is online now   Reply With Quote
Old 05-06-2008, 08:39 AM   #606 (permalink)
terboneon's Avatar
Member Number: 8891
It is just the 10 lb spring alone. Boost is at 10 psi to redline.
Old 05-06-2008, 09:38 PM   #607 (permalink)
SayTown SRT's Avatar
Member Number: 7544
i had the same problem. part of it is that the scaling of the fuel maps for the 682 injectors. switch to rc650's you'll only have to pull about 10-15%. your other option would be to use a stock computer and sensors and the scalling will have the s2 injectors at higher duty cycle. i went with the 650's
SayTown SRT is offline   Reply With Quote
Old 05-07-2008, 12:46 AM   #608 (permalink)
Trader Rating: (96)
well i got a deal on some 750's and they are in now. WOW 23psi is pretty damn fun thats for sure.
Old 05-07-2008, 02:08 PM   #609 (permalink)
mad1's Avatar
Trader Rating: (10)
It's a hair blowing back handfull. Isn't it. LOL !!
At the top of 3rd and fourth it's a real experiance. Looking death in the face on the street. AHH !~!
Old 05-07-2008, 05:58 PM   #610 (permalink)
bitts's Avatar
Member Number: 29842
Trader Rating: (48)
<----Is looking for a return line
Former Tn. red-neck
bitts is offline   Reply With Quote
Old 05-07-2008, 07:58 PM   #611 (permalink)
terboneon's Avatar
Member Number: 8891
Ok, do you know whether or not the duty cycle will increase if I up the boost? On AGPs site they say that you should be able to run a 50 trim at ~16 psi on stage 2 before maxing it out. I'm thinking that once it sees higher boost, the computer will kick up the injector duty cycle. Kind of nervous to try this though, since I'm already lean.
Thank you for the input.
Old 05-14-2008, 02:26 PM   #612 (permalink)
asthe_skyfalls's Avatar
Member Number: 42018
Hey guys i was wondering what mod to do next (besides clutch) for my srt-4. I have previously posted my dyno 375whp/379wtq which was tuned and dyno'd before the Mpx fmic and the dcr oil mod. Anyone know around what power i should be at right now? So just wanted to know your input as to what mod i should do next as you are fellow 3147 owners
Here are my mods as i jotted them down as i bought stuff lol
Current mods:
AGP 3147 Turbo kit
TurboXs High Performance Manual Boost Controller
MPx 3" turbo back No cat
Hks Ssqv with AGP Uppipe
Aem 3" Cold air intake
Mpx large front mount intercooler
AGP Fuel return line kit
DCR Oil Modifier
RC 750cc injectors
walbro 255lph fuel pump
Apexi S-afc Neo
MSD tach driver
Apexi turbo timer
Solid Tune
2005 Flame Red Srt-4 // Agp 3147
Pm me if you need any stock srt-4 parts
asthe_skyfalls is offline   Reply With Quote
Old 05-14-2008, 03:58 PM   #613 (permalink)
bitts's Avatar
Trader Rating: (48)
-Meth kit
-Ported IM
-bigger TB
for starters
Old 05-14-2008, 04:59 PM   #614 (permalink)
mad1's Avatar
Trader Rating: (10)
All the above and....
An AEM ems is great too. A bit pricy, but drivability and compensation for weather is great. And a built in 2 step. Meth and nitrous control. And with a boost solenoid you get great boost control. And a ton of other stuff it can do.
Old 05-21-2008, 10:44 PM   #615 (permalink)
6lue5pool's Avatar
Member Number: 64241
What AFR are most of you running in your tune with zero Knock Retard on pump gas without using water injection. Also what boost are you running with this AFR? Are you keeping the AFR curve flat or are you running a leaner AFR to help spool time then richening it up as you approach redline?
I'm just trying to get my portfueler tuned safe with the agp 3147... Answers to these questions will help get me pointed in the right direction. I am currently tunned at 10.3afr @ 3200rpm and as I approach redline I get an 11.3afr, but I am also getting Knock Retard of 4 to 5 at redline. This is on pump gas at 18 to 19psi, and no water injection.
Thanks for any help you can provide!
6lue5pool is offline   Reply With Quote
