Old 05-18-2008, 06:25 PM   #1 (permalink)
Member Number: 50647
Default 16psi radiator cap or stock 18psi or more
my radiator cap took a crap on me and my car lose all is coolent by the overflow reservoir but it never overheated
it was on the weekend so only few part store where open so the only radiator cap ive found is a 16psi
now my car run well but when i check in the elbow when cold it need maybe a glass of coolent and the coolent is in the overflow
does my cap does not hold as much pressure as is needed or i have another problem
speedup is offline   Reply With Quote
Old 05-19-2008, 01:27 AM   #2 (permalink)
Member Number: 39895
MAKE SURE YOU USE THE SAME PSI CAP AS STOCK.
MOST SYSTEMS ARE 17 MAX
For every 1 psi added in the cooling system you raise the boiling point of your coolant 3 degrees F.
Too much psi can do bad things such as blow out your radiator. Unless you have a race set up. Go with stock and nothing else.
Casey @ NBP
kreepin06 is offline   Reply With Quote
Old 05-19-2008, 05:21 AM   #3 (permalink)
Gringoloco's Avatar
Member Number: 26664
I would check your oil for coolant and coolant for oil. Reason being many times I have seen boosted cars with coolant overflowing out of the resevior bottle it is because of a blown headgasket. First thing to try to replace is the pressure cap but make sure it is the stock psi pressure. And if it still does it than you most likely have a blown head gasket.
335whp 373tq (for now)
Stage 2, SST, Built Motor/JMB Race Ported Head, Nitrous, SB Stage 5 Clutch and alot of goodies...
Gringoloco is offline   Reply With Quote
Old 05-19-2008, 07:34 AM   #4 (permalink)
the stock system work with a 18lb cap
i dont have oil in the coolent or coolent in the oil for now so i suspect that the cap is not at the right pressure
the car never overheated
Old 05-19-2008, 03:40 PM   #5 (permalink)
supercooper's Avatar
Member Number: 20758
Use 18psi. 16 don't cut it.
Until you go too far, you'll never know how far you can go.
supercooper is offline   Reply With Quote
Page generated in 0.13042 seconds with 11 queries
