Old 11-20-2008, 10:02 PM   #1 (permalink)
thnefosp's Avatar
Member Number: 44895
Default 2.4 engine block?
i am trying to figure out if the na 2.4 engine block out of a stratus or van is different than the turbo 2.4 in the srt-4 neon. i would like to build a motor for my car but need to be able to drive it while doing so. and a buddy of mine has a na 2.4 block he will give me. thanks for the help
agp race fmic agp hard pipes with ssq agp solid motor mounts greddy turbo timer quicktime down pipe with cut out, side exit exhaust driveshaft shop axles power slot brakes with monster green pads agp cold air intake msd coil pack msd 8.5 wires rear strut tower bar short throw shifter with bugger bushings gt3076 turbo rc 750 injectors 255 lph fuel pump dtec fuel controler agp return line front strut tower bar mt drag radials
12.064 at 120 mph
thnefosp is offline   Reply With Quote
Old 11-21-2008, 02:11 AM   #2 (permalink)
LiFeGuArDrOb's Avatar
Member Number: 30007
I have also wondered the same. Guess it depends on if you can plum the oil lines into the block, any plugs in the block?
Same boat, would love to build an engine while still driving the car!
I work at a golf course
LiFeGuArDrOb is offline   Reply With Quote
Old 11-21-2008, 08:35 AM   #3 (permalink)
camlifter's Avatar
Member Number: 3008
Trader Rating: (25)
the na block dosen't have oil squirters, not a problem unless it's going to be a road track car. theres plugs in the oil passages you can use for the turbo. of course you'll need to change the pistons and rods and the head has a port for egr valve that needs pluged. the valves aren't the same as the turbo head. i'm using a pt motor for my twin turbo project. as long as you build it for boost it will be ok.
heres a pic of the project, twin s3 turbos, full built head w/s3 bc cams and forged bottom. and yes, it's a motorcycle.
This post is completely ENVIRONMENTALLY GREEN. It was prepared using 100% recycled words and recovered hot air and other gases from the exhaust of the private jet Al Gore used to fly over to Norway and pick up his Nobel Prize. It has been further environmentally corrected and enhanced through the use of Intelligence Offset Coupons.
camlifter is offline   Reply With Quote
Old 11-21-2008, 12:43 PM   #4 (permalink)
Member Number: 58399
Trader Rating: (36)
^^^^^ that's awesome, there are alot of those turbo dirt drag bikes around here... A couple Busa' and gsxr-1000's, I have an 07 1000 I want to put a Velocity Racing Kit on...
On topic: I know the squirters arent in the NA block also, I would buy a used or bad short block off here, at the most with a spun bearing you would have to buy a new crank, then you could send it to TK or DCR and have them Ionize it or Cryo treat it... Or use a NA block and do the work he is talking about to make it work
DCR Powered
tcglass1 is offline   Reply With Quote
Page generated in 0.14039 seconds with 13 queries
